Question about Sharp AR-5320 Black and White Copier
L4 error for ar 5320e - Sharp AR-5320 Black and White Copier
  • 87 Answers
SOURCE: Error L4
l4 if sub code is 01 .check sub code by pressing start key .that is for main drive motor and gears .just check all main drive properly mian jee
Posted on Jan 21, 2009
  • 120 Answers
SOURCE: how to reset u2-40 for sharp AR266 photocopier
Since this appears to be a non-US model I can only base my response on the closest US body type AR-M237.
U2-40 means the countdown (CRUM) chip in your toner cartridge either broke or went to zero. If you can put in a fresh CRUM chip in your cartridge, that's great, otherwise you'll have to replace the toner cartridge.
L4-01 means main motor lock, probably due to a brownout or otherwise missed timing. You can probably get by with a power off and on. Not sharing your copier with other devices on the same outlet will also help here.
To reset error codes, put the machine in test mode with the four-key combo: # - * - C - * ... 16-Start clears your U2 trouble, 14-Start and 17-Start clear the rest. Then hit CA and allow your copier to reboot. Good luck!
Posted on Jul 09, 2009
  • 118 Answers
SOURCE: CODE L4-02 JUST ILUMINATE ON MY SHARP AR-M 350U PHOTOCOPIER
That code means you have a drum drive motor failure. The drum is the long, cylindrical green-blue tube you'll see when you open the left-side door.
Chances are some paper jammed up inside the drum process unit (that black frame that holds the drum) and it's keeping the drum from turning. Check the drum/process unit and make sure they are clear of any material that could cause a jam.
Posted on Aug 28, 2009
xptareq2000
  • 1447 Answers
SOURCE: error code L4 30
L4 error code mean your copier motor fail problem.
Please press # Interrupt C interrupt press 16 press start key or print key.If are not fix this problem please check motor fuse or any kind of gear was broken.
Posted on Dec 16, 2009
hamzaskilltd
  • 316 Answers
SOURCE: SHARP AR--M207 Error L4-11
1. Main motor lock detection
2. shifter motor trouble
Posted on Jun 01, 2010
MY SHARP AR-M207 DISPLAY ERROR CODE L4-00 KINDLY GIVE ME A SOLUTION
Hi Alafin,
An error code of L4 suggests a motor error. It could be something as simple as a loose cable but it could be a bad motor. I would suggest you call on a local dealer to repair this as you will probably need new parts.
Jun 14, 2016 | Sharp Used AR-M207 Copier Printer Scanner
My sharp machine ar 5516s is having problems giving error code l and 4 simulteniously what can i do
can be the main motor locked if its l4-01 but if its l4-31 its fusing fan locked detected or l4-35 its PS fan locked detected
Jun 18, 2014 | Sharp AR-275 Copier
I HAVE SHARP COPIER, THE MODEL NO IS AR-5320E. I AM HAVING THE PROBLEM OF H4 ERRO. PLEASE HELP ME
check heater section properly,(thermister,thermostat,heater lamp)go service mode and clear error code also
Sep 20, 2011 | Sharp AR-5320 Black and White Copier
My sharp copier AR-5320E is displaying error code u2
U2 04 Content EEPROM serial communication
error
Detail Error in communication with
EEPROM
AR-205
Jul 20, 2011 | Sharp AR-5316 Advanced Digital Imager...
Error code L4 30
Dec 16, 2009 | Sharp AR-M455N Copier
I need the software for ar-5320e
I need a share ar 5320e software .How can I get this software?
Jul 16, 2009 | Sharp AR-5320 Black and White Copier
Model AR 5320E. Giving H2 error.
As we needed our copier very quick we had to call a qualified person to arrange the system.
Kind regards
Miriam4177
Jun 17, 2009 | Sharp AR-5320 Black and White Copier
Error L4
Jan 15, 2009 | Sharp AR-5320 Black and White Copier
Sharp AR-5320 Black and White Copier Logo
35 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
