Question about Samsung ES30 Digital Camera
Usb connection show on starting
When start the camera usb connection show on secreen even connect usb cable on computer but no action run
    New Friend:
Connect camera to pc and power on the camera.
Posted on Dec 15, 2013
4 Suggested Answers
  • 11967 Answers
SOURCE: When I connect the Samsung
Do what the pros do...use a card reader to download to a folder you create on your desktop.
Posted on Sep 21, 2010
  • 11967 Answers
SOURCE: I've never had problems uploading pictures in the
Posted on Oct 26, 2010
SOURCE: i have Samsung ES25 Camera. my camera shows
Connect your camera with a pc and Just format your memory card.... Shuyeb (SHAHJALAL UNIVERSITY OF SCINCE AND TECHNOLOGY, BANGLADESH)...008801676711544
Posted on Oct 13, 2011
I cant load my pictures in my computer
If images cannot be imported automatically into the Windows PC, check [Precautions] below.
[Precautions]
- Temporarily terminate resident software such as antivirus software.
- Connect the AC adapter or load a fully charged battery into the digital camera.
- If RealPlayer 10 is installed, select "Tools" - "Preferences" and then disable "Automatic Services."
XXXen the digital camera is connected to the PC, if the FinePixViewer starts up and images in the digital camera are displayed, skip Steps 1 to 5 and start with Step 6.
1. Start up the PC and then connect the digital camera and PC using a USB cable.
2. The "USB MODE" setting of the digital camera may be set to "PC CAM."
Set "USB MODE" to "Card Reader" or "DSC."
*Only in the case of the digital cameras that have the "USB MODE" setting in the SETUP menu
3. Check whether or not any mark indicating the USB connection (USB, CARD READER, USB symbol with an arrow mark, etc.) is displayed on the LCD monitor of the digital camera.
If not, the digital camera and the PC are not connected properly. Check the following points.
a. Restart the PC, disconnect and connect the USB cable and then try again.
b. If the PC has multiple USB ports, connect the USB cable to another port and then try again.
If no mark indicating the USB connection is displayed even after performing above Steps (a) and (b), the digital camera or USB cable may have a problem.
4. Check whether or not "Removable Disk" is displayed in "My Computer." (For example, when the operating system is Windows XP, a FinePix icon in the shape of a digital camera is displayed.)
If "Removable Disk" is not displayed, install the USB driver again.
5. Automatic startup software (Exif Launcher) may not function properly.
Perform the following procedure.
[Windows XP]
a. Select "Start" - "My Computer."
b. Right-click the "FinePix" icon and then click "Properties."
c. Click the AutoPlay tab.
d. Click "Music files" and then select "Pictures" from the displayed list.
e. Select "Select an action to perform."
f. Select "Viewing images with FinePixViewer."
g. Click the "OK" button.
6. The Automatic Save Settings may be incorrect.
Specify the Automatic Save Settings again by following the procedure below.
a. Start up the FinePixViewer.
b. Select "Automatic Save Settings" in the "Settings" menu.
*If "*** not found" is displayed, click the "OK" button.
c. In the "Way of Saving" column, click the "Browse" button to specify the storage location.
Feb 26, 2014 | Fuji FinePix A345 Digital Camera
I cannot take pictures while connected to computer with a usb cable
Is there anything to make you think you should be able to? I took a quick look at the manual and didn't find anything to imply that. Many cameras when connected to a computer serve only as a fancy card reader, allowing you to download pictures, and not as a camera that can take more pictures.
If you see anything in the manual, please point it out to me. In the meantime, what operating system are you running on your computer? Are you using any software on the computer for remote operation of the camera?
Feb 06, 2014 | Pentax *ist DL (W/18-55 LENS) Digital...
Extrawebcam
Most digital cameras (NOT ALL but the exceptions are sold as such)
can't be connected to the computer, when they are switched on.
Most digital camera's will shut down, when connected to the USB card. Your Canon G10 is no exception. Most of the time when connecting the USB cable the camera changes in an external memory drive for the computer. Some camera's can be charged via the USB cable. Even when connected to a computer.
Even when I want to connect my DSLR to a computer, to do life view on my computer screen, I have to install special (payed) software, to let it work.
Without the software running, the same DSLR always shuts down and only will download pictures when another program is started.
Feb 05, 2014 | Cameras
When I switch on to download photos the camera lense slightly comes out and there is also no beep noise that normally follows, it is not letting me download?
Even if the USB cable is connected perfectly to the camera and PC it still is not sure everything in the cable and both connectors is 100%. Or even the drivers in the computer can be corrupted.
Start with another cable, and if possible try to connect another camera to the compeer, to check the computer acts normal to that.
Always try to isolate a problem to one thing.
For the time being, you perhaps could place the memory card in an external card reader connected to the computer, to put the pictures on your computer that way?
Jan 29, 2014 | FUJIFILM FinePix S1800 Digital Camera
I cannot connect up SP800UZ to my computer.
If you mean that, even when you connected the Olympus USB cable correctly, the computer does not recognize the camera? If so, connect the camera to another computer to check if the camera or usb cable or the original computer is causing the problem. Often the computer does recognize the camera as a Removeable USB Device. You can see that when using e.g. the Windows Explorer. If the problem is only, that the installed Olympus software is not started, when connecting the camera to the computer, check the settings of the [ib] software by running it manually. Otherwise re-install the [ib] software.
May 20, 2011 | Olympus SP800UZ Digital Camera
When I try and connect my camera to computer using the usb cable it shows a screen which says 'usb mode connecting.... Switch on [menu]. I go to menu and have 3 options auto mass storage and pictbridge. I...
Consider NOT using the USB connection.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jun 25, 2010 | Sony Cyber-shot DSC-T70 Digital Camera
Ipod Shows as camera
Try restoring it...here's how...
  1. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  2. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  3. Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
    Note: If you see the message "Charging... Please Wait" , let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
  4. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  5. When you see "Connect to iTunes" on the screen, you can release the Home button andiTuneswill display the recovery mode message:
    If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
But you will lose all your data
Sep 07, 2009 | Apple iPod touch
I cannot upload pics from my camera to my pc.
Try updating Canon software from their website...www.powershot.com
Also:
Here are the steps to take.
1. Establish whether or not you have a connection between your camera/computer by going to your start button, control panel, system, hardware tab and device manager. The camera must be powered on and in playback mode (should automatically go to playback mode when connected, camera's screen should go black if there is a connection). Make sure you have a fully or nearly fully charged battery in your camera.
2. Once in device manager, look under Imaging Devices. If your camera is properly connected it should show up as Canon Powershot SD800. If it shows a yellow exclamation point, there is a driver issue, and even if it doesn't show a yellow exclamation point, you may want to update your driver anyway by right clicking and having the system search automatically for driver updates. If download of driver begins, great...once finished, restart camera and your problem may be resolved.
3. If there are any other imaging devices, you may have to temporarily disable them to avoid conflicts.
4. If you have any other imaging software running, exit or close the program in your system tray (down by your clock in the right hand corner of your computer's desktop.
5. Try again to connect.
6. If you are on a desktop, try a rear usb port vs. a front port. You can also try a different port on a laptop. After each change, try restarting camera to establish connection.
7. Go to start/My Computer and look for the icon for your camera...you will be able to download images even without Canon software loaded onto computer so this is not a software issue if you have no hardware connection. If you see the icon, right click on it and choose Get or Import pictures. From there the default Microsoft scanner and camera wizard should launch and you will be able to import your images.
8. If still no connection, try going to Start/Run and type in services.msc here you are looking for 4 services to be running. Check under status of each service and make sure it reads that each of these services are started.
  • Canon Camera Access Library 8 (if Canon software loaded)
  • SSDP discovery service
  • Universal Plug and Play Device Host
  • Windows Image Acquisition
Once all of these services are started on your computer, restart camera once again. If any of the last three services are not on your computer or are not started, connecting will be a problem.
If all of these steps fail, try purchasing an SD card reader from your local electronics store for around $12 and download images from there. Canon also offers lifetime technical support for your Powershot, so give them a call if none of these steps work or if you would like someone to walk you through it.
Best of luck to you!
MrsJGreen
May 29, 2008 | Canon PowerShot A80 Digital Camera
Canon PowerShot SX100 is : Need to download photos onto computer. Proper connection and did this before. Now, the computer doesn't recognize the connection and a small script on the camera says...
MrsJGreen
May 27, 2008 | Canon Cameras
No pictures
Have you checked the HP hep site?
Here is their suggestion
Introduction This document explains how to transfer images from the camera to a computer running Windows XP operating system by using a universal serial bus (USB) cable. Transferring the images Follow the steps below to transfer images from the camera to a Windows XP computer. Step one: Connect the camera to the computer
  1. Turn off the camera.
  2. The camera came with a special USB cable for connecting the camera to a computer. Connect the large end of that USB cable to the computer. Figure 1: Connect the USB cable c00878070.gif
  3. Open the rubber door on the side of the camera and connect the small end of the USB cable to the USB connector on the camera.
Step two: Transfer the images Choose one of the following methods to transfer the image files: Method one: Transfer images with the HP Photosmart software
  1. Make sure the HP Photosmart software is installed on the computer. If the software is loaded, then go to step 2. If the software is not loaded, click here to upgrade to the latest version of imaging and printing software (in English).
  2. If images on the camera are selected for printing or selected for HP Instant Share destinations, make sure the computer is connected to a printer and the Internet.
  3. Turn on the camera. The HP Import Photos software starts on your computer. If you have set the software to automatically transfer the images in the camera, the images automatically transfer to the computer. Otherwise, in the Transfer images from Camera/Card screen, click Start Transfer . The images are transferred to the computer, and then if there are any still images that were previously selected for HP Instant Share destinations, those actions are started.
  4. When the Image Action Summary screen appears on the computer, you can disconnect the camera from the computer.
Method two: Transfer images without the HP Photosmart software If you do not, or cannot, install HP Photosmart Software on your computer, you can still transfer images from the camera to the computer using the Picture Transfer Protocol (PTP) in Windows XP. Follow the steps below to transfer images.
  1. Turn on the camera. Windows will automatically launch a program to transfer the images.
  2. When the images have finished transferring, disconnect the camera from the computer.
  3. If you encounter problems, check that the camera USB Configuration in the Setup Menu is set to Digital Camera .
    1. While in Live View , press the Live View/Playbackc00591915.gif button, and then press the Menu/OKc00280209.gif button.
    2. Scroll to the Setup Menuc00595863.gif using the left/right arrow c00280208.gif buttons.
    3. Use the up/down arrow c00280207.gif buttons to scroll through the Setup Menu to highlight the USB option.
    4. Use the left/right arrow c00280208.gif buttons to change the setting to Digital Camera and then press the Menu/OKc00280209.gif button.
    5. To exit from the Setup Menu , press the Live View/Playbackc00591915.gif button.
  4. Reconnect the camera to the computer.
Mar 06, 2008 | HP Photosmart M415 Digital Camera
Samsung ES30 Digital Camera Logo
119 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
