Question about Maytag Dryers
Maytag Maxima Gas Dryer MGD6000AW
Convert from gas to propane instunction manual
ngafm
  • 166 Answers
SOURCE: Natural GAs to Propane
Call Maytag or whirlpool!
Whirlpool makes Maytag now same company
They make a conversion kit!
ngafm at your service.
Please rate me before you sign out!
Posted on Sep 06, 2008
SOURCE: How to convert from LP back to Natural Gas?
I have an old Kenmore dryer that I need to convert from LP to gas. I have the parts but no instructions. Can you please help?
Thank you, Roxanne
Posted on Oct 13, 2008
  • 9 Answers
SOURCE: converting back to nat gas from propane
Typically, conversion from natural to propane and visa-versa is just a simple connection behind the appliance. Look in the box of the conversion kit (or on the back of the packaging,) and you should see the conversion instructions. Since you are dealing with gas, you need to make sure the shut-off valve is... shut off so no gas can leak while do the exchange. Also, make sure there are not open flames anywhere near the work area. Take your time and follow the directions...
Posted on May 25, 2009
SOURCE: samsung gas dryer convert to propane
I purchased a Samsung steam gas dryer and found that no one in our area knew anything about them, Fortunately I am a gas tech. but have never worked on this brand. The first thing is you should always use a gas technician before doing this. Secondly turn off the gas and electricity. You must remove the two screws from the back that hold on the top of the appliance and set this aside. Then lift up the front electronics and disconnect the wiring harness, once you've done this there are 5 screws along the top of the silver strip or door area. This will alow you to lift up the front and disconnect the wiring harness and set aside. now you can follow the instructions on converting your dryer. PLEASE check for LEAKS and proper gas flow. Follow the same steps in reverse to put the dryer back together and happy drying.
Posted on Jul 01, 2009
SOURCE: Convert Whirlpool dryer from propane to gas
I have a whirlpool dryer as propane and needed it converted to gas. I have the orifce -gas kit which consist of two parts. Which part do I use? Is it the one which screws in and mist hole is on the other end, or the other one it comes with that has the mist hole on the other side.
The one i placed was the later ( one with mist hole on the side)
Posted on Aug 02, 2009
Convert dryer to propane. We have the Whirlpool converter for Maytag dryer.
If this is natural gas dryer, you need a certified gas technician to do the work. You can't do it yourself as it is too dangerous. The gas air mixture and the gas pressure has to be set with a tool called a manometer.
If the dryer was electric, and you want to convert it to propane, that is impossible and can't be done.
Feb 07, 2017 | Whirlpool Dryers
Maytag neptune gas dryer Model # P MD64000AWW converting to propane and would like to convert back to natural gas
NEED TO CHANGE GAS ORIFICE. THEY ARE DIFF. BETWEEN NATURAL GAS AND PROPAIN THATS ALL YOU HAVE TO DO.
Oct 06, 2013 | Maytag Neptune MCG8000AW Gas Dryer
Need to convert electrical Maytag Performa Dryer (Model:PYET244AYW) to propane gas system. It can be converted?
No that can not be done fairly inexpensivly...it could be converted but would actually cost more to purchase all needed parts that it would be to buy a brand new gas dryer
Oct 16, 2011 | Maytag PYE2300AY Electric Dryer
Can you convert the gas model to electrical? I just got a gas model from a friend but have no way to use it.
Sorry their is no way to do that..the gas dryer is only equipped to heat by gas and has no elecrtic heat element in it
Sep 07, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Does the maytag model number mde9700ayw have the
Yes it can be a gas dryer. If you have a electric dryer now though you can not convert to gas. If the dryer is set for propane the it can be converted to gas buy a licensed plumber or appliance repair man.
Good Luck
Apr 27, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Range Model MGR5870 how to convert to propane
set the regulator to propane and change the orfices to the blk ones. copper is for nat gas / black for propane .. thanks hope this helped .mm
Dec 22, 2009 | Maytag MGS5870 Gas Kitchen Range
Dryer has been converted to propane using conversion kit #131776600 and I need the info needed to get it back to run on NG The dryer is a Fidgaire Gallery series model #FDGC648GHS0 any help greatly a
Hello there. If the parts were saved, they can be reused. If not, contact your propane provider and tell them that you plan to convert back to natural gas. They will be able to get you the kit you need, and will possibly have a technician come out and install it for a fee.
May 27, 2009 | Maytag Neptune MDG5500AW Gas Dryer
MayTag Neptune to Propane
go to sears.com to get the conversion kit which will contain detailed instructions.
Jan 01, 2009 | Maytag Neptune MDG9700A Gas Dryer
Sep 01, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Thank you, Roxanne
Mar 06, 2008 | Maytag Neptune MCG8000AW Gas Dryer
Dryers Logo
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
