Question about Artemide Tolomeo Classic Wall Lamp
Artemide tolomeo wall - Artemide Tolomeo Classic Wall Lamp
Shower walls
You have got a lot of moisture behind your wall covering. Is that a plastic or fiberglass shower wall liner? You are going to have to tear out the shower walls, clean the studs, replace insulation and put in new walls. You must stop the leak too! You could be growing a lot of mold in the cavity behind your wall.
Jul 06, 2013 | Tools & Hardware - Others
Hole in kitchen wall. How do I fix it?
First I would cut around the hole using a dry wall knife -I would make it a square. Then get a piece of wood ( 2" high and Then measure the length of the hole if it is 9" then you would need the wood piece to be 11" long.) Insert the wood piece inside the wall (hold on to it) and then drill using dry wall screws from the out side wall into the wood piece you installed. Then cut a piece of dry wall the size of the square you made and insert into the wall then screw into wood piece. Then take some joint compound and spread light over insert dry wall spreading on the old dry wall and let dry and then sand so it is flush with wall.
Apr 18, 2013 | Tools & Hardware - Others
The holder has fallen off the wall. There appears to be two screws, one that fits into the back of the centre of the wall plate and a small one that fits into the side of the wall plate. I don't think...
Hello Alicia
Most often the wall plate will screw to the wall and then there is a set screw (usually an allen key) to tighten the fixture onto the wall plate. If it is the wall plate that won't stay on the wall then your screw holes are probably stripped. An easy way to fix this is to fill the hole with a wood glue filler available at your local hardware store. Use toothpicks to jam the filler into the hole. You can also use white wood glue and jam glue and toothpicks into the hole. Let it dry overnight and the next day you will be able to screw the plate back onto the wall. If the fixture is falling off the wall plate then the set screw is not being tightened hard enough against the plate to hold it onto the wall. Good luck with the repair.
Jul 17, 2010 | Sonia GENOA COLLECTION TOILET ROLL HOLDER...
How do I post on my wall so all my friends can see it?
use wall to wall posting you may have to upgrade your current wall and invite as many friends as you can to upgrade to wall to wall posting
Oct 13, 2009 | Computers & Internet
Artemide Tolomeo Classic Wall Lamp Logo
20 people viewed this question
Top Artemide Home Experts
Donni Steen
Tom Chichester
Are you an Artemide Home Expert? Answer questions, earn points and help others
