Question about Plumbing
Jaguar bath fit
Cold side is choked.
    Problem Solver:
  • 31 Answers
Pipe or valve could be block or bend.
close the main water valve and open the bath cold valve antil all the remaining water come out.
when come emtpy close the bath cold valve and open the main valve, after open for few seccons all the valves in kitchen and bath. normaly the most of impurities they come out.
Posted on Nov 27, 2013
Whirring vibrating sound
As long as it virtually goes when warmed up, don't worry. When starting from cold remember P & N aren't actually driving the transmission. Point to note, Jaguar say no servicing of auto-trans necessary - this is NOT true - fluid AND filter should be changed about every 25/30 thousand kms.
Jun 20, 2013 | 2000 Jaguar S-Type
Rpms go up and when cold at idle
i dont know about this car but few cars come with automatic choke when you start cold the choke is activated to reduce air intake and in process excessive fuel is drawn in the carburettor to heat the engine and when it reaches the preset point the choke is automatically de activated. if you find it different from before then have a checkup on choke which might get stuck due to malfunction or else
Aug 29, 2012 | 1989 Jaguar XJ6
Won't start when cold
hello wyatt...... Is your jag.built with a carburetor or fuel injected?
Carb, your choke is not set to close when cold, and should be set. When set, it also sets a cam that keeps the engine running fast. Then when warm, you hit the pedal and the cam moves, and the engine speed goes to normal. Unless the choke is set, the engine cannot keep running, as it tries to run on cold gas and it can't run good on cold gas. It needs more gas, therefore, and the choke makes more gas go into the engine.
Fuel Injected, the computer should adjust the amount of gas your car is getting when cold. If not, the coolant sensor might be bad.
The coolant sensor senses the cold engine and tells the computer to add more gas. Once the engine is warm, the coolant sensor tells the computer to put the gas to normal.
So, if the sensor is not working, the engine will try to run normal, and if cold, it can't. Joe Thanks for choosing Fixya!
Dec 24, 2010 | 1985 Jaguar XJ6
PLUMBING>FITTING FLEXI TAP CONNECTORS TO BATH
NO PROBLEM USING FLEXIBLE HOSES. JUST ENSURE THEY ARE NOT KINKED WHEN INSTALLING
Oct 13, 2009 | Home
Air conditioner does not blow cold air
all cars of that year use r-134 refrigerant. Follow the ac lines till you run across the service port. The one near the evaporator (front of engine) is the high side; leave that one alone. It usually is marked with a red cap
the low side port is near the firewall, and usualy has a blue cap. The valve for a refill can usuallly will only fit on a low side. When filling the can will get very cold very fast. If the can doesnt start to get cold immediately, remove it you have it on the wrong side. Make sure to remove it immediately, as keeping it on the high side will pump liquid freon into the can causing it to explode.
May 31, 2009 | 1995 Jaguar XJ6
Grundfos recirculating retro fit hot water out of the cold side
they have it installed wrong it is pulling from the wrong side, it is supposed to pull ot water up to the fixture but then if it stays hot on the cold side they are backwards
May 27, 2009 | Grundfos RCP-96 Recirculation Pump for...
Bath waste
! goes over the threaded piece that screws into the piece that goes under the tub...and the other goes between the tub and the waste assembly thereby creating a sandwich with one on top and one underneath the tub....then screw the piece down tight through the tub and into the waste assembly and your good to go.....
Good luck and thanks for rating my effort.....the Fang.
Mar 25, 2009 | Lefroy Brooks BATH WASTE KIT - LB1370-ST -...
Had new mixer taps fitted on sink and bath (water pressure was fine hot and cold before) but now have very low pressure on hot water. can anyone please help, as its taking 35 mins to run a bath.??????
can you check some other source of hot water? if the pressure there is ok?..if it is, then the problem is on the new tap that you fitted.
Jun 27, 2008 | Heating & Cooling
Plumbing Logo
54 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
