Question about Bosch Logixx WAS2446 Front Load Washer
Bosch logixx 8 E57
Error code e57
    New Friend:
Circut board of the motor is demeged.if you take out the board witch is next to the moyoryou will see on the electronic print
The demeg.
Posted on Jul 24, 2015
  • 3741 Answers
SOURCE: i need a bosch WAS24466GB user manual
click on the link below and download the manual,if asked you will have to enter model number or else you can download user manual directly from the link:
bosch user manual
thanks.
Posted on Aug 31, 2009
Testimonial: "thank you, that was very helpful"
SOURCE: Bosch washing machine logixx 8 front loader error
Det er for koldt i rommet, eller vandrør har frosset til.Sett opp temperatur i rommet eller tine rør
Posted on Jan 15, 2010
  • 414 Answers
SOURCE: f:23 code logixx edition75
Usually means there is water in the base pan and the flood safety has been activated. If you tip the unit forward a touch you will most likely find that water is expelled from the bottom front. The machine should work but obviously the source of the leak has to be found. Check door gasket for tears etc, water valves and drain hoses.
Hope this helps.
Posted on Jul 07, 2010
SOURCE: bosch logixx code f-23 .wat does it mean?
it means the float at the base of the machine has been triggered. Open the back panel on the machine (turn off power and water tap first) then remove all screws and take metallic back off. Dry inside base with a towel and push down the float which is located in the corner. This will reset it. Keep an eye on it as it may mean you have a leak.
Posted on Aug 04, 2010
SOURCE: How do you remove Pump Cover on Logixx 8 washing machine?
I have a solution.You just keep turning the white knob anticlockwise. Use a pair of pliars to aid the turning keep going clockwise and anticlockwise if it gets stuck. It will rotate. Just opened my one and found a lollipop stick and a collar stiffner. Good Luck.
Posted on Dec 02, 2011
How to unlock door on Siemens iq 700 showing error code e57
go to the manufactures website and download the user manual it normally free to download
Dec 24, 2017 | Siemens Washing Machines
What does error code E57 indicate?
E57 means that your inverter board is drawing too much power' below link shows where and how,
press the helpful button
GE Front Load Washer Inverter Removal
Jan 25, 2016 | Washing Machines
Bosch avantixx 8 waq error code e44
E44 means a motor fault. More here: http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3310-bosch-logixx-was-series-washing-machine-error-codes.html
Mar 03, 2015 | Bosch Washing Machines
Bosch washing machine (logixx 8) shows error code F57
The E57 error code on the Bosch Logixx 8 means that there has been a door lock fault.
Feb 13, 2015 | Bosch Washing Machines
What is error code E57?
E57 Checksum failure Software error occurs - checksum failure. Non-recoverable error. Main control board must be replaced.
Nov 07, 2014 | Washing Machines
ERROR CODE E57 indicates what?
For most questions you should supply as much information as possible, especially manufacturer & model #.
I'm sure error codes are different by manufacturer.
I found this answer for an electrolux;
Regrettably, error codes E57 and E58 could mean a number of issues, but primarily that the motor is overheating or a higher-than-usual motor current caused by other issues. Typically, an experienced technician would remove the belt to check the motor and motor pulley to ensure all is in working order first. Their next step would be to check the tub pulley and tub bearings. Last items they would examine would be the drive motor and speed control board by ohm measurement. Once the tech has ruled out a number of possibilities, he or she can pinpoint the exact problem and the necessary part to fix the issue. Since parts can often be quite costly, I would personally recommend reaching out to a qualified tech who can accurately diagnose the issue your unit is experiencing.
Apr 06, 2014 | Washing Machines
My Bosch Logixx 8 sensitive won't work and shows the code: F:43
Bosch Logix with error code F43 has "a motor fault".
You can reset the error code by the follow steps:
1. Turn the appliance knob to the off or reset position, 12 o'clock.
2. Turn the knob to the 6 o'clock position.
3. Press and hold the spin button and while holding the spin button turn the knob to the 7 o'clock position. Continue holding the spin button for about 5 seconds then release the spin button and now turn the knob to off
When your turn it back on it should have cleared the error code
Check motor connector block
Check wiring
Check motor carbon brushes
Check tacho connections
Check motor
Apr 03, 2014 | Bosch Logixx WFT 2806 Front Load...
My electrolux EWFLS70JSS front load washer is showing a E57 error and is not entering spin cycle.
Hello Walter, thank you for your post!
An error code E57 could mean a number of issues, but primarily that the motor is overheating or a higher-than-usual motor current caused by other issues. Typically, an experienced technician would remove the belt to check the motor and motor pulley to ensure all is in working order first. Their next step would be to check the tub pulley and tub bearings. Last items they would examine would be the drive motor and speed control board by ohm measurement. Once the tech has ruled out a number of possibilities, he or she can pinpoint the exact problem and the necessary part to fix the issue. Since parts can often be quite costly, I would personally recommend reaching out to a qualified tech who can accurately diagnose the issue your washer is experiencing.
Hope this proves helpful!
Jan 16, 2014 | Electrolux EWFLS70JSS Washer
Bosch Logixx WAS2446 Front Load Washer Logo
1,740 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
