Question about Intel REALTEK nc-r150201 Network Adapter
Silan sc92301 PCI Ethernet driver - Intel REALTEK nc-r150201 Network Adapter
Driver for ethernet
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
Realtek RTL8139 Family PCI Fast Ethernet NIC
http://download.cnet.com/Realtek-RTL8168-8111-PCI-E-Gigabit-Ethernet-NIC/3000-2112_4-99235.html
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access
http://download.cnet.com/Realtek-RTL-Gigabit-and-Fast-Ethernet-NIC-Driver-Windows-2000-XP-XP-64-bit/3000-2112_4-10278840.html
Drivers for RTL8100B(L)/RTL8100C(L)/RTL8101L/RTL8139C(L), RTL8139C(L)+/RTL8139D(L)/RTL8100(L), RTL8130/RTL8139B(L)series. Windows
if these driver packages aren't right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
you might have to search/try a few times to get it right
IE: motherboard name ethernet drivers or lan drivers
hope this helps
Sep 18, 2012 | Dell J0592 / 0J0592 DIMENSION 4550...
Marvell yukon ethernet shows with yellow exclamation mark and will not allow me to connect to internet
The driver should be on the motherboard disc or the one supplied by your ISP internet service supplier
make very sure all leads are plugged into their specific connection plugs you might have to connect the usb lead to your modem to get a connection then
click start control panel,administrive tools,computer management,device manager scroll to network adapters could see a yellow question mark? right click install drivers
hope this helps if you cant find the driver hopefully one of these will help you
Feb 08, 2012 | Marvell Yukon 88E8001/8003/8010 PCI...
Pleas help, I need software on : Olicom OCE4XODI Ethernet PCI/II 10/100 MLID v1.08 (970130)
Hello k_kmail,
I've given you a "Link" to the Website, where you can
"Download the Software / Drivers," you need.
If you look at the list of {Items}!
You will see the NETWARE/NW4X/OCE4XODI.LAN
for the [Ethernet PCI/ll].
Click on the "File: oc218x-3.exe"
This will download the Drivers!
"Install the Drivers and restart the computer!"
This will "Update the software."
"Best Regards"
Click here for Software: http://www.network-drivers.com/drivers/27/27565.htm
Jul 23, 2011 | Olicom Ethernet PCI/II OC-2183 Network...
I'm not able to connect with my ASUS M50vm to ethernet. how i can check if the hardware is working?
May 16, 2011 | ASUS Intel 440BX Chipset P2B-VM...
Update Drivers pour REALTEK8139/810X Family fast Ethernet NIC sur "XP"
Apr 30, 2011 | Televison & Video
Need drivers for ibm 10/100/1000mbps gigabit ethernet low profile pci express adapter Item#53y4005-co
This card is equivalent to the
Marvell Yukon 88E8075 PCI-E Gigabit Ethernet Controller
This should be the correct driver:
http://www-307.ibm.com/pc/support/site.wss/MIGR-74413.html
Follow the instructions at the site.
Apr 11, 2011 | IBM 10/100/1000Mbps Gigabit Ethernet Low...
Dell Inspiron ethernet card plug bad, either send tower to Dell for 3 weeks or replace and bypass with new ethernet card PCI, any problems with doing this?
There should not be any problem with you buying your own PCI ethernet card and install it yourself. They are not that expensive. www.newegg.com has on for only $7.99 and it will work fine in your computer. It does not need to be from Dell.
Nov 19, 2009 | Dell Ethernet Card Network Adapter
One of two 3com pci gigabit ethernet cards is not working
If you have the driver disk that was distributed with the card , try reinstalling the card drivers first.
If the card is faulty, buy a new pci ethernet adapter and replace it, inserting the ethernet adapter into the pci slot.
After installing install drivers for the new card with the disk that will come with the card.
Ensure that you are logged in as administrator when you reinstall the drivers.
Nov 05, 2008 | SysKonnect Gigabit SK-9843 Network Adapter
Driver for INTEX RTL 8139D for windows XP
the chip of my card is labelled as RTL8139D, download RTC (not RTL) 8139D driver (517kb) for XP from http://www.intextechnologies.com/support-and-downloads.aspx ,
it works now.
Jan 02, 2008 | Intel REALTEK nc-r150201 Network Adapter
Intel REALTEK nc-r150201 Network Adapter Logo
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
