Question about Kitchen Ranges
Euroart rangehood lights do not work on euroart rangehood model RHG920SS
Torin E13 Rangehood. Blown light globe needs replaceing
Gee I think I could figure that out by looking at it .
Jan 17, 2016 | Kitchen Ranges
How do i replace the lightbult in the robinhood 2000 rangehood?
It depends on the model but Instructions can be found in the operating manual that came with your rangehood or as a PDF on the product pages of the website
http://www.Robin Hood.com.au
Jul 12, 2014 | Kitchen Ranges
Lights not working in Technika Rangehood (900m Model - D8900HASS)
TECHNIKA Pty. Ltd. 77 FILLO DRIVE, SOMERTON, VICTORIA 3062 PH 03 9948 4500 TOLL FREE
ABN 38 069 686 326 PO BOX 543, SOMERTON, VICTORIA 3062 FA X 03 9948 4555 1800 649 969
Online customer care contact for support: http://www.technika.com.au/contact
Dec 05, 2013 | Dryers
Technika rangehood parts
please follow the steps and fix it. God bless you
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
May 27, 2013 | Microwave Ovens
Baumatic rangehood bah9005 the switch pushes in and the lights dont work , motor works when electrical switch at wall is on
Thank you for using FixYa. It sounds like there is obviously power getting to the rangehood ( the motor works) and I would suspect that it is just the bulbs that have blown.
Mar 16, 2011 | Microwave Ovens
I need to find out the light bulbs relacements for a zephyr rangehood, model venezia
Check out the zephyr Site. The halogen bulbs they use are very unique. Have two clients that have Zephyr hoods and took me a while to locate replacement bulbs. Could not find them at the local lighting stores nor hardware stores. I believe it is a 35 watt halogen (sort of an MR-16 size) with an entended base.
Oct 19, 2010 | Kobe Rangehoods CH-100 Series - 36" Wide x...
How to replace light globe in Chateau Grange rangehood
I have a 600mm Chateau range hood with the same problem. To access the globe chamber, you need to first remove the plastic diffuser from the underside of the rangehood. Located at one end of the diffuser will be a small slot approx 10 mm long. Insert a small flat blade screwdriver into this slot and carefully depress the plastic tongue of the diffuser by gently pushing the head of the screwdriver away from the diffuser. As the tongue disengages from the frame you should be able to grasp the edge of the diffuser and pull it away from the frame. Once the diffuser has been removed from the frame, you will be able to change the globe.
To reinstall the diffuser, insert the plain end of the diffuser into the frame of the the rangehood (above the globe) and gently push the clip end back to its flush position.
Nov 17, 2009 | Kitchen Ranges
Looking for a manual for SMEG rangehood HACD60SS model bought in 2008. Rangehood may not be installed properly, it's not sucking up air into the hood.
check to be sure that the fan works, and if it does check to be sure that the air flow path to outdoors is not clogged. one way to do this is to remove the hood and slide a dry garden hose through the entire vent pipe to the outdoors.
Jun 29, 2009 | Kitchen Ranges
Rangehood malfunction
My Baumatic Rangehood model BAISL92.2 had the letter A flashing. I was advised by a repairman that it indicated the filters needed to be cleaned with warm soapy water. Apparently in my particular model there is a built in 30 hour timer for when the filters need to be cleaned. To remove the flashing letter A, I was advised to clean the filters, turn off the rangehood and while it was off, press the (-) (minus) button and hold for 5 seconds. It beeped and the flashing letter A was removed. This worked for my particular model - I couldn't guarantee it would be the solution for your model. I hope this is some help.
Jul 22, 2008 | Baumatic Upright Freezer BV12A
Euroart dishwasher error message
I have the manual for this dishwasher an error code 003 means "longer heating time, but not reaching required temperature" and the possible cause is written as "Malfunction of temperature sensor or heating element". Hope this helps.
Regards,
Phil
Feb 02, 2008 | Dishwashers
Kitchen Ranges Logo
125 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
