Question about WYSE Winterm S30 Network Terminal
Uncontrolled scrolling in excel
Within a published excel application in a Citrix environment, users of our S30's are experiencing uncontrolled scrolling in excel. For example, when someone attempts to select roughly one page of cells to copy, format, whatever, when the mouse is dragged over the area to select, the selection process "runs wild" and selects everything within the document (no matter how long) and cannot be stopped. Initial thoughts were a problem with the mouse or keyboard. I've swapped both out and still have issues. Any thoughts?
Good morning, we just had the same problem.
The only thing that fixed it was to re-flash the units with the most current version of windows CE. As soon as we did that, the scrolling issue - and a lot of other annoying bugs - went away.
Good luck
Posted on Dec 08, 2007
    Problem Solver:
  • 12 Answers
You System has been attacked by a virus or bug try scanning your PC in safe mode with the latest dat file of MC afee or trend micro. I have faced a similar problem recently and and have got rid of it this way only. Good Luck
Posted on Oct 10, 2007
SOURCE:
SAP with Ncomputing, its works?
It should work fine. As long as the SAP client is 'multi-user' aware then you're good to go. One 'acid test' is to see if the SAP client will work on a Terminal Server or a Citrix Presentation server and in this case it does. The NComputing solution, conceptually at the application layer, behaves much like TS or Citrix, thus looking for those solutions is what you'll need to know for NComputing. Here is the website I found about how to setup specific INI files for Citrix to get the SAP client working. My recommendation would be to test as is out of the box with two NComputing seats, simultaneously. If that fails, then try the suggestions on this website: http://community.citrix.com/display/adi/SAP+GUI+7.10+on+Citrix+Presentation+Server.
Aug 16, 2011 | NComputing L230 Network Terminal
I am using microsoft excel 2007, the code is not running, the macro was disabled.. How to enable the macro...?
From the excel help file
  1. Click the Microsoft Office Button o12filemenubutton_za10077102.gif, and then click Excel Options.
  2. Click Trust Center, click Trust Center Settings, and then click Macro Settings.
  3. Click the options that you want:
    • Disable all macros without notification Click this option if you don't trust macros. All macros in documents and security alerts about macros are disabled. If there are documents with unsigned macros that you do trust, you can put those documents into a trusted location. Documents in trusted locations are allowed to run without being checked by the Trust Center security system.
    • Disable all macros with notification This is the default setting. Click this option if you want macros to be disabled, but you want to get security alerts if there are macros present. This way, you can choose when to enable those macros on a case by case basis.
    • Disable all macros except digitally signed macros This setting is the same as the Disable all macros with notification option, except that if the macro is digitally signed by a trusted publisher, the macro can run if you have already trusted the publisher. If you have not trusted the publisher, you are notified. That way, you can choose to enable those signed macros or trust the publisher. All unsigned macros are disabled without notification.
    • Enable all macros (not recommended, potentially dangerous code can run) Click this option to allow all macros to run. This setting makes your computer vulnerable to potentially malicious code and is not recommended.
    • Trust access to the VBA project object model This setting is for developers and is used to deliberately lock out or allow programmatic access to the VBA object model from any Automation client. In other words, it provides a security option for code that is written to automate an Office program and programmatically manipulate the Microsoft Visual Basic for Applications (VBA) environment and object model. This is a per user and per application setting, and denies access by default. This security option makes it more difficult for unauthorized programs to build "self-replicating" code that can harm end-user systems. For any Automation client to be able to access the VBA object model programmatically, the user running the code must explicitly grant access. To turn on access, select the check box.
Jun 21, 2011 | Microsoft Office Professional 2007 Full...
CITRIX not working with my cable modem. Connecting via laptop using the modem's wireless connection. i am able to connect to CITRIX just fine from the office, and from other internet connections.
Are you talking about published apps not working? If so, make sure that your cable modem has the following ports open:
TCP 1494 and 2598
These ports are used by the ICA protocol, which is what Citrix Presentation / XenApp Server software uses for running published apps.
Nov 12, 2009 | Arris SURFboard SBG900 (49402201900) Modem
Connection reset by peer
is this a citrix environment? have you just applied a rollup pack to your terminals?
You need to speak to Wyse!
Apr 27, 2009 | WYSE S10 (90210501) Network Terminal
Lexmark Z645 can print locally, but will not print off of citrix
Lexmark X and Z series printers do not function in a Citrix environment, see page 4 on the following document.
ftp://ftp.lexmark-europe.com/brochures/de/solutions/citrix_basic.pdf
Apr 13, 2009 | Lexmark Z645 InkJet Photo Printer
Uncontrolled scrolling within excel app
Try pushing in on the scrolling ball on the mouse.
I just had the same issue and that's what I did and it quit.
Hope this helps!
Sep 11, 2007 | WYSE Winterm S30 Network Terminal
S30 Display Problems
In almost all cases of my dealing with Thin Clients over a 10/100bps network all problems usually are within the Terminal Servers hosting the Thin Clients. BPCS
May 01, 2007 | WYSE Winterm S30 Network Terminal
Citrix ICA CE Client
The CE Citrix ICA Client can be downloaded from Citrix.com * From the "Citrix Downloads" section scroll down until you see "Recommended Client Chart". * Look for "Windows CE" on the chart. * Click on "ICA CE Client" to download.
Sep 14, 2005 | NEC MobilePro 750
WYSE Winterm S30 Network Terminal Logo
272 people viewed this question
Top WYSE Computers & Internet Experts
Ekse
Archie Ferrarini
Archie Ferrarini
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
