Question about Konica Minolta Bizhub Pro C6500 Color Copier Color Printer
Biz Hub c6501 gives error code 3501 - Konica Minolta Bizhub Pro C6500 Color Copier Color Printer
Kevin Hayes
  • 167 Answers
SOURCE: Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
Posted on Feb 17, 2009
firecontrol7
  • 6161 Answers
SOURCE: biz hub 6500 has a code c3508 how do i clear it
If this code comes right back do not attemp to clear again, contact a certified service technician and have him or her look at this problem, it deals with fuser the hot part of the machine. Dangerious!!
To reset a fuser abnormality code, perform the following:
1. Power the machine OFF from the main switch leaving the sub switch ON.
2. Press the utility Key and power ON the machine from the main switch.
3. Enter Stop => 0 => 0 => Stop => 0 => 1.
4. Press [03 System Setting] on the touchscreen.
5.Press [01 Software SW setting] on the touchscreen.
6.Press the left up-arrow, which is displayed on the touchscreen, 2 times. The number displayed above the up-arrow will change to 03.
7. Select the bit number of switch 1, using the right up-arrow, 03-1 will be indicated.
8. Press the [Return] key, which is displayed on the touchscreen.
9. Exit Service mode to return to normal operation.
DipSW 3-1 is set to 0 without correcting the cause of the error, a fire may occur.
Posted on Aug 15, 2009
SOURCE: Biz Hub c250 gives error code 3452
C3452: Pressure Heater Trouble.
Try to reset it like this:
Shut down from the main power switch (the one behind the front cover).
Keep pressed the Utility/Counter button.
Power on while the button is kept pushed.
Release the 'Utility/Counter' button only when you see the 'Trouble Reset' button on the touch screen.
Touch the 'Trouble Reset' button, a small ok should pop up underneath.
Power off, wait for a few seconds and then power on.
Posted on Aug 23, 2009
  • 158 Answers
SOURCE: konica minolta biz hub C250 need to reset admin code URGENT
you cannot overide the administrator password on the konicas the default password is 12345678 try that
Posted on Oct 31, 2009
  • 44 Answers
SOURCE: bizhub 250. error c2152
Check and make sure there are no jams by the fuser ie: bits of paper in the paper path.
Posted on Nov 29, 2009
How to fix trouble code 0910
Unrecoverable error (The count is made by C-5402.)
An abnormal operation accurs when an interupt copy is made (copy print job 1). Estmated defective par Overall control board (OACB).
Oct 15, 2014 | Konica Minolta Office Equipment & Supplies
Error code 3501
HI
I HAVE KONICA C6500
ERROR CODE 3501 and 3802 but know the error 3501
I know it rech high temperature I change the sensor 1 UP fuser roller
and I reset the error, the machine start and stop again with error 3501
Oct 01, 2013 | Konica Minolta Bizhub C 6500 Copier
Error code c1144
I have 5 biz hub 654s. There is no "utility" hardware button. Instead, open the front cover (marked "biz hub 654") - switch off the main power - white switch in an orange rectangle. Wait 30 secs. Flip back on- then QUICKLY close the door while holding down the yellow RESET button. "Trouble reset" appears - tap it - OK appears below it. Use main power to power down. Wait 30 seconds. Power back up. Works every time.
Nov 01, 2012 | Konica Minolta Office Equipment & Supplies
Ihave konicaminolta biz hub pro c6501 machine when i take 300 gsm paper in trailing edge the images getting blurred . please help me
300 serious thickness. Does it do it out of all draws and bypass trays? Certainly will slow the machine down to fuse it properly
Jan 03, 2012 | Konica Minolta Products - Konica Minolta -...
Printing every other line in different quality
Hardware error
Error Code 3501
Error Code 6203
Error Code 6203
Error Code 3501
Sep 10, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Whats error code 3501
According to Kodak, that error just means the cover was open. I noticed when I print a diagnostic sheet that error shows up whenever I change the ink.
Sep 02, 2008 | Kodak ESP 5 Printer
Not printing
try to press and hold the copy and cancel button at the same time. It should take up a pice of paper and spit it out blank. then try to print again. if problems persist call the 1 800 235 6325 kodak support hotline
Jul 25, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Since installing my printer I have a error code of 3610 and 3501
Go to the Kodak.com website and follow their prompts to reach Customer Support for the AiO Printer(s).
Had similar issues with mine and they resolved my problem overnite by sending me a replacement part.
Jan 01, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Konica Minolta Bizhub Pro C6500 Color Copier Color Printer Logo
85 people viewed this question
Top Konica Minolta Computers & Internet Experts
Lawrence Oravetz
David Payne
David Payne
Tom Chichester
Are you a Konica Minolta Computer and Internet Expert? Answer questions, earn points and help others
