Question about HiTi 510S Digital Photo Printer and Breeze Systems Software Bundle
My hiti p720l newly installed tells me Ribbon mismatch erro code 524800
MY NEWLY P720L INSTALL . SAYS RIBBON MISMATCH WITH ERROR CODE 524800
My print outs are having lines across them
You need to have your printer go thru head cleaning cycle. Check to make sure the ink is not leaking from the cartridge. Are you using OEM ink or second hand?
Jun 20, 2014 | HiTi P720L Photo Printer
0205 CINTA INCOMPATIBLE
pls Check the smart chip
Apr 01, 2014 | HiTi P720L Photo Printer
Cam error 01 for hiti 720L
Same problem here!! any tips or fix please :(
Dec 15, 2013 | HiTi 720L Photo Printer P720L
I have Hiti P510S photo printer which was working very well, but now when i issue a print command, it gives me an error message like "PAPER ROLL MISMATCH" even with all consumable well fixed. What do i do?
Double check the ribbon chip and make sure contacts are clean. Also make sure it is for the 4x6 paper size. If it is a 5x7 ribbon it will not work. Have you printed 5x7's before? If so this is probably the issue.
Also check to make sure firmware is up to date. . I hope that helps!
Oct 23, 2013 | Hi-Touch Imaging Hi Touch Imaging...
HiTi 510S Digital Photo Printer and Breeze Systems Software Bundle Logo
166 people viewed this question
Top HiTi Office Equipment & Supplies Experts
Emmanuel Sackitey
Cara Lee
Cara Lee
Level 1 Expert
Chas Peters
Level 1 Expert
Are you a HiTi Office Equipment and Supply Expert? Answer questions, earn points and help others
