Inverter inverter no feedback and excess heat
    Top Expert:
  • Computers & ... Master
  • 22,161 Answers
Please explain your problem
Posted on Nov 20, 2013
When inverted temperature light is on what could the problem
over heating
excess current draw , above recommended rated draw
Mar 10, 2016 | Electronics - Others
Ow do i fix error 59
If you are talking about error code 59 then the error is E.HybC.
E.HybC means that the feedback card on the inverter has been changed.
You must confirm the change at parameter ec.0 or ec.10. The inverter reads the value from the feedback card so all you have to do it hit enter to confirm the value.
If you have not changed the feedback card but the error continues to come back then there is a problem with the feedback card or the control card.
Aug 20, 2014 | Inverter KEB COMBIVERT F5
What is error E5 on pioneer mini split air conditioner?
E5 indicates excessive temp. of the outside coil if on cooling, OR excessive temp of the inside coil in.
Try cleaning it (them if inside one too), with dishwashing liquid and spray outside hose.
Jun 03, 2014 | Pioneer Ductless Mini Split INVERTER Air...
What is cable breakage at the resolver or incremental encoder
It means that the signals between the inverter and feedback device are being lost. This is due to a cable breakage, defective encoder/resolver, or loose connection, possible defective feedback card.
Feb 24, 2014 | Inverter KEB COMBIVERT F5
How can we fixed if the error display is E.EnC1
There is a problem with the channel 1 feedback loop.
Possible causes:
Loose connection at encoder or feedback card.
Defective feedback cable.
Defective encoder.
Defective feedback card.
Defective control card.
Defective inverter.
Pctv does not show anything on tv except colored lines
This may be caused by the inverter board found behind the LCD panel. You need to re-solder the two sides of the coil found on the inverter board.
There seems to be loose connections on the solder probably caused by heat..
Please send us your feedback & vote to help us help you as it should be.
Feb 11, 2010 | KWorld PCTV CONVERTER KW-PCTV-1600 RT...
My lcd screen on my new msi cx700 keeps flickering and going black. if i press the top corners of the screen bezel the screen returns to normal.Could this be a bad screen, backlight, inverter, something...
This may be due to the inverter board found behind your lcd panel.
Take it apart & solder the two sides of the coil found on the inverter board. This loose solder is caused by heat.
Please send me your feedback & vote to motivate us & to help us help you.
Feb 11, 2010 | MSI CX700-020US INTEL R4330 T4200 SYST2.0G...
WHAT IS ERROR CODE F96 ON A PANASONIC INVERTER AIR CONDITIONER - MODEL CS-E28HKR ?
F-96. Over heating protection. to solve it-------Check for • Excess refrigerant
• Improper heat radiation
• IPM (Power transistor)
Nov 21, 2009 | Toyotomi TID-1800HP Air Conditioner
H97 error code and excessive heat
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here. If you're not in the US, see Panasonic.net.
Sep 12, 2009 | Panasonic Microwave Ovens
Service code EC?
CODE INDICATION
05 Refrig. Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
06 Refrig. Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
07 Freezer Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
08 Freezer Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
20 Defrost Under-heat with No Voltage Feedback Through Gray/White Wire at Defrost Start
21 Defrost Overheat
22 No Voltage Feedback Through Gray/White Wire at Defrost Start
23 Defrost Overheat with No Voltage Feedback through Gray/White Wire at Defrost Start
24 Defrost Under-heat
30 Excessive Icemaker Water Valve Solenoid Activation (Exceeded 15 Seconds)
40 Excessive Freezer Compressor Run
50 Excessive Refrigerator Compressor Run
Jan 21, 2008 | Sub-Zero 632 / S
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
