Honeywell cm900 screen problem
The lcd screen is fragmented
3 Suggested Answers
Buffalo12980
  • 625 Answers
SOURCE: installing a honeywell CM900 wireless programmable thermostat
the analog unit uses just two wires for heat. red - white. there is a heat anticipator setting that must match the burner current. check your programmable specs and follow instructions.
Posted on Dec 07, 2007
  • 910 Answers
SOURCE: need a wiring diagram for
Y Plan Installer Guide and CM900 Manual at the Links below.
http://www.honeywelluk.com/downloads/Systems-Plans/
http://www.discountedheating.co.uk/shop/acatalog/311940.pdf
Posted on Jun 09, 2011
My honeywell cm900 thermostat keeps showing the tempreture as -24 degrees, therefore it keeps working on full power in order to bring the tempreture back up
I would change the battery first. Then try adjusting the temperature to see if that has any affect. From here I would guess the temp sensing thermistor is open or short, causing it to indicate the extreme temperature of it's capability. Test the thermistor and replace, or replacing the thermostat are the only solutions. I hope this helps.
Oct 21, 2013 | Heating & Cooling
Help with LCD screen
Replace the LCD or the laptop. It is not repairable beyond doing those things.
Jan 07, 2012 | Toshiba Satellite 2400-S201 Notebook
My lcd screen is blank and system doesn't respond to commands... Says ''not ready'' but that's it! There is power to the units but no response except a single beep after the pin and command is entered. It...
FYI 6150 is keypad model not alarm model. See if yhis helps. try pressing the " * " key bottom leftit thould then indicate zone trouble or fault. that sould give you at least some place to start.
Feb 07, 2010 | Honeywell 5804 Ademco Wireless Security...
I knocked tv over and cracked screen. it works but fragments picture.
You need to replace the panel. You might as well get a new set. It'll be cheaper.
Dec 02, 2009 | LG 32LH20 32 in. LCD HDTV
Installing CM900 Honeywell into Junior 24 Bosch Combi
What kind of boiler are using is this boiler a on the demand electric or gas? You need low voltage wires. If you get me make and model # of off boiler i can try and find wiring diagram . Tell me a little more about you heat system to. Like baseboard heat or in floor how many zones
Jan 16, 2009 | Honeywell Programmable Thermostat Heater
Better/higher Colors for ADI CM900?
sounds like the CRT is on it's way out. open it up and check what brand the CRT is, if it's a samsung. chuck the monitor.
as good a manufacturer samsung are. they can't make a CRT display for S@#$
Apr 26, 2008 | ADI Corporation MicroScan M900 (White) 19"...
Installing a honeywell CM900 wireless programmable thermostat
Dec 04, 2007 | Honeywell Programmable Thermostat Heater
Honeywell HZ7040 shuts off after few minutes
This sounds like a theromostat problem. If you're NOT still under warranty you should at least open the heater and look for the theromostat. A lot of times you can buy replacement at a local electronic or hardware store and they're easy to replace. Good luck!
Dec 02, 2005 | Honeywell HZ7040 Compact Heater
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
