Question about Bosch Coffee Makers & Espresso Machines
Brewing unit stuck
I have a similar issue with former posts. The brew unit of my Siemens Surpresso Compact TK58001 is stuck with the nose in upper position. The steamer and power lights flash alternatively and the machine does not respond to any pressing of buttons. The machine fails to reset the error by switching off and on. I saw a youtube video for a Saeco that shows that you first need to move the screw connected to the water supply, however I see nothing similar or accessible on the Siemens.
2 Suggested Answers
  • 1833 Answers
SOURCE: I have a two year Problem
Hi, First turn off and unplug your coffee maker. Unscrew the two screw holding the outlet and remove it. you can follow the service manual for help.
Posted on May 04, 2011
Machine is not starting right - brew unit gets stuck and if removed in order to reset the alignment of the gearing wheel in the machine, it does not align in order to get the brew unit back in place.
When the upper and lower, dregs box and descale light, are flashing alternatively, this means that either the grinder or the brew group motor, sensors or switches are not responding to the CPU or pwr board. This will need to be brought to a Saeco Service center for repair. I would not attempt to repair without proper working knowledge of the cpu and pwr system.
Apr 30, 2016 | Saeco Odea Giro Plus Coffee Maker
Gaggia platinum vision
Seems that the valve stuck in wrong position. Try to start cleaning mode.
May 20, 2014 | Coffee Makers & Espresso Machines
Siemens coffee maker model tk540001 brewing unit is stuck!
Hi, I am a user with the same problem but on a Siemens TK580001. Is the solution applicable 1:1 as the two models have different panels?
Jun 11, 2012 | Coffee Makers & Espresso Machines
Problems with unit
siemens surpresso s40 can't finish calc
Mar 26, 2012 | Washing Machines
I have lost my user manual for my Siemens surpresso s 40 . Where can I downloud one ?
You can download it from here.
http://www.siemens-brand.info/siemens-surpresso-s40-manual.html
Jul 20, 2011 | Microwave Ovens
We have a Siemens Surpresso S40, giving 'error 8'
Error 8 indicates a technical fault. Try switching off the main switch for about 1 minute and then start it up again. If the error message persists, you will have to have the machine serviced. The most common fault would be that the machine is blocked.
Jun 06, 2011 | Coffee Makers & Espresso Machines
Platinum B70 "brew temp set"
Brian, sorry, (re post ) with complete question? and make and model
May 11, 2011 | Keurig Platinum B70 Coffee Maker
The machine is showing the brew unit is blocked but we have taken it out and cleaned it but this makes no difference.
Does the brew unit try to move at all? You can listen for the motor, or open the door panel and defeat the safety interlock while it's operating. (Be careful not to put a finger in there.) Then you can observe where the brew unit is getting stuck.
May 19, 2010 | Gaggia Syncrony Compact Digital Espresso...
Jammed brewing unit
Remove the brew unit and check the screen under the red o-ring, find the 2 screws above the top piston and make sure the chamber that leads out to the tube is clear.
Mar 28, 2010 | Solis Master 5000 Espresso Machine
Coffee Makers & Espresso Machines Logo
453 people viewed this question
Top Bosch Coffee Makers & Espresso Machines Experts
Tre Elkins
Oloyede Monsuru
ray gallant
Are you a Bosch Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
