Question about Bosch Vacuums
My Bosch Athlet vacuum cleaner doesnt charges. Its new, it fully charged all night. I used it for 2 days. Then doesnt want to charges anymore, please help.
SOURCE: help
Same thing happened to me, I called the company, and they told me to remove the battery, press the on button for 5 seconds, which clears the system, replace the battery and do a long charge 12 hours. I'm in the process of doing that now.
Posted on Apr 25, 2008
GoVacuum1
  • 6 Answers
SOURCE: Bosch Vacuum Cleaner: I changed
Greetings from GoVacuum.com,
It sounds like you may have a bad thermal switch inside the machine. Most vacuum cleaners have a switch connected to the motor, so if the vacuum cleaner is running hot, it will shut off to prevent any damage to your motor. You did all the right things by checking the bag, making sure the hose was NOT clogged, and replacing HEPA filter.
Most of the time on canister vacuums, the reason is caused by a clog in the hose, or somewhere in the powerhead. If you're sure that there is no clog anywhere, it is going to be the thermal switch on the motor.
Here's a link to the parts schematic for the Bosch upright vacuum. I hope it helps you in determining how to access the thermal switch. A word of warning to you before you try it, this is a very tough vacuum cleaner to work on, you may want to bring it in to a vacuum repair shop, as this is not an easy repair.
Here's the link;
http://www.essco.net/Customer/SchematicFrame.asp?FileName=Turbo%20jet%20upright.pdf
Please let me know if you have any other questions,
Chris Jones
GoVacuum.com
1-866-468-2288
chris.jones@govacuum.com
Posted on Aug 18, 2008
  • 5 Answers
SOURCE: my dc 16 rechargeable vacuum won't work
far as i know the dyson dc 16 root 6 vacuum uses a lithium ion battery with a charge of 21.6 volts. it could be that either your battery isnt storing the right amount of power anymore and you may need to replace it. check on the specifications to confirm how much volts the battery is supposed to have. too little volts may be enough for things like lights to switch on, but not enough for the motor to start up.
Posted on Oct 29, 2009
Testimonial: "Thanks for that, It does look like the battery is shot. "
  • 52 Answers
SOURCE: I have a two Rumba Vacuum cleaners that will not
It is odd that you have two Roombas that don't hold a charge. A Roomba battery
Posted on Jun 12, 2010
  • 14 Answers
SOURCE: fully charged, filters cleaned, vacuum keeps
Your battery is losing voltage too quick. It has probably developed a 'memory'. Dyson claims that their handheld has the best suction out of all the handhelds out there. In order to maintain that claim the circuit board will shut off power to the motor when the voltage drops below adequate charge for full suction.
We need someone who can teach us to bypass that part of the circuit so it won't cut power to the motor or you need to get a new battery.
Shorting the battery like an Aircraft battery then re-charging won't fix it.
Posted on Nov 11, 2011
I have a stick dyson DC35. It runs out of power after being fully charged. I have cleaned filter and cleaned all parts numerous times, but still have the problem.
The battery may only be capable of partially charging but indicates it is fully charged, something like 100% of 50%. It may be time for replacement.
May 02, 2016 | Dyson DC35 Digital Slim Stick Broom/Hand...
Light blinks when i pull trigger
Hi Philip, it's Jack at Dyson.
If you've recently replaced the battery and ensured it's fully charged, and you're still noticing a flashing indicator light, there may be a fault with the main body assembly.
We'd like to take some further details to confirm if this is the case. If a replacement part is required, we can also check whether this is covered under your vacuum's 2-year warranty.
You can reach our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). Please have your machine to hand when you call so we can run you though some quick diagnostic checks.
Feb 26, 2014 | Dyson DC44 Animal Digital Slim Cordless...
I just bought a Dyson DC35 cordless vacuum cleaner, and the charger does not light up, nor does it seem to be charging the vacuum cleaner
Hi Jeff, it's Jack at Dyson.
DC35 should charge completely within 3.5 hours, and when fully charged the light on the charger will go out. If the battery doesn't seem to be taking in any power, we'd appreciate the opportunity to take you through some quick diagnostic checks when you have your machine to hand. If a replacement part is needed, our experts will also be happy to confirm if this is covered under your machine's 2-year warranty.
You can reach the Dyson customer Helpline by calling 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Dec 31, 2013 | Dyson DC35 Handheld Vacuum
Brand new : battery charges to 60 minutes ( 8 hours)and by the next day is completely discharged.
It sounds like the battery has a faulty cell in the battery that never lets it hold a full charge or lets it bleed off. I would take it back and exchange it.
Could you provide a model number?? There may be some settings on the vacume that are continuing to use power even though it is not in use.
Thanks
Apr 11, 2010 | Vacuums
I can't get replacement bags for my Bosch Premium 1300 W vacuum cleaner.
Greetings from GoVacuum,
Your Bosch Premium canister vacuum cleaner uses Bosch Style P Bags.
We carry 2 different types of Bosch Type G bags for your vacuum cleaner.
We have the genuine Bosch Bags Available for Purchase Here;
Bosch Type P MEGAfilt™ Super TEX Vacuum Cleaner Bags
And also in bulk buy here;
3 Pack Bundle Pack of Bosch Style P Vacuum Cleaner Bags Part #BBZ52AFP2U
And we also carry a generic paper style bag that doesn't filter as well as the cloth Bosch genuine bags, but is suitable if you don't have any breathing issues or allergies in your home. Here are the Bosch generic P bags;
Bosch Type "P" Canister Vacuum Bags Generic
I hope that this information was helpful to you. If this helped you, please be sure to rate this as helpful by clicking the 4 Thumbs Up Icons in the top right hand corner of my answer.
Feel free to email me at chris.jones@govacuum.com if you have any questions or need further help with your Bosch canister vacuum.
Thank you so much,
Chris Jones
GoVacuum.com
Feb 22, 2010 | Bosch BSG81313UC Premium Bagged Canister...
Will not turn on. Fully charged.
SOUNDS LIKE THE BATTERY IS SHOT AND WON'T TAKE A CHARGE.DOES THE CHARGER PLUG DIRECTLY INTO THE VACUUM.IF SO SEE IF IT COMES ON WITH THE CHARGER PLUGGED INTO IT.IF IT COMES ON THEN THE BATTERY IS NO GOOD.PLEASE LEAVE FEEDBACK
Mar 26, 2009 | Euro-Pro Shark Cordless Stick Vacuum...
Vacuums Logo
4,378 people viewed this question
Top Bosch Vacuums Experts
Billy Detlefsen
ray gallant
JoeVacs
Are you a Bosch Vacuum Expert? Answer questions, earn points and help others
