Question about Cisco Re1000 Linksys Wireless And Range Extender
Cisco RE1000 extender power
My RE1000 extender has no power. It has worked for a year always connected. Does it have a fuse that can be replaced?
  • Cisco Master
  • 10,291 Answers
If you have access to a voltmeter check to see of there is any voltage on the power supply cord.
Posted on Jan 15, 2014
We added a smart tv and I keep getting a message to "log in to area "RE1000" on 192.168.1.1:80
RE1000 is the range expander on a router. If you don't remember the login and password for that router, you can reset it.
Aug 23, 2015 | Computers & Internet
HOw to replace the power fuse in a OCOSMO LED TV
There is no replaceable fuse.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Aug 27, 2014 | Televison & Video
Clock resets every time key is turned off
My wife had this problem years ago on her car.
There's a wire that's always "HOT" (live, if key is on or not) that keeps the clock powered.
Check the fuse.
Jul 22, 2013 | 2006 GMC Canyon Extended
Need manual for RE1000 treadmill
please download from the website www.manualslib.com
God bless you
Dec 15, 2012 | Exercise & Fitness
I am having problems extending wifi range
Things That Affect Wireless Router Signals
1. Many wireless routers are using the same wireless channel. Many manufacturers choose channel 6 as the default. Change to another channel. 2. Analogue video senders used to send audio and video to other TVs in the home. 3. Microwave ovens emit interference in the 2.4GHz band. 4. Wireless speakers and console controllers can cause interference with the wireless router. 5. Bluetooth devices, newer Bluetooth devices can jump to different frequencies if there is a connection problem. 6. Power cables located near the wireless router can cause dropouts and speed reduction. 7. Fish tanks will cause massive Wi-Fi shadow on the other side of the tank from the wireless router. 8. Depending upon the location of large mirrors will reflect wireless signal away your computer. 9. Building materials will block wireless signals such as plasterboards with metal foil, reinforced concrete walls and floors. Also objects near the wireless router such as metal filing cabinets and other electrical appliances. 10. Blinking Christmas lights can reduce Wi-Fi performance by 25% when it is close to the wireless router.
Sep 16, 2012 | Cisco Re1000 Linksys Wireless And Range...
Cisco 876 doesn't work at all
The power adapter maybe faulty. Test the voltage on the plug that connects to the router with a multimeter, the voltage should be slightly higher than the voltage that is printed on the label on the adapter.
If the voltage is low or zero then the adapter needs to be replaced.
May 19, 2012 | Cisco 876 ADSLoISDN Sec Router
My dma2200 has stopped working, Will not connect with any system either wireless or wired. In fact both of my units have frozen. Cant get past start up scholl screen.
You aren't the only one with this new problem. No one knows for sure what is going on, but most think the extenders are phoning home to Cisco and Cisco isn't answering. You are going to need to change your router services to block HTTP for the extender's static IP address or change the DNS server for the extender to 0.0.0.0. You'll need to give the extender a static IP address in your router if you do the first solution. More information is here http://thegreenbutton.com/forums/t/95097.aspx?PageIndex=1
Nov 07, 2010 | Linksys DMA 2200 Media Center Extender...
I have 2 extenders - both are doing this: when I reset them they go through the setup and tart to communicate with the PC then they freeze up and the screen goes blank. When I go to the PC it sees them but...
This problem has affected many Linksys DMA extender owners in the US and Australia since 4 November; European users are unaffected.
Cisco (owners of Linksys) took an update server offline which the Linksys tries to communicate with; when it can't reach it, it fails to startup correctly.
The solution is to block the Linksys from accessing the Internet, at least until Cisco get the server back online -- apparently they are working on this and it should be fixed soon.
There are a lot more details in this discussion thread on The Green Button and I've also written a blog entry with more details.
Nov 06, 2010 | Linksys DMA 2100 Media Center Extender...
Cisco Re1000 Linksys Wireless And Range Extender Logo
74 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
