SPARK PLUG GAP M10962-2 - Heating & Cooling
  • 2336 Answers
SOURCE: spark plug gap
it is 0.036 in
Posted on Nov 10, 2008
  • 1779 Answers
SOURCE: 2004 Honda Accord spark plug gap
.044 Happy New Year!
Posted on Jan 02, 2009
  • 196 Answers
SOURCE: Spark Plug gap settings.
Look on you're emissions tag under the hood they should be on there.
Posted on Jan 16, 2009
SOURCE: spark plug gap ford explorer 4.0 6cylinder
Our 2003 Explorer V6 requires:
0.052 - 0.056" plug gap
Posted on Sep 02, 2009
  • 86 Answers
SOURCE: Spark plug gap 150 hp Yamaha outboard
The correct gap is .035
Posted on Oct 16, 2009
What is the spark plug gap for the above car which is 4 cylinder. thanks
1988 Oldsmobile Cutlass Ciera, original GM plug gap .045".
this is what i would gap new plugs too, AC Delco Part # R44LTS plugs probably gaped at this already.
press the helpful button
How To Change Spark Plugs on 1987 Cutlass Ciera SL 3 8L
Spark Plug Gap NGK Spark Plugs Tech Video
How to Gap Spark Plug
Feb 04, 2016 | 1988 Oldsmobile Cutlass Ciera
Spark plug gap 96 gov safari ACDelco platinum 41-942
Spark Plug Gap - AutoZone
www.autozone.com/.../specificationsMain.jsp?...Spark+Plug+G...
AutoZone2004 Mercury Grand Marquis 4.6L SFI 8cyl ' Specifications ' Spark Plug Gap.
AstroSafari.com • Spark plug gap size?
www.astrosafari.com/viewtopic.php?f=43&t=81409
Jul 27, 2015 - You're doing a '96? I think EARLIER 2nd Gen 4.3's used a .045" gap ; I believe it changed in 2000 or 2001 but don't quote me on that. All i'm ...Missing: gov
AstroSafariVans.com • View topic - spark plug gap question
astrosafarivans.org > ... > ENGINES GENERAL/PERFORMANCE
Nov 28, 2012 - 15 posts - ‎4 authors
My question is do I gap the spark plugs per 89 4.3 specs or do I use the 95 .... The vortec heads for a V8 chevy are 1996 and up however there ...Missing: gov
What is the proper sparkplug gap? - CarGurus
www.cargurus.com > Questions > GMC > Jimmy
CarGurusMar 16, 2013 - My Haynes manual and various places I've seen online say the gap is .045 inches ... spark plug gap for 1992 4.3 160 HP? ... Used GMC Safari".Missing: gov
[PDF]2000 GMC Safari Owners Manual - GM Extended Warranty
www.vadengmpp.com/owners-manual/gmc/2000-GMC-Safari.pdf
Jan 27, 2016 | Cars & Trucks
Spark plug gap
How to Gap a Spark Plug - YouTube
? 2:57
https://www.youtube.com/watch?v=IuW3svdqKZM
Oct 15, 2012 - Uploaded by ChrisFix
How to correctly gap a spark plug. This is a fast and easy video on how to gap a spark plug and spark plug gap ...
FAQ: Find My Engine Spark Plug & Gap ' Briggs & Stratton
www.briggsandstratton.com/.../identifying-the-correct-s...
Briggs & StrattonFollow this step-by-step image guide to locate spark plugs in different Briggs & Stratton engine types. ... Spark Plug Type & Gap Chart for Briggs & Stratton Engines. Now that you've found the part you'd like to replace, you can use the chart below to identify the genuine Briggs & ...
Dec 15, 2015 | Cars & Trucks
Can i use a ruler to measure gap on spark plug
If your can see the difference between .020 (20 thousands) and .025 (25 thousandths) of an inch than you may not need a gap tool.
A $3 spark plug gap tool is a must, you can get it at any auto parts store. Also if your spark plug is stuck in the socket, get a new socket and spark plug, but if you need it now take the socket wrench off the socket and place the socket in a vice. Then with the biggest screwdriver that will fit in the socket wrench hole, place the screw driver tip on the top of the spark plug stuck in the socket and hit the other end of the screw driver with a hammer until the spark plug comes out...... get a bigger hammer. note: the old spark plug may not survive.
Mar 02, 2015 | Cars & Trucks
Spark plug gap settings chart
The spark plug gap depends from the engine make/model, not from the spark plug type.
Usually all engines will run with a gap between 0.7 and 1.00mm
Jul 30, 2014 | Champion Spark Plugs Marine Spark Plugs...
Ngk spark plug gap for 2005 hummer h2
check Gap: .040
Bosch Spark Plug: Part Number: 18594-05120685
PLATINUM -- Original Equipment is Iridium. Gap is Preset
OE Fine Wire Platinum -- Do Not Gap, Gap is Preset
OE Fine Wire Iridium -- Do Not Gap, Gap is Preset
Sep 22, 2013 | Spark Plugs BR4HS Plug 10/BX #3322
Need do know the spark plugs gap
If you're replacing the spark plugs in your car engine, you'll need to set the gap before reseating the spark plug. The gap is the distance electricity arcs between the ground electrode and center electrode. The gap must be set correctly to ensure maximum performance. Here's how to set the gap of a spark plug.
  1. Remove the spark plug wires. Use a socket wrench to remove the spark plugs from their chambers.
  2. Clean the spark plug if you are not replacing it with a new one. Remove all dirt and debris from the spark plug.
  3. Check the owner's manual for your car (or any appliance with spark plugs) to find out the recommended gap setting.
  4. Use a gap tool to check the gap of the spark plug. Slip the tool between the ground electrode and center electrode. The gap tool should fit snugly at the recommended gap width indicated on the tool.
  5. Push the tool between the electrodes a few times to ensure proper gap. If the gap is too wide, push the ground electrode firmly against a flat surface to narrow the gap and then check again with the gap tool.
  6. Repeat Step 5 as necessary until you reach the correct gap. Reseat the spark plug and reattach the spark plug wires
Good Luck
Dec 10, 2010 | 1997 Pontiac Grand Am
Spark plug Gap for 2000 chevy cavalieR
Hello, here is the spark plug gap for this vehicle.
Spark Plug Gap: 2.2L Engine LN2 0.00157mm.(.040 in.)
2.4 quad engine Spark Plug Gap: 1.27 mm (050 in)
Oct 25, 2010 | 2000 Chevrolet Cavalier
Whet is spark plug gap
Spark plug gap refers to the amount of separation between the center electrode of the plug and the bent tang at the bottom of the plug. Too small a gap and you get a weak spark. Too wide a gap and the plug may not fire every time. Most bikes today have CDI (Capacitor Discharge Ignition ). CDI produces a strong spark and works best with a gap of .35 to .45.
May 08, 2010 | 2002 Suzuki GZ 125 Marauder
Spark plug gap
Notice: This engine has aluminum cylinder heads. Do not remove the spark plugs from a hot engine, allow it to cool first. Removing the spark plugs from a hot engine may cause spark plug thread damage or cylinder head damage.
Gap the spark plug, using round wire type spark plug gap gage.
Gap Adjust the spark plug gap to 1.14 mm (0.045 in).
DO NOT coat the spark plugs with anti seize compound. Over torquing could occur and damage to the cylinder head threads may result.
If your going to use Platnum plugs, DO NOT GAP them. Just check the gap and if there not the right gap, ask for new one's with the right gap.
The metal on the PLatnum plugs, are harder and my break apart in the cylinder .
Good luck and hope this helps
May 02, 2009 | Pontiac Sunfire Cars & Trucks
Heating & Cooling Logo
87 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
