Xerox Workcentre Pro 420 error APS or AP5
When printing from a PC the above code appears on the Seven Segment Display and it does not print
4 Suggested Answers
checkitright
  • 1362 Answers
SOURCE: Xerox Workcentre Pro 123 error code 016-719
this is not a mechanical error but a software error.
It either doesn't recognise the format or program
as for the driver don't thinkit's the problem the HP can use PCL6
Posted on Sep 08, 2008
  • 31 Answers
SOURCE: le code erreur j7 pour
change le drum cartridge
Posted on Feb 03, 2011
babaprithi
  • 372 Answers
SOURCE: E6 error on Xerox WorkCentre
ur side or front covert is properly shut.u can cross check this by cheating the interlock switch with a screw driver.
Posted on Jun 06, 2011
How do I reset error code u4 using the control panel?
Switch off the M/C then press & hold zero button & on still when screen will display (---) then press '10' start button '1' start button. now your M/C showing 3 so you change it press '0' button then switch off &on
Oct 10, 2014 | Xerox Office Equipment & Supplies
Xerox workcentre pro 55 pcl xl error
We have a WorkCentre 7655 that has been working fine for ages but is now causing some issues. A user who is running Windows 7 32 bit edition is sending files to print (using the secure print function) - the system is reporting they have spooled fine to the printer - but when they go and release the document they are getting (more often than not) about 16 out of 21 pages (for example) and then a PCL XL Error (Subsystem: Text, InternalError 0x50, Operator: Text, Position: 8564). I have another document that 9 times out of ten will actually crash the WorkCentre completely and cause it to reboot mid way through printing.
The driver we are using is the latest: "Xerox WorkCentre 7655 rev 2.0 PCL6"
As mentioned the user is running Windows 7 - the printer is shared from a Windows 2003 Server which has the same version of the driver.
Jan 06, 2012 | Xerox WorkCentre Pro 575 - 550 Copier
Xerox workstation pro 428 error code 116-324
I did contact the Xerox support center and they did suggest the following fix:
reboot the printre --> pres the following buttons --> powersave + red stop button + nr 6.
This should empty the print memory.
Dont forget to remove all the printer jobs on the client computers.
Apr 30, 2011 | Xerox WorkCentre Pro 428 Copier
Xerox workcentre c2424 error code
One of two things most likely.
1. The wiper blade is stuck to the print head,or 2, The print head blosk has a lot of spill over ink built up in it.
That code is caused by the inability of the print head to move properly. Either left to right or pivot front to back to get into the print position.
You have to remove the covers to access the stainless steel print block. It is located about 2/3 of the way back on the lower left side of the frame. It is a one inch by one inch square block that may have a lot of buildup of spill over ink in it. If the wiper is stuck you have to remove the ink loader , where you add the ink sticks , to access the area between the print head and drum, It is a pink blade the is between the drum and print head, it wold be stuck to the print head not allowing it to move. Just carefully unstick it from the print head
Mar 27, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
WORKCENTRE PRO 420 U9 CODE
Hello sir; The U-9 code means the main control unit/switch board problem, replace it.
Feb 07, 2009 | Xerox WorkCentre Pro 423 Copier
How to do 'mirror' on photocopier
Hi, I made a mistake, sorry. It is not a 423 Greyscale etc.. that I own but a Xerox Workcentre pro 420 black and white photocopier. I have but no manual to find out how or if it has a 'mirror' or 'inverse' function. Thanks
Dec 14, 2008 | Xerox WorkCentre Pro 423 Copier
Sep 08, 2008 | Office Equipment & Supplies
43 people viewed this question
jasbo
jasbo
