Question about Sony SDM-P234/B 23" LCD Monitor
Flash ??!! no menu ,no picture .Tensions is good .The microcip is GM 1601 . I need the interface for to show me the psb error ??!Thanks
0 characters
1 Points
My DPFMate is showing a blank screen
you must flashing that because the system software is error
Dec 27, 2013 | Spectra DPF-105 Digital Photo Frame...
Samsung t240 - discharging capacitors?
The main 400v capacitor is the one to watch out for. If you carefully handle the power supply board and avoid the area around the power plug you should be good. To properly discharge the capacitor you would need to use a very large resistor and wire to short out the capacitor but if you do it the wrong way you can damage the board beyond repair. Below is a picture of the T240 power supply board with the 400v capacitor circled in red. If you need to get the other capacitors that need to be replaced on the board, which is the most common problem then you can get a parts it here:
I hope this helps,
Sep 20, 2012 | Samsung SyncMaster T240 24 inch LCD...
I need to find the VGA controller for the Dell 2005FPW monitor
you can use on all vga cards(you dont need any special controler), this monitor has a USB hub
and its is detected normaly on winxp or above, and the vga cards detect the monitor auto.
i give you the monitor specs, take form website
Display Type LCD display / TFT active matrix
  • Built-in Devices USB hub
  • Width 18.6 in
  • Depth 9 in
  • Height 15.3 in
  • Weight 17.6 lbs
  • Enclosure Color Midnight gray
  • Image
    • Display (projector) image aspect ratio 16:10
    • Image brightness 300 cd/m2
    • Image Contrast Ratio 600:1
    • Max horizontal view angle +88 / -88
    • Max vertical view angle +88 / -88
    • Diagonal Size 20.1 in
    • Viewable Size 20.1 in
    • Dot Pitch / Pixel Pitch 0.258 mm
    • Max Resolution 1680 x 1050 / 60 Hz
    • Color Support 24-bit (16.7 million colors)
    • Max Sync Rate (V x H) 75 Hz x 83 KHz
    • Video Bandwidth 146 MHz
    • Response Time 12 ms
    • Controls / Adjustments Zoom , Clock , Phase , Contrast , Sharpness , Brightness , Saturation , H/V position , Color balance
    • Display Positions Adjustments Height
    • OSD Languages French , German , English , Spanish , Japanese
    • Display Screen Coating Anti-glare , Hard coating
    • Video Output None
    • Signal Input DVI-D, VGA
    • Features Picture by picture , Picture in picture
    Video Input
    • Analog Video Signal RGB , S-Video , Composite video
    • Digital Video Standard Digital Visual Interface (DVI)
    Audio Output
    • Type None
    Input Device
    • Type None
    Expansion / Connectivity
    • Interfaces 1 x VGA - 15 pin HD D-Sub (HD-15) , 1 x DVI-D - 24 pin digital DVI , 1 x Composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 4 x Hi-Speed USB downstream - 4 pin USB Type A , 1 x Hi-Speed USB upstream - 4 pin USB Type B
    • Flat Panel Mount Interface 100 x 100 mm
    • Features Security lock slot (cable lock sold separately)
    • Compliant Standards CE , CCC , MIC , NOM , PSB , BSMI , GOST , SASO , NEMKO , TUV S , C-Tick , TUV GS , EN55022 , TCO '99 , EN 60950 , ICES-003 , TUV Ergo , UL 60950 , IEC 60950 , EN 61000-3-2 , EN 61000-3-3 , FCC Part 15 B , VCCI Class B ITE
    • Form Factor External
    • Voltage Required AC 120/230 V
    • Power Consumption Operational 55 Watt
    • Power Consumption Stand by / Sleep 3 Watt
    Environmental Parameters
    • Min operating temperature 41 °F
    • Max operating temperature 95 °F
    • Operating humidity range 10 - 80%
    • EPA Energy Star Compliant Yes
    Feb 13, 2010 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
    Shows acer logo then blank screen and just goes from one to the other , power light flash on and off.
    select f8 to enter advance menu. on advance menu
    select last known good configuration. allow unit to boot. if this fails you will need to do a system repair with your windows disk.
    Nov 14, 2009 | Acer AL1711M 17" LCD Monitor
    My Dell E151FP LCD monitor keeps randomly flashing OSD menu, help
    The cable might be pinched or bad.Have you tried the monitor on another PC?
    Good luck
    Oct 17, 2009 | Dell E151FP 15" Flat Panel LCD Monitor
    LG 1710b tft monitor - no picture. screen shows 4 hozizontal line
    Problem with Interface board or panel.
    Also maybe due to defective powersupply filters.
    Dec 10, 2008 | LG Flatron L1710B 17" LCD Monitor
    Problem with controler
    The problem is defective keys/switches of front key PCB.You need to replace this key PCB or Individual keys.
    Normally Benq Offers a 3 yr warranty Try contacting BenQ.
    Please rate the solution and provide feedback.
    May 15, 2008 | BenQ FP731 17" LCD Monitor
    NEC fs 5197 tv blank screen
    I cannot assist but do you please have an owners manual for the FS 5197. I'm not sure if its against this sites "rules" but little fingers have tuned the menu's instructions into Arabic. Contact me directly at Thanks
    Feb 10, 2008 | NEC-Mitsubishi AccuSync LCD72V 17" LCD...
    Blank Screen..Will not power off
    The flash light test only works with lcd monitor as they have back lights. Double check the connections again, also, if you can borrow a monitor try it on your pc, it may be your graphics driver needs to be uninstalled and re-installed, but you will need a monitor to see.
    Dec 13, 2006 | Proview PS 776 Monitor
    Sharp LL T17A4-B (Black) 17 in.
    Are you using the digital connection?? If so try using both the analog and digital connection then set the digital as the Main monitor in your graphics card interface. To check if the backlight is out, darken the room, and light a flash light into the screen. If you can see a picture, then you need to replace the backlight. Good luck
    May 03, 2006 | Sharp LL T17A4-B 17" Flat Panel LCD...
    Sony SDM-P234/B 23" LCD Monitor Logo
    Top Sony Computer Monitors Experts
    Lala Alonsi
    Lala Alonsi
    ray gallant
    Are you a Sony Computer Monitor Expert? Answer questions, earn points and help others
