Question about Indesit Washing Machines
Water coming out of powder tray
Water looks too high a level in drum , and is coming out of powder tray
  • Indesit Master
  • 17,129 Answers
Either your water level sensor is not working or if you can test this to be in order then the controller unit is not responding to the input from the level controller unit.
check this link: Controller check
Posted on Nov 21, 2013
fanny
  • 146 Answers
SOURCE: Doesn't suck up the soap from the tray while washing
Try to open your water tap to full or check the filter in the inlet valve or hose. There seems to be a problem with the water pressure entering the machine.
Posted on Oct 31, 2007
  • 42 Answers
SOURCE: Water is coming out of the wash powder tray. I had
you need to check all your drain pipes as mine was blocked down into the drain itself
Posted on Nov 21, 2009
barkencoa
  • 3463 Answers
SOURCE: when hotpoint aquarius starts washing cycle, water
It could have over filled, or the drum is turning too fast, or there is a blockage in the dispenser hose. To accessw the hose, remove the top cover, and give the hose a good squeeze to clear any possible blockage.
There is little else it could be, so I am afraid it is a process of elmination.
Good luck.
Posted on Jan 27, 2010
SOURCE: WATER LEAKING FROM POWDER TRAY AND AROUND DOOR
There is a ball return valve that wants cleaning. Disconnect the appliance from water and mains. Turn machine on its side and look underneath. At the bottom of the white plastic drum you should see a black rubber hose about the size of a mug fastened by a hose clip. Remove hose clip and extract the hose from the drum and look inside. You should see a white plastic cone about the size of a paper cup with a plastic ball inside, remove and clean of any debris and replace. Be careful when reattaching the black how to the drum or you will get a flood if not properly attached.
Hopefuly that will solve your problem.
Posted on Jul 12, 2010
Daniel S
  • 4323 Answers
SOURCE: I have an LG WM1814CW.
Hi
If the washer overflows you'll need to check for the water inlet hose, the water inlet valve and the pressure/water level switch assembly. Inspect the inlet hose coming to the washer for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill or is doing what it is doing right now then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the pressure/water level switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Posted on Sep 02, 2011
Water coming out of soap tray and running down the front of the machine
Your soap tray and/or inlet is probably blocked with undissolved powder. Remove the tray and clean it. Also clean the inlet tube from the tray into the washing machine with hot water.
I, personally don't like soap powder and use a liquid or tablets because washers nowadays tend to use cold water only so doesn't fully dissolve the powder. Also the outlet to drain gets blocked along with the underground pipe to the mains sewage.
Sep 25, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Water leaking from the panel under the turn knob
Water comes in the back, then goes via to solenoid valves to the back of the powder tray, it then is distributed through holes above each compartment, take out the powder tray (push down the blue bit at the back of the softener compartment) and check for cracks or even blockages, (water goes from tray down the back and through a short rubber hose straight into the drum.
Feb 11, 2014 | Russell Hobbs RH1042 Frontload Washing...
Should I put powder detergent in the tray or in the drum in my Asko front load washer?
But the powder in the tray. I have a asko washer myself
You should to able to go on line and download your manual
Go to Asko.com Good Luck
Feb 12, 2013 | Asko W6461 Front Load Washer
DebsteveI have a fisher and paykel washing machine, GW709au and it is not rinsing properly. I have reduced the load size and the amount of powder but it still happens. On dark items you can see white...
Hi - it sounds like the water levels not right? - try this out first when washing a load overide the auto sensing to a suitable level pending on the load - High for a full load etc & see how the washing comes out, a lot of times the auto level control will not have as much water in the drum as one would like, so to speak..
Cheers
Jun 27, 2011 | Fisher and Paykel Washing Machines
Hi I own a LG intellowasher WD8013C and the inside of the dispenser needs a good clean due to the built-up of hardened soap powder. Is there a way to unhook this so that i can be cleaned? I suspect this...
Hi from retired Englishman in France,
Absolutely right! If the tray is blocked with a mix of powder and softener the softener will not easily syphon into the drum and water tends to be left in the tray. Some water is not unusual, though.
Very easy to remove. Most trays are stopped from coming out by a catch/lip on the top at the back in the middle. Often, if the middle tray is the softener, it is there.
Just bend down to eye level with the top of the tray and you should see which bit is sticking up. Gently press it down and pull the tray out!
I give ours a good clean every few months as my wife tends to allow some powder to spill into the softener tray- but don't tell her I told you so, please!
Best of luck,
John C
Jan 24, 2011 | Washing Machines
Water leaks from my detergent dispenser from my front loader washing machine?
This is usually indicative of soemthing blocking the flow of water out of the soap tray, down the connecting pipe and in to the drum chamber.
The soap tray doesnt have any seals as water should just flow into the tray, wash out the soap / fabric softner, and then flow out the back of the tray and down the connecting pipe. When working correctly, there is no pressure or water back-up to cause the water to reach the front of the soap tray.
Take out the tray - your machine user manual will show you how, and check both the tray itself and the "hole" it slots in to for either a build up of solidified soap powder, or some other foreign object. If still leaking, remove the tray again and try to get your hand (a woman's or teenager's hand being smaller is best) down the large oulet at the back of the "hole" the tray slots in to to feel for a blockage.
Do you have young children ? A washing machine soap tray is a great place to hide things !
Occasionally, if the smaller pipes that deliver hot and cold water to the tray come adrift, this can spray water at the front of the machine. This water then has only one real way out - via the soap tray "hole". Most often this will be the cold water pipe as this has higher water pressure to cope with. The only way to check this is to take the top of the machine off.
If after all of the above it still leaks, you'll either need to dismantle the machine enough to see the back of the soap tray "hole", connecting pipe and drum chamber for a better look for problems, or call an engineer.
Nov 04, 2009 | Maytag Washing Machines
The machine is leaking water from the soap tray how do i stop this?
Do have young children ? A washing machine soap tray is a great place to hide things !
Sep 30, 2009 | Zanussi FJS1225W Front Load Washer
Apr 27, 2009 | Washing Machines
Water leaking through soap dispenser drawer
OLDFIXER was exactly right ! I had water gushing out of my LIQUID detergent tray. I removed the tray by pushing down on the flexible tab at the back of the tray and when I had the tray out I discovered A LARGE AMOUNT OF DAMP powder detergent caked up on the inside. I removed it all and sprayed some hot water inside AND ITS COMPLETELY FIXED !!! GOD BLESS OLD FIXER.
Apr 27, 2008 | GE WSXH208A Front Load Washer
Won't take Fabric Softener
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
May 31, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
76 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
