Question about KitchenAid Food Mixers
Artisan 5KSM150 It does not keep a steady speed in low speed range, I have taken the back off to see if all the wires are still connected and they are fine.
  • KitchenAid Master
  • 1,305 Answers
Remove the back cover and run it LOOK BUT DON'T TOUCH. Are the copper contacts jumping when the speed pulses? If yes you will need to SLIGHTLY twist the copper contact bar so that only one of the pointed contacts touches at low speed. Your adjustments will be done with the power cable unplugged.
Posted on Nov 25, 2013
3 Suggested Answers
hslincoln
  • 235 Answers
SOURCE: mixer runs ,then stops, and now has lost all lower speeds.
Hi DALE, from the symptoms you describe, it sounds like you've got problems in your (speed) control assembly. If your mixer were out of warranty, I'll tell you that you could fix it yourself, but as your mixer is less than one year old, let KA fix it or replace your mixer on their dime. Contact them immediately and tell them about your problem with the speed control.
The KA website is at: http://www.kitchenaid.com/flash.cmd?/#/page/home. Click on Customer Care>Contact Us> and the toll free phone number is listed to speak with someone. You can also look under the Warranty & Service Plans to see what KA will do for you. I've extracted parts of it here:
Hassle-Free Replacement Warranty
We’re so confident the quality of our products meets the exacting standards of KitchenAid that, if your mixer should fail within the first year of ownership, KitchenAid will arrange to deliver an identical or comparable replacement to your door free of charge and arrange to have your “failed” mixer returned to us.
Your replacement unit will also be covered by our one year full warranty. Please follow these instructions to receive this quality service.
If you reside in the United States and your KitchenAid® mixer should fail within the first year of ownership, simply call our toll-free Customer Satisfaction Center at 1-800-541-6390, 8 a.m. to 8 p.m.,
Monday through Friday, 10 a.m. to 5 p.m., Saturday, Eastern Time. Give the consultant your complete shipping address. (No P.O. Box Numbers, please.)
When you receive your replacement mixer, use the carton and packing materials to pack-up your “failed” mixer. In the carton, include your name and address on a sheet of paper along with a copy of the proof of purchase (register receipt, credit card charge slip, etc.).
I hope this helps. Good Luck with KA! - Howard, Burke, VA
If this solution has been helpful, please rate it, thanks! - hslincoln
Posted on Dec 19, 2009
SOURCE: KitchenAid Artisan 5KSM150. Motor working
worm gear is borken. buy new plastic gear it cost 25
Posted on Sep 02, 2010
My artisan mixer will not turn back on
Make sure it's unplugged, remove and inspect the carbon brushes one at a time under those black screws on the side. They are keyed with one corner of the square ground off so will only go in properly one way so eyes open when you take them out. If they are less than 10mm long replace them. Next would be look under the back cover for a broken wire to the black square speed control plate. Broken wires are only likely to be one of the bottom 2 on either side. Any more testing is going to require a multimeter.
Dec 20, 2015 | KitchenAid KSM150PSGA Model KSM150PS...
What is the rpm of artisan 300watts
On low speed roughly 1 rotation of the planetary per second. On high speed it should be the maximum speed that motor can run at, too fast to count that's for sure.
Oct 05, 2015 | KitchenAid KSM150PS Artisan Series Stand...
How do I replace the speed control lever on a kitchenAid artisan mixer
Remove back cap, remove white wire and black wire from lower corner of speed control plate, both on same side on adjacent terminals. Remove the gasket thing at the back as well.
Remove chrome drip ring from around planetary, knock pin out of planetary and remove the planetary.
Flip upside down on a towel and remove pedestal by taking out hinge pin (1 locking screw from underneath inside pedestal)
Remove all screws from bottom side of gearcase, 5 around planetaty, 2 in the middle and 2 at the back.
You can now seaparate the gearcases to get to the speed control lever which is held on by 1 screw.
Feb 15, 2015 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid artisan mixer
The most likely answer is that you need a new speed control switch and there is a possibility that you may need a new worm gear. Can you give a more detailed explanation? What happened last time you used the machine?, what was happening when the problem occurred? What caused you to open the back cover? what else did you inspect or take apart or open up? Please send more info.
Jan 03, 2013 | KitchenAid KSM150PS Artisan Series Stand...
MOTOR SPEED WRONG
remove rear coverdome, dust off mechanism carefully with a vacuum and small brush. Inspect all the parts- the black plate with the wires connecting to it is the speed control; beneath it are centrifugal weights which form the governor- the faster the motor spinsthe further the governor assy pushes out agatnst the contacts on the control plate to keep the speed smoothly moderated. If you have speed control but it just runs too slow or not slow enough the two screws at top of the control plate can adjust the speed; loosten the jam nut slightly and adjust the screws evenly together. Be sure theres nothing worn out or damaged which could be fatal to the mechanism later.
note tht the bottom of the control plate is retained by a wire hook on the end of a spring. It is a problem to catch and pull out if you lose it inside the mixer. If you set speed too low you will lose all power at low speeds.
The condensor at top of nontrol plate has only two wires from it out either side a flat cardboard tube. If shorted you will lose all speed adjustment. Test by disconnecting one or both wires.DO NOT RUN MIXER WITHOUR CONDENSOR except for brief testing... otherwise your trouble is the PC board- the white grease is important behind the heat sink dont remove it (standard heatsink grease for computers, etc.)
Best of luck!
Oct 02, 2011 | KitchenAid KSM150PS Artisan Series Stand...
How to attach a icecream maker KICA0WH to KitchenAid Artisan Series KSM156 that has a cap on the beater shaft. In the manual it shows how to attach it to the mixer with spring and no spring but does not...
After the bowl has been frozen you attach it to the base. Then you take the part your asking about and attach it where you would put a beater or whip. The trick is to make it spin and the notched part stay in the "center of the circle". You don't use the top front of the mixer. I had to practice without the bowl and beater bar to make sure I had it right.
Jan 04, 2011 | KitchenAid Artisan Series Tilt-Head Stand...
I have to physically hold my Artisan mixer in place or it will go off the counter, even at low speeds. Seems to rotate fine as long as the head isn't down with an attachment on and in the bowl.
I think from your description that the the head connecting to the base shaft needs tightening. Put the mixer on it's side. Look up inside the base and you'll see a small set screw.
With a flat blade screw driver tighten that screw and it should stop moving. If it doesn't you probably need another shaft because it's worn.
May 03, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Food Mixers Logo
66 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
