701clps - i have E3 coming up and machine stops working. It will leave the water in the machine and just not go. When i try to restart it will start then stop straight away. Anyone know what this is
Amigaman
  • 248 Answers
SOURCE: MY NEPTUNE MAH4000AWW WORK WHEN IT WANT TO WORK
Check for low water pressure. Clear screens in inlet valve. Do-not remove screens. This unit will turn off if not filled in specified time.
Posted on Nov 15, 2007
  • 6 Answers
SOURCE: aeg 72630 update will not rinse during rinse cycle
If the drain lines were plugged, there may have been enough pressure on the pump to fault out. Make sure the sewer line is completely open, as well as the lines at the pump.
Posted on Jan 14, 2008
ginko
  • 19396 Answers
SOURCE: Washing machine fills in the water but does not start the wash cycle
The fact that it does not fill completely can be related to a problem with the water-level switch, that regulates the water level.
See from Repairclinic:
"This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch."
However, when it is only the switch the mashine usually completes the cycle, but with less water than normal.
A possibilty is that either the timer is faulty or there is a problem with the water supply.
Check that water is coming from water supply with regular pressure, and that hoses back there are not obstructed.
More likely you will have to replace the timer.
See again from Repairclinic:
"When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water."
  • You can find parts at the following websites, you need to input your model number. If the part is not listed contact them.
    Repairclinic
    Partselect
    Don't forget to rate the solution.
    Many thanks.
    Posted on Sep 01, 2008
    • 1462 Answers
    SOURCE: Bosch WFLI 2440 Front Load washing machine stopped working
    filter is probably the problem. the round cap unscrews and then just pull filter out
    Posted on Sep 07, 2008
    • 4 Answers
    SOURCE: LG +3 turbodrum wf t851 bE error code
    I have the same problem. I do not think this has a micro switch to activate the wash cycle or spin. I have looked carefully.
    I have a gut feeling that this works on a sensor similar to that of a sonic car alarm. It may have gone out of sync and needs to be retuned.
    I have tried to find the software but it is not commercially available.
    Posted on Jan 04, 2009
    Where can I get a lint filter for a tech magic 9kg washing machine. who makes these. I have noticed that I have a small amount of water sitting under the drum in the machine. . Thank you
    It may be that your pump is not functioning efficiently ?
    Usually what happens here is that the pump to expel the water is not functioning, the normal problem here is a coin or hair grip gets lodged in the pump and stops the impeller from turning, generally the pump can be removed and opened up to remove the offending article and allow the impeller to operate again, once cleared of obstruction reassemble the pump and refit it. ( be aware, as the machine is still full of water, when you remove the pump the water will flood out so you need plenty of towels so soak up the water that spills.
    Sep 21, 2016 | Washing Machines
    9KG My machine fills up with water and does not drain, makes a noise but does not drain, what could be the problem?
    does it go into wash cycle? if so then check for a clogged drain pump or pump with broken propeller/ if no wash cycle then check ur water pressure switch
    Mar 06, 2015 | Washing Machines
    MY SAMSUNG WASHER HAS AN ERROR MESSAGE THAT SAYS E3 AND IT WONT SPIN
    This video will help you diagnose the fault on 3e error codes and the video will help you solve the problem hope it helps
    Jul 08, 2014 | Samsung WF337AA Front Load Washer
    E3 water drainng error
    Some drain problems come from the washer drain hose not being high enough to allow for the water to fill in the dishwasher. Make sure the hose is held as high as the washer top as possible before it drains into the sink drain pipe. A good example is your cloths wash machine the drain hose comes from the bottom of the machine then it goes up to the drain that is higher than the basket. This keeps the water level high enough to wash clothes. The dishwasher works the same way. The drain hose must be slightly higher or as high as the needed level in the machine to work. In most cases as high as the dishwasher top or close to it. Simple raise the drain hose.
    Jan 20, 2014 | Samsung DMB28AFS Dishwasher
    After main washing, stops and can't spin. Gives error E3.
    The "E3" error indicates that a Samsung washer's motor is not running properly. The cycle can usually be restarted by pressing the "Start/Pause" button. However, if the error code appears again, you should contact an authorized service technician.
    Sep 25, 2013 | Washing Machines
    Xqb90-701clps
    Some where at the bottom there is springs that can be broken or out of position, or the jockey pulley might need replacment
    May 10, 2017 | Washing Machines
    My washin machine is just stopping thru cycles and beeping continuously until I switch off - reading E3. My father thinks it might be the heater, is that right. I'm having a lot of trouble getting...
    Hi, the E3 error is comes up when the water heater element does not work properly or the filter mesh is blocked. Remedy: Clean the filter mesh and if the problem continues, the main board needs to be replaced.
    Jun 24, 2011 | Maytag 24 in. MDB6600A Jetclean II...
    My NEC NFL855 E3 error
    E3 error is discharging water problem. ie 1.the pump not working (under bra wire will stop it spinning) or 2. the discharge hose blocked or most likely 3. the pump inlet hose from the drum is blocked (with small article of cloth or coins or similar).
    To Fix:
    1. Open the pump filter and check if spinning during empty/spin cycle, make sure nothing jamming or twisted around impellor.
    2. Check discharge hose is not crushed or kinked.
    3. Lay machine on its side, access pump and remove inlet hose assembly and remove any blockage.
    Jeremy
    Jul 19, 2009 | Washing Machines
    Rinse cycle won't stop
    Start rinsing again, when the water comes out, take off the water tank and let the machine go to it stop.
    /Mirran
    Aug 21, 2008 | Saeco Incanto Classic Espresso Machine
    Washing Machines Logo
    24 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
