Question about Texas Instruments TI-83 Plus Calculator
How do you find the degree from tan
If you want to know what degree value is associated with e.g. a tan value
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
To calculate the arctangent, use 2ND TAN. For example, to calculate the arctangent of 1, press 2ND TAN 1 ENTER
Posted on Jun 08, 2014
2 Suggested Answers
Typus
  • 69 Answers
SOURCE: Trig Functions and Angles
What is wrong? Are you not getting the right answers? If so, your calculator is set on radian, not degree.
Posted on May 13, 2009
Use the identity tan(x/2)=sinx/1+cosx to solve for the value of tan45 degrees
tan(x/2)=sin(x)/(1+cos(x))
Setting x/2=45, means that x=90 (degrees)
But cos(90)=0 and sin(90)=1. Thus tan(45)=1/(1+0)=1.
Mar 13, 2013 | SoftMath Algebrator - Algebra Homework...
How do i change the setting to degree?
Press [2nd][MODE] to enter the default setup screen. On the third line Radian, Degree, highlight degree and press ENTER. From then on, angle values will be interpreted as degree values.
Feb 26, 2012 | Texas Instruments TI-86 Calculator
Sharp el-501w figure degree on rise run seven inch rise tweve inch run = ? degree
If you have learned about the trigonometric ratios (sine, cosine and tangent) you can use the tangent of the angle.
Let your run be to the right ( along the positive x-axis) and the rise be upwards along the positive y-axis. The tangent of the angle is
tan (theta)=rise/run=7.5/12
If the calculator is set with angle unit in degrees, the angle is obtained as the arc tangent of the (rise/run) value.
theta= arctan(7.5/12)=32.00538321 or about 32 degrees.
The arctan is the inverse of tan. To access it on the calculator press [2nd F][tan]
Depending on the calculator (sorry I do not have your model under my eyes)
Press [2nd F][tan] ( 7.5/12) [=]
or
7.5/12 = then [2nd F][tan] [ALPHA][Ans] [=]
Jan 21, 2012 | Sharp Office Equipment & Supplies
How do you compute this using scientific calculator log tan 36 degrees 20 minutes?
You may want to insist on using the DMS (degree, minute, second) notation but since 20 minutes is 1/3 of a degree the value of the argument of the tangent function is just 36 and 1/3.
Make sure the angle unit is set to degree.
Set the calculator IO mode to MathIO: Press [SHIFT][MODE ][ : Degree]
Press the[ log] button: log(
Press the [ tan] function key tan (
You see on the screen log ( tan (
Type in 36 [a b/c] 1 [a b/c] 3
Close the two parentheses ))
Press [EXE]
You should get -0.13344355615
Aug 15, 2011 | Casio FX-115ES Scientific Calculator
Sin cos tan
To use these functions press the sin, cos, or tan button followed by the angle you are looking for the value for if in degree mode or the radian value your are looking for if in radian mode.
May 12, 2011 | Casio FX-260 Calculator
How do I find the tan of an angle and given the tan value, how do I find the angle
To find the tangent of an angle:
  1. input TAN (it's up one and left one from the division key)
  2. then the desired angle
  3. then a close parenthesis
  4. And then hit ENTER
To find the inverse tangent:
  1. Press 2nd
  2. Press TAN (TAN-1)
  3. Enter the desired tangent value
  4. close parenthesis
  5. hit enter
this will give you the angle that yields that tangent value.
You might have to switch your calculator from radian to degrees or from degrees to radians to get the expected result. To do that:
  1. Press MODE
  2. Scroll down to where it says ANGLE
  3. change it from either RAD or DEG
Good luck
Mar 01, 2011 | Texas Instruments TI-83 Plus Calculator
How do i use the tan option to figure out an angle when I have the Tan D amount
use the arctan function - arctan gets you back to the angle, tan gets you the value of opp/adjacent remember you note if you want radians or degrees
Jan 29, 2011 | Texas Instruments TI-83 Plus Calculator
How to solve tan(52)=X / 18?
There is nothing special about the equation. tan(52) is just another number.
Isolate the unknown to get
X=18*tan(52)
I assume that the angle value is in degrees. To set it, press MODE 0 to use the usual computational mode, then set angle unit to degrees by pressing MODE 4.
Once this is done, type in
52 TAN * 18 =
Mar 23, 2010 | Casio FX-260 Calculator
I have a SHARP EL-501W calculator and i am getting the wrong answers with the tan -1 function
The source of errors is most certainly due to the wrong schoice of angle unit (degree or radian). If the default angle unit set in your calculator is the degree, any value fed to the trigonometric functions (sin, cos, tan) is considered to be expressed in degrees. Consequently, if you calculate the arctangent ( tan^-1) of a value, the angle returend by that inverse trigonometric function is expressed implicitly in degrees.
Similarly if radian is the default angle unit in your calculator, any angle returned by an inverse trigonometric function (arcos, arcsin, arctan) is in radian.
Set the default angle unit as the one required by your problem at hand. This way, the angles returned will be in the right unit and you will not have a problem of interpretation.
Hope it helps.
Dec 07, 2009 | Sharp EL-501WBBL Calculator
Need to know how to obtain the cot,csc, and see in the degree mode and radian mode
There are no dedicated keys for these trigonometric functions, for the simple reason that they can be obtained from the tan, sin, and cos by a simple division.
cotangent (x) =1/tan(x) . Do not confuse with the arc tangent tan^(-1)
cosecant (x) = 1/sin(x) . Do not confuse with the arcsine sin^(-1)
secant(x) =1/cos(x) Do not confuse with the arccosine cos^(-10)
If you know how to use the tan, cos, and sin, with angle unit in degrees or radians, then there will not be any problem
If angle unit is degree, any number you give a trigonometric function is interpreted as degree. For instance if mode is in degree , and you calculate cos(PI) do not expect the value -1. You will have the value corresponding to the cosine of of 3.14159 degrees, namely 0.99849715
Now for you if you are interested.
If [MODE] is in degrees you can still enter angles in radians
You use the [2nd][ANGLE] [3: raised r] [ENTeR].
Here is a screen capture to show you more clearly.
The raised r is obtained by [2nd][ANGLE][3: raised r] [ENTER]
Hope it helps.
Oct 13, 2009 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
55 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
