Question about HP ProLiant ML350 G6
How can i update the Bios of ML350 G6 and what is the update link ?
Error Message "Boot Logical Drive is Missing OR Offline"
    Sergeant:
  • 249 Answers
Download bios from hp wesite and update
Posted on Nov 26, 2013
4 Suggested Answers
alpug
  • 1961 Answers
SOURCE: I just plugged in a
make sure you select the jumper on the hard disk into a slave setting and the hard disk is formatted into windows format.check the jumper settings first and post back for further suggestion.
Posted on May 19, 2011
  • 181 Answers
SOURCE: logical drive has been disabled due to possible data loss
Replace the HDD whose led is blinking in AMBER ( orange ) colour.
Posted on Mar 30, 2012
Ntldr is missing press ctlr+alt+ and delete to restar and i did and don't workz
First I have to assume that you are running Windows XP. This solution should work for other versions of Windows.
The "NTLDR is missing" error displays very shortly after the computer is first started, immediately after the Power On Self Test (POST) is complete. Windows XP has only initially begun to load when the NTLDR error message appears.
Causes of NTLDR Errors
There are a number of possible causes for NTLDR errors, including the most common "NTLDR is missing" error message.
The most common reason for this error is when your PC is trying to boot from a hard drive or flash drive that is not properly configured to be booted from; in other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
Other possible causes include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
How to Fix NTLDR Errors
1.Restart the PC. The NTLDR error could be a fluke.
2.Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive with Windows installed is listed first.
3.Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
Note: There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
4. Restore the NTLDR and ntdetect.com files from the Windows XP CD. Restoring these two important system files from the original Windows XP CD may do the trick.
5. Repair or replace the boot.ini file. This will prevent the NTLDR error if the cause of the problem is a boot.ini file that is not configured properly for your Windows XP installation.
6. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the "NTLDR is Missing" error.
7. Repair the Windows XP master boot record. NTLDR error messages may also appear if the master boot record is corrupt.
8. Reseat all internal data and power cables. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
Try replacing the IDE cable cable if you suspect it might be faulty.
9. Update your motherboard's BIOS. Occasionally, an outdated BIOS version can cause the "NTLDR is Missing" error.
10. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
11. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch. While this will almost certainly resolve any NTLDR errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
12. Replace the hard drive and then perform a new installation of Windows XP. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
NTLDR Errors Apply To
This issue applies to the Windows XP operating system, including Windows XP Professional and Windows XP Home Edition.
Windows 8, Windows 7, and Windows Vista utilize BOOTMGR, not NTLDR.
Still Having NTLDR Issues?
See Get More Help for information about contacting me on social networks or via email, posting on tech support forums, and more. Be sure to let me know what steps, if any, you've already taken to fix the "NTLDR is missing" issue.
Jan 29, 2014 | Microsoft Windows XP Professional
My windows XP has an error message when started. It says "MISSING NTLDR, PRESS CTRL, ALT, DEL TO RESTART" I tried restart with boot disk but nothing. Please help!?
  1. Restart the PC. The NTLDR error could be a fluke.
  2. Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
  3. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
Jan 22, 2014 | Belkin Basic Wireless Router
My server cant boot after a fresh intall
Reshuffling disks will disturb the Logical drive .Recreate RAID Install OS , Set the Boot controller order in system bios Pressing F10key
Jul 25, 2012 | HP Compaq ProLiant ML350 G3 Server
Proliant does not boot from raid controller if external SCSI drive is powered on.
Try to disable boot to other device on your bios setting.
Make sure that your Smart Raid is set on the first boot device.
Nov 01, 2011 | HP Compaq ProLiant ML350 G3 Server
A boot message "SCSI bios
Disable the SCSI controller in the BIOS.
Aug 30, 2011 | HP Compaq ProLiant ML350 G3 Server
I have a proliant ml350 g3 rack mounted server that is in a constant reboot loop. It once gave a blue screen of death with the error message of NME Parity error, so I took out all but one RAM stick and...
Put RAM's in Identical form and check.
clear NVRAM and Check.
check the array controller
update BIOS and Array controller firmware ( disconnect HDD's from the cage before
updating the latest Firmware( download from hp.com/support and drivers )
May 27, 2011 | HP Compaq ProLiant ML350 G3 Server
I have ML350 G3 Server SA 532 and 2 HDD SCSI, W2K. I want intall RAID 1 Can I help me???
unable to understand your question.
If you want to configure raid 1 and install OS freshly then follow these steps.
1) make ready all the required h/w.
2) Swith on the server.
3) when post starts reading SA532 controller press F8 button .
4) you will enter into Raid card bios.
5) select View to know any existing logical drive.
6) select Create logical drive,select both hdd's by pressing space bar.
7) press F8 to confirm changes,save and exit.
8) Enter into bios and set the boot controller order smart array controller as 1st.
9) press escape button and restart the server.
10) boot with cdrom and proceed for os installation.
6)
Jan 19, 2011 | HP Compaq ProLiant ML350 G3 Server
1962 operating system not found
Check the computer BIOS to see if the HDD is being detected correctly
Check the computer's BIOS for the Boot sequence (the order in which The BIOS seek a device with a Bootable operation System). Verify that the HDD is on the list.
Boot you comuter with a Floppy containing MSDOS Boot Strap (just go to a computer with a win9x system and do
Code: format a:/u/s and see if you can access you HDD and see the Files on the first partition:
Code:
a:\>c:
c:\>dir This will tell you there is Valid Partition on the HDD.
I will be lurking here for your response,
Gabriel __________________
Real stupidity beats Artifical Intelligence
Avatar courtesy of A D E P T user_offline.gif quote.gif Gabriel View Public Profile Visit Gabriel's homepage! Find More Posts by Gabriel post_old.gif October 18th, 2004, 06:17 PM #3 Beonarri vbmenu_register("postmenu_540105", true); Registered User
Join Date: Oct 2004 Location: Detroit Posts: 18 My computer is back up and running! smile.gif smile.gif smile.gif
I looked around the net for some information on the error and it turns out a simple Boot Disk fix is all it needed.
Thanks for you help anyways, Gab!!
Here's the link for the info:
http://www.cybertechhelp.com/forums/...highlight=1962
It's the forth poster.
Mar 09, 2009 | IBM xSeries 226 Server
Computers & Internet Logo
510 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
