Question about HP LaserJet 2300 Printer
Numerical Error
I have start printer, Error on Printer display 53.10.03?
    Sergeant:
    Champion:
  • 246 Answers
Try to reinstall the printer drivers
Posted on Nov 20, 2013
On my Brother MFC410CN Printer Message reads Unable to clean I have followed TroubleShooting instrctions and it still appears
MFC620CN/425CN/420CN/410CN/215C/210C and FAX2440C
Press the Menu/Set, Black Start, Menu/Set, and Black Start keys in this order.TIP: For the FAX models equipped with numerical keypads, you may press the Menu/Set, Black Start, and 0 keys instead in the same way as conventional models.Then "MAINTENANCE 10" appears on the LCD. Press 82 using the numerical keys/arrows.
Then press the Menu/Set key.
Error code will display indicating source of error if it is 41 thats print head error,
replace machine.
press stop to exit if needed.
(http://www.fixya.com/support/t250171-brother_mfc_215c_unable_clean)
Oct 06, 2008 | Televison & Video
Show error 52.00
52.X PRINTER ERROR The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error 1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner.
Apr 16, 2016 | HP LaserJet 4350n Printer
I get an error in HP LaserJet 4345 MFP printer, 49.ff95 error, Tunr off and the turn on
a 49.xxxx error on an HP means that there is an issue with one or more hard disks. you can try to re-initialise the hard disk(s) by rebooting the printer while holding the green button. when the three leds are lit, release the green button, and navigate using the numerical buttons until you see "initialise hard disks" on the display of the printer. confirm by pressing the green button again. if all goes well, your printer will take two minutes longer than usual to boot. if you still get the same error afterwards, you need to replace the disk.
Apr 21, 2010 | HP LaserJet M4345 MultiFunction Printer
Canon Pixma MP760 no error code
First you must remove the printhead and power on again, if it only has printhead error then printhead is the culprit. Otherwise you must press a key sequence to display the numerical error code and know what part of the printer is failing, purge unit, feed assy, or dirty encoder strip.
Please rate my response!! Thanks, SF
Jan 28, 2010 | Canon Office Equipment & Supplies
Canon MP760 stopped working. Error Message "Turn machine off and on". Suggestions given early this morning have not helped. The paper path appears to be clear. Please help. hsalomon
Jun 19, 2009 | Office Equipment & Supplies
Unable to clean on mfc215c
PAPER JAMED IN MACHINE PROBALLY ON THE OTHER SIDE OF THE PRINTHEAD SO MOVE THE PRINT HEAD ACROSS AND LOOK IN THERE FOR A PIECE OF PAPER PROBALLY SOAKED IN INK, HAVE A GOOD LOOK WERE THE PURGE UNIT IS MAKE SURE NO PAPER THER .
Or
Error code will display indicating source of error if it is 41 thats print head error, not worth a cracker, replace machine.
Thanks.
Dec 29, 2008 | Brother MFC 210C All-In-One InkJet Printer
1.unable to clean?mfc215c
press stop to exit if needed.....
OR
Thanks.
Errors list : 46, 50, A1
CP315C/310CN/120C/115C/117C/110C
(1) Press the (1) Press the
Menu and Mono Start keys. Menu and Mono Start keys. Next press the key four times to make the machine Next press the key four times to make the machine
enter the maintenance mode. enter the maintenance mode.
(2) Enter 8 and 0 by using the and (2) Enter 8 and 0 by using the and
Set keys.* Set keys .*
(*To enter a numerical code on models having no numerical keypad, press the key several times to (* To enter a numerical code on models having no numerical keypad, press the key several times to
display the numerical code to be entered and then press the display the numerical code to be entered and then press the
Set key. Set key. Repeat this operation for each Repeat this operation for each
numerical code.) numerical code.)
(3) Press the (3) Press the
Mono Start key several times until the purge count appears on the LCD. Mono Start key several times until the purge count appears on the LCD.
(4) Enter 2, 7, 8, and 3 by using the and (4) Enter 2, 7, 8, and 3 by using the and
Set keys to reset the purge count to zero.* Set keys to reset the purge count to zero .*
(5) Press the (5) Press the
Stop/Exit key to return to the initial stage of the maintenance mode. Stop / Exit key to return to the initial stage of the maintenance mode.
(6) Enter 9 twice by using the and (6) Enter 9 twice by using the and
Set keys to exit from the maintenance mode.* Set keys to exit from the maintenance mode .*
Mar 01, 2008 | Brother DCP 115C All-In-One InkJet Printer
Brother mfc-215c unable to clean?
I have the same problem my printer (a MFC-215C) is unable to clean and when I press Menu/set I do not have "Black print"? So what do I do now?????? HELP... Thanks Nathalie
Nov 09, 2007 | Brother MFC 420CN All-In-One InkJet...
HP LaserJet 2300 Printer Logo
20 people viewed this question
Seeker5211
Seeker5211
