Question about Canon IR 2535 Copier
Error code E000001 - Canon IR 2535 Copier
  • 66 Answers
SOURCE: Error E000001-0000
e001 is a fuser error. it might be able to be reset, but should be looked by a tech.
SERVICE MODE
*28*-press the additional func button, 2&8 at the same time, and the additional func button again.
when you have done it correctly, the screen will change and it will say service mode across the top.
Then select:
copier
func
clear
err
press the done or ok button on the lower right side of the screen.
turn the machine off at the black switch on the right side, wait 10secs, turn back on. should work.
****DONT MESS WITH ANYTHING ELSE IN SERVICE MODE YOU CAN REALLY SCREW UP THE MACHINE.!!!!!!!!!!!!!!!******************
Posted on Apr 23, 2009
SOURCE: ImageRunner 2230 Error E000001-0002
canon copier e000001-0002
Posted on May 11, 2009
PATHAMPAD
  • 25 Answers
SOURCE: Error Code E000001-0004
The main thermistor TH1 has poor contact or open circuit.The thermal switch TP1 has an open circuit.The fixing heater has an open circuit.The SSR is faulty or the DC controller PCB.After the main power switch is turned ON the temperature detected by the main thermistor does not reach 70 C.The error must be reset in service mode :COPIER - FUNCTION - CLEAR - ERR
Posted on Feb 13, 2010
  • 4 Answers
SOURCE: What is error code E000001-0004 and E000001-0010
This error code is a sensor in the side where paper jams usually occur open the door and look for a small sensor in black plastic, it will probably be not located properly these are known for dislodeging, Canon engineers simply glue them back in, switch off the power beofre doing this and when you switch back on it should load ok.
Posted on Apr 20, 2010
  • 149 Answers
SOURCE: What is error code E000001-0004 and E000001-0010 f...
there is a good possibility that the main thermistor and the sub thermistor has gone bad or is dirty. also it might need adjusted to be better placed next to the upper fixing roller
Posted on Jun 11, 2010
IRC 3380i error code E000001-0003 please help
get into service mode
To get into service mode.....
Press *
Then 2 & 8 together
Then *
then choose COPIER
then choose FUNCTION
then choose CLEAR
then choose ERROR
then press OK
turn power off and on
Sep 03, 2013 | Canon C3380i Color Copier
What is error code E000001-0004 and E000001-0010 for canon copier 8500
May 19, 2010 | Canon imageRUNNER 8500 Copier
Error code E000001-0003 canon clc2620n
it is a fusing/fixing error try this on the control panel press * with head 2&8 together *with head >copier>function>clear>err>ok turned off/on the machine hope this help
Oct 01, 2009 | Canon Office Equipment & Supplies
HAVE CANON IR C6800 WITH THE FOLLOWING ERROR CODE... E000001-00ff
moz-screenshot.jpgmoz-screenshot-1.jpgIt is a Fuser error code .
Could be a poor connection with the draw connector on fixing feeder unit.
Try shimming all three connectors on the fuser draw side can resolve the issue. Another thing to check is the upper fuser roller for flat spots this can also cause fuser error codes
May 07, 2009 | Canon imageRUNNER C6800 Copier
Error E000001 -0010
The error code is for the fixing assy not getting to the correct temperature in a specified time. The 0010 part of the code is indicating the copier was turned off and back on without resetting the error. To reset the code, Press the additional function button, then the numbers 2 and 8 at the same time and then the additional function key again. The display will now be indicating the service options available. Touch COPIER, then FUNCTION at the top of the display, the CLEAR in the middle, then ERR, then OK. Power down copier at the right side rear, then turn back on. If the error comes back then you will have to check the fuser assy to see if the front drive gear has failed or one of the thermistors has gone bad. Good luck
Mar 06, 2009 | Canon imageRUNNER 5570 Copier
I keep getting error codes
i am getting error E000001 -0010
Sep 16, 2008 | Canon imageRUNNER 5570 Copier
Canon IR 2535 Copier Logo
109 people viewed this question
old marine
old marine
