Question about Hughes SD-DVR80 DirecTV / TiVo DTV Receiver / 70-Hours Video Recorder
Setup Elro dvr80
Don't know how to set up elro dvr80 and cs74q camera system, pc said that the driver had a problem
How do I find the serial number on an elro dvr 320
most small engines have a serial number stamped into the base of the crankcase on one half.
May 05, 2015 | Garden
I have the camera but don't know how to install it...what do I need to do? I think it is the ice2 model.
Plug you camera, wait for a few seconds your operating system will detect the new device and will ask for the drivers, then insert your driver installation disk and look for setup if it doesnt automatically start the installation process. After installation your camera should work just fine. hope that helps.
Sep 07, 2011 | Macally IceCam Personal Web Camera
How can i find drivers and install pc video camera Deluxe.I don;t have a disk
Go to your computer's manufacturer's website or the web-cam manufacturer's website and search for the web-cam drivers for your computer model and operating system. Download the proper driver setup and run it, this will install the software for you to use the web-cam.
Mar 14, 2010 | Computers & Internet
I have logitech camera but i don;t have drivers and i don;t have model no also
Normal 0 Normal 0 I gave you a diagnostic program to check the model and then gave you the site to get the drivers.
Be sure the camera is plugged into the USB port before running the program.
As you run the program, write down the info about the camera so you will know what you have .
Double click on this site and download the Camera Diagnostic Tool and run it to check out your camera and/or problem.
http://www.download32.com/webcam-diagnostics-d35065.html
I ran the diagnostic on my camera to give you an idea how well it works.
Give it a try.
http://www.logitech.com/index.cfm/support_downloads/&cl=us,en
Then
Search by Image (Match what yours looks like)
or
Search by Name
and
Product Name.
This will then take you to the next window where you need to select your
Operating System
. Then you will get your download driver.
Then do this:
Disconnect the Camera from the USB port and reinstall the CD or Downloaded softwareprogram. When the program asks you to connect the camera to theUSB port, do so and it should work.Then to use it on the Web, do this.
Web Camera’s have to besetup on the program they are to be used with. Just installing the cameraon your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order forthe Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Yourfriends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
Hopethis helps. Bud
Hope this helps. Bud
Apr 25, 2009 | Computers & Internet
Elro webcamera driver
Nope, they aint out there. You can buy it for about 100+/- € on Elro's homepage. Problem is that you can get a new for that price. I dont know what the ducthies was thinking when they made that price. And remember that without freight cost.
I got one, but I dont know if its the same cam. but i could rip it and send it to you if you like?
Post the model, and a webmail. Then I could give it a go.
Mar 26, 2009 | Cameras
Hughes sd-dvr80 direct tv receiver tivo
go to your settings page and run the initial setup. make sure each section is done correctly. the tivo might take a second to start downloading the locals.
Jan 03, 2009 | Hughes SD-DVR80 DirecTV / TiVo DTV...
Remote control code for sd-dvr80
is this the remote that came with it or if not what kind is it? if it is the remote that came with it then here is a link to the manual for your device
http://www.2000networks.com/manuals_discontinued.html#hughes_sd-dvr80
Oct 10, 2008 | Hughes SD-DVR80 DirecTV / TiVo DTV...
Dvr80
let me know exactly what u need
b_stro804@yahoo.com
subject TIVO instructions
Sep 24, 2008 | Hughes SD-DVR80 DirecTV / TiVo DTV...
Remote does not work
Do the buttons on the front panel of the unit work?
If so, try doing this:
Hit the tivo button, go down to messages and setup and into to system information. Go down a few screens until you see remote code. Hold (on your remote) the tivo button and pause button for about 5 seconds. Then hit 0-9 on your remote to set the code. It's a single digit code only. You'll see your remote light flash. Now, try hitting the back button and see if your remote works. If it does, great. If it doesn't that means one or more of the following:
1) Your remote is defective
2) Your IR receiver on the unit isn't working correctly.
If #2 is the problem, you'll need to open up the unit, powered down! and make sure the thin, greyish ribbon cable in the front of the motherboard is 100% in. If it's not all the way in, it will cause issues.
Nov 20, 2007 | Hughes SD-DVR80 DirecTV / TiVo DTV...
Hughes SD-DVR80 DirecTV / TiVo DTV Receiver / 70-Hours Video Recorder Logo
145 people viewed this question
Top Hughes Televison & Video Experts
jason
Jim London
Jim London
Edward Talavera
Edward Talavera
Are you a Hughes Televison and Video Expert? Answer questions, earn points and help others
