Zenith TV I have a Zenith 27" color TV made in 1989, model #SF5765H. Recently, the picture started to shrink and expand from the sides of the screen. It is intermittent, but happens often. Can it be fixed without too much cost, or should I buy a new one?
Buy a new one its had a good life
Posted on Oct 08, 2007
SOURCE:
When I turn my TV on, I have sound but only a horizontal white/color line across the screen. My TV is an old Zenith 25" floor model.
You can buy a new one for less than 200 bucks. I'd advise you do this. It sounds like you need a new
picture tube
Dec 31, 2010 | Zenith C27A24T 27" TV
Regular picture size shrinks and color fades
This is a common problem on certain models of Philips Magnavox TV sets. The most common symptom is the screen will shrink and expand over and over. After the TV heats up for a while the video will work like normal. After a few weeks or months your TV will eventually stop working and not have video. You can get complete parts and instructions from www.TvRepairKits.com
Jan 01, 2010 | Philips Magnavox 9P6034C 60" Rear...
Picuture shrinking color fading
I have the same Tv.. Repair tech said it was the deflection board. Cost $395.00 to repair.
Feb 28, 2009 | Philips Magnavox 9P6034C 60" Rear...
How to adjust picture on projection TV
It should have in the menu ,under settings ,, convergenge,, it realines the colors,, ,,
Oct 03, 2008 | Philips 60P8341 60" Rear Projection...
Old zenith 36"
Bad CRT (the picture tube) they fail on the many of the zenith sets.
Jul 26, 2008 | Zenith C27A24T 27" TV
Screen is cutting off the sides
That is an ITC008 chassis and the problem you're referring to is called a breathing picture. One fault I am aware of in this chassis/model is the connector Bl103. I have seen a couple where the connector failed and had to be replaced. Could open it up and locate the conntector and see if it's vibration sensitive.
Bill
Apr 26, 2008 | RCA 32V550T 32" TV
Zenith console tv model sentry 2 27 inch
Resolder the vertical deflection section. Change pump up capacitor if it has one...100uf is a typical value. Is the vertical output some flavor of LA783x ?? May need to replace. A model # would help.
Nov 04, 2007 | Televison & Video
Vertical/horizontal
Since you can bang it to heal it some, try checking for cold solder joints. Caps and IC's next. Careful TV's store up to 3000 K volts unplugged. Enuff to kill.
Sep 10, 2007 | Televison & Video
Shrinked picture of 29 inch television.
It is a pincushion problem. There is a bad cap and or a bad diode in the horzontal section.
Oct 29, 2006 | Toshiba 27A51 27" TV
Televison & Video Logo
110 people viewed this question
Top Televison & Video Experts
Ekse
