Question about Lexerd iRiver S100 TrueVue Crystal Clear MP3 Screen Protector
My Iriver S100 Don't Have DAB/DMB item in main menu
Hi Friends, My Iriver S100 Don't Have DAB/DMB item in main menu. i update device firmware to 1.21 but the problem still exist. please help me
Where can I get the driver and music manager for my IFP-799 ?
iRiver IFP-799 is a IFP-700 series player.
Making transfers to the device can be done in either UMS or Manager mode.
UMS firmware matches with seeing the player as a removable disk in Windows Explorer and is also used for updating firmware, using iRiver PLUS software.
Manager firmware matches with iRiver Music Manager software.
When needing the Music Manager go to next site and enter the word
manager in the second column next to GO:
http://www.iriver.com/flash/index.asp?code=0302
iriver music manager ( Ver. 3.21 ) shows up: click the item and read
the instructions for download and installation.
How to update the player's firmware
in MSC mode:
http://www.iriver.com/flash/popup/flash_pop.asp?board=faq&code=47
in Manager mode:
http://www.iriver.com/flash/popup/flash_pop.asp?board=faq&code=252
Need more help ? Just post a comment.
Dec 25, 2009 | iRiver iFP-799 MP3 Player
My mp3 iriver T5 is not working!!!
Support page for iRiver:
In the second colum enter T5 in the bar next to GO.
All downloads for the T5 will show up.
Check having old firmware for the T5. Then an update has to be made when using Windows Media Player 11 or iRiverPLUS3:
Click the first item, "For users who have old version of T5", saying:
1. Please check your Firmware version first.
(Main Menu ->Setting-> Advanced -> System information)
If firmware version of yours is 1.00, 1.10, 1.20, please upgrade firmware with stupdater...
Download the zip file T5.zip for the upgrade.
Getting Iriver plus 3:
In the left column of the support page select Plus 3.
Next left click Download iriver PLUS3 and save the execute file iplus3.exe .
How to use Windows Media Player 11:
http://www.microsoft.com/windows/windowsmedia/player/11/default.aspx
Dec 04, 2009 | iRiver T5 FM 4 GB black MP3 Player
Nextar ma852-801 mp3 freezing...reset?
Hi.
Welcome To Fixya Community.
Solution 1:
  • Try to Turn it ON/OFF(Reset).
If that isn't Working try This:
Solution 2:
  • You are going to upgrade the Firmware of your Mp3 Player in order to perform that follow these Steps:
  • Installation of the Upgrade Tool:
  1. Download the Upgrade Tool application (the download link is in the bottom of this Solution) to your computer.Double click the application.Follow the instructions shown on the screen to complete the installation.Firmware Upgrade:Note: All the existing files in the player will be erased while upgrading,please make a copy of your files before doing this.Turn on MA852-801 player. Press and hold the MENU button todisplay the main menu. Select “Settings” → “System” →“Upgrade” and press the MENU button to confirm. Select “Yes”and then connect the device to a computer via USB interface once you see the following window:
2. Select ”Program files” 􀃆 ”Firmware Update” from the Start
menu or double click the “Firmware Update” icon on the
desktop. You will see the following window shown on the
screen:
6fc021c.jpg***************************************************************************************
3. Click Open button, and specify the upgrading firmware with
the extension “ .rfw ” (Please download the firmware from
Nextar website named MA852-801 – updated firmware.rfw).
Click Update button to start upgrading.
Note: This process may take about 2 minutes depending on the
computer system you use. Please don’t disconnect while upgrading,
it may cause serious damage to the player.
4. Once it shows "Firmware update successful"wording in
“Update Info” window, then click Exit button to finish
upgrading.
*************************************************************************************(5) 5. Safely remove the player from the PC.
6. Turn on the player. Please wait about 20 seconds for the
player to automatically initialize settings.
Downloads:
Upgrade Tool.
Firmware File.
Additional Help:
Nextar Ma852-801 Mp3 Player Manual Guide.
please don't hesitate asking me if you need any Further Info.
Thank You For Using Fixya.
Good Luck.
Nov 04, 2009 | Audio Players & Recorders
System files missing
I got this from another post:
1) plugged in H10 to pc that didn't have any iriver software on it
a) I've read if you press the "o" button on the iRiver H10 when connecting it will just connect as a usb mass storage device
2) the H10 now appears as a mass storage device
3) right click on the drive, and select format ( I choose quick format)
4) install the iRiverFirmware updater from http://iriveramerica.com/support/mtpupdate/
5) when you run the updater, it found the H10, then asked if the device was from USA or Europe, mine was from Europe
6) It stated that the iRiver firmware was v0.0, and would install v2.51 (I've seen v2.53 available on the european iriver website but could not download it).
7) proceed with installing the updated firmware
8) on the last screen it says, unplug to complete firmware update - NOTE press Finish first before unplugging
9) switching on the iRiver it 'rebooted' a few times and then when the menu appeared, I connected to the pc and just dropped some mp3 files into the music directory and all was okay.
hope this helps.
Also go here for the firmware directly: http://iriverinc.com/support/hd/h10_5-6gb.aspx
Apr 13, 2009 | iRiver H10 MP3 Player
I fixed this problem for my mate, here's what I did:
hope this helps.
Here is for the Iriver H10 software:
Iriver h10
This is straight out of p. 67 of the user's manaul, available on iRiver website (it may not work if the computer does not recognize the device):
Initializing H10
67
Additional information
Firmware upgrade
66
What is firmware ?
It is the operating system that works in the H10.
iriver provides you with the latest and best features through Firmware upgrade.
You can choose manual or automatic upgrade function.
For information on automatic upgrade, refer to the iriver plus instruction manual.
Manual firmware upgrade
Select [Option - Firmware Upgrade] from the menu in iriver plus.
Do not disconnect H10 during firmware upgrade.
Internet must be connected for the "Firmware Update" function.
Change to "Player must be connected to the PC for Firmware Upgrade function.
Note
Please initialize H10 player in the following cases.
All music, pictures, text, and data will be erased from the player during this initialization.
- if there appears to be corruption on the internal hard drive.
- if an error message displays and the player doesn't boot properly.
1 Connect the player and PC using the cable supplied with the player.
Open iriver plus.
Select [Option-Portable Device Initialization]. 2
Click [Start] to begin initializing.
Initializing H10
A
A
B
B
May 30, 2008 | iRiver H10 MP3 Player
System initializing
Initializing H10
67
Firmware upgrade
66
What is firmware ?
Note
Open iriver plus.
Initializing H10
Dec 18, 2007 | iRiver H10 MP3 Player
Iriver H10 20GB - i can't access my music through Artists or Albums
Have you tired doing a "Database Refresh". It's located on the main screen under "Settings". Go to Database Refresh and check "Yes". How much music you have on your player will determine how long the refresh will take. If that doesn't work possibly run the Firmware Updater from iRivers' web site and only update the database, do not do a complete "Recovery" or all of your music will be erased as that choice reformats your hard drive. Only choose "Update Firmware"
Regards,
John H.
Aug 14, 2007 | iRiver H10 MP3 Player
Lexerd iRiver S100 TrueVue Crystal Clear MP3 Screen Protector Logo
82 people viewed this question
Top Lexerd Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Lexerd Audio Player and Recorder Expert? Answer questions, earn points and help others
