Question about Dell 2155cn AllInOne Laser Printer
Want to stop a print order
A large print order has gone through in erro I need to stop it, is there a way of doing this?
  • Dell Master
  • 8,068 Answers
Stop the printer. On your desktop (taskbar) find the icon of the printer. Display the queue, select the job and terminate it
Posted on Nov 20, 2013
Lexmark 4300 printer suddenly stopped working. Replaced black ink cartridge--same erroe comes on eventhough the screen shows a fullk catrdge. I down loaded new drivers---nothing.I called the company direct...
Are you still able to scan or make a copy? Can your printer still do any of its functions? Try to remove the cartridges from your printer. Close the printer cover. Wipe the cartridge nozzles with a soft moistened cloth to clean the dirts and clogs. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert the cartridges and close the cover. Try to print again. If problem continues, please contact Lexmark technical support for additional assistance.
May 16, 2011 | Lexmark P4350 All-In-One InkJet Printer
How do I cancel an order to make it stop printing and clear it out of the system
Click on Start button
Click on Run
Type SERVICES.MSC and click ok
look for Print Spooler in the list
highlight Print Spooler,
Click on STOP button then click on START
close the window and check if the print queue is gone.
Alternate method,
Click STart
Click RUN
Type Cmd ( or COMMAND ) and hit enter
In the black window type
NET STOP SPOOLER ( hit enter button )
Type
NET START SPOOLER ( hit enter button )
Repeat the Stop and START Command 4-5 times
End the Command with NET START SPOOLER
Open Printers and faxes folder - Refresh the Window - the printer will show STatus ready with 0 document
Jun 23, 2010 | Zebra 105SL Thermal Label Printer
Hp designjet 8000s 1290 error
ESSE ERRO DE SISTEMA 1290 ACONTECE QUANDO O TEMPO DE TROCA DE ALGUMAS PEçAS ESTá PERTO, GERALMENTE é A TROCA DO KIT DE LIMPEZA.
QUANDO ACONTECER ISSO BASTA FAZER O SEGUINTE:
- DESLIGUE A IMPRESSORA;
- PRESSIONE DE UMA Só VEZ O SHIFT+CANCEL E DEPOIS LIGUE;
- SETA PRA ESQUERDA+SETA PRA DIREITA+SHIFT+OK;
- Vá ATé O íTEM COUT DEPOIS OK
- OK.
- DESLIGUE.
- AO LIGAR ELA VOLTA A FUNCIONAR.
Apr 05, 2010 | HP DesignJet 9000 InkJet Printer
Erro code 900.00 service RIP soft ware. What is
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Dell 5310n: error message is 900.00 service RIP software A few of my users were having trouble with a Dell 5310n printer. The error message on the display was error message is 900.00 service RIP software. When printing large data files, such as a PowerPoint presentation, the printer would error out.
Per Dell's recommendation I configured the virtual printer to not spool the print jobs and send them directly to the printer. This seems to have corrected the issue so far.
Since I have HP printers on the same print server and none of them have had any kind of issue printing the same large files, I starting to think that the problem is due to either bad printer hardware or print drivers from Dell.
http://itadmindev.blogspot.com/2008/07/dell-5310n-error-message-is-90000.html
Feb 03, 2010 | Dell 5310n Laser Printer
Erro code "900.00 service RIP Soft ware. What is this?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This is what I foudn working on the same problem....
What does erroe code 2 mean?
paper jam , but you ned to open the upper cover then clean stel ruller which the head of ink cartdrige move in it when it copy then but graze and then clean the slot of unite waste ink yiu see it when the cartdrige stop move then put graze on it and try move it on you hand some times and see the move must be very easy thts all
Dec 18, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
I cant get my printer to clean or print keeps saying unable to print, please help
verifiqure se da algum erro
se der o erro:machine error xxx
faça o seguinte:
May 15, 2009 | Brother MFC-215C All-In-One InkJet Printer
Stopped printing, need drum? but no light on
Hi! sandy; Your printer not really heavey duty one, and you give them big jobs, for a sample, you give adult jobs to the baby, it not going run, so your machine need a break! nothing wrong just give them little bit rest.
May 06, 2009 | Brother HL 5250DN Laser Printer
Panasonic FP 1780 Copier. The copier has a flashing wrench that will not reset. I need advice on resetting the wrench.
Hold down 3 buttons in this order:
Paper Tray (Oval button), Recall (Diamond) and #3.
You should see an F2 in the display.
Enter #5 (Display should be showing F5)
Hit the Print Button. (Display should show C00)
Enter 70. (Display should show C70)
Hit the print button. (Display should show probably a 7 or 8)
Hit the print button again. The print button should go Red for a second and then back to green.
Wrench should be gone.
Next to get out of service mode
Hit Clear / stop button until the display shows F5
Then hold down 3 buttons in this order:
Paper Tray, Recall and the Clear Stop button.
You should now be back to working order.
If you have any questions or need parts, feel free to ask.
Have a good day.
Good luck.
Please remember to leave your rating if I have helped you.
Mac
Apr 15, 2008 | Office Equipment & Supplies
Dell 2155cn AllInOne Laser Printer Logo
14 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
