Question about Acer Computers & Internet
Ini file sow inevilad boot INI file
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Acer Master
  • 2,226 Answers
That is your software boot devices doing that look for the file you need download it install it then you sould not have anymore problems
Posted on May 27, 2014
SOURCE: invalid boot.ini
<3 you guys.
Posted on Jul 19, 2008
  • 115 Answers
SOURCE: on boot-up the system stalls indicating a missing
you need to reinstall the OS.
Posted on Oct 25, 2009
  • 407 Answers
SOURCE: i cant open crossfire,it only
go to crossfire tutorials at VMWARE one
Posted on May 16, 2011
krihard
  • 407 Answers
SOURCE: can't find AsusSetup.ini in C:\Users\APPDATA\LOCAL\TEMP\Intel_chi[set_V9111019_XPVistaWin7\AusuSetup.ini
missing chip set file...load asus motherboard driver
Posted on Aug 05, 2012
krihard
  • 407 Answers
SOURCE: can't find AususSetup.ini
I have 2 HDD's in my PC - both with Win XP Prop
Boot.ini is correct, but looks default is booting from Disk2 and partition 1 which is your G:\ 500 GB.
Try Copying boot.ini from c:\boot.ini to g:\boot.ini It might help
In your example I see missing "\" after partition(1), may be typing mistake, but in real time can generate error.
You boot.ini looks exactly same in both drive c:\ & G:\
[boot loader]
timeout=10
default=multi(0)disk(0)rdisk(2)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(2)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="GUY DRIVE XP Professional" /noexecute=optin /fastdetect
Note: boot.ini will be hidden and readonly file. You need to unhide the file and remote the read only option and then only you will be able to save the boot.ini file
Hope this helps
May 22, 2010 | Microsoft Windows XP Professional SP2
Tip
How to remove Multiboot Option in Windows
If under various circumstances you had to install a second Windows OS on the same system, you should have already met the dual boot option. It will pop up before booting the system permitting the user to select which OS will boot.
Boot.ini, the house of the dual boot option Boot.ini is a system file found in the system root. Because it has a major importance for the booting process.so we have to edit this boot.ini file to remove multiboot popups.
How to edit Boot.ini
1.Go to Start Click on Run
2.Type msconfig.
Once the system configuration window pops up, you will notice that Boot.ini has its own tab. Select that tab and where you see "timeout," set it to a lower or higher value. Remove/Add Operating Systems in the dual boot menuThis is the main issue.
Step 1:Right click on My Computer icon and select Properties.
Step 2:From the properties window go to Advanced > Startup and Recovery > Settings.
Here, you can both edit the timeout value and modify the Boot.ini file by clicking Edit. If you remove the second operating system from Boot.ini, the dual boot option won't appear before booting.
For more details information visit How to Remove Multiboot Option in Windows XP
on Jan 08, 2010 | Computers & Internet
MY pc does not start anymore. I have a Seagate hard drive ST380011A. I got the message: The following fail is missingC:/windows rootsystem32hal.dll
<windows root>system32hal.dll. is missing or corrupt. â How to fix it?â The Hal.dll file is the first file that boot.ini tells the system to look for at boot. â Looking at it this way, this error message can be rather misleading. In fact the reason could be a number of things, such as: â The boot.ini file is actually corrupt or damaged, â or it is pointing the Startup to look in the wrong place. The Hal.dll file is located in the System32 directory of your %SystemRoot% which in a default XP setup is:â C:WindowsSystem32.â You can use the Dos boot disk (or NTFS Reader above) to quickly determine if the file is missing.â If it is, then you should extract it from your XP CDrom and place it in its proper location.Boot to your XP CDrom, and then choose 'r' to go to the Recovery Console.â With your XP Cdrom in the drive, issue this command:Expand D:i386hal.dl_ C:Windowssystem32â â (This assumes the CDrom is D and your System Partition is C) â If this does not cure your issue this may be due to issues in your boot.ini file.â â The boot.ini file is actually corrupt or damaged, or it is pointing the Startup to look in the wrong place. Resolution:â The easiest way to fix this is to boot to the Recovery Console and replace the old boot.ini with a new one.â Once you have booted to the Recovery Console run these commands at the prompt:Attrib -H -R -S C:boot.iniâ â â (This removes the attributes and allows deletion). DEL C:boot.iniâ â â â â â â â â â â â â â â â â â (Deletes the corrupted boot.ini file)â â â â â â â â â â â â â â â â â â â â â â â â â â â â BootCfg /Rebuildâ â â â â â â â â â â â â â â â (Recreates the new boot.ini file)If you would like to view the boot.ini file, you will need a boot disk to get to the DOS prompt.â If you have formatted with FAT32, then you may use a Windows boot disk (such as a W98 disk), but if you are running NTFS, you will need a NTFS reader boot disk, such as NTFS Reader For DOS which is available for download here.â To diagnose the problem, copy the boot.ini file from the hard drive (C:boot.ini) and open it with Notepad.â You will want to verify that the "Default=" line as well as the ARC path line are pointing to the right location.â Here is two examples of boot.ini files (ARC paths start with multi): [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS [operating systems] multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Professional" /fastdetect This is a sample of the above Boot.ini file after adding another partition running Windows 2000 Professional. [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS [operating systems] multi(0)disk(1)rdisk(0)partition(1)WINDOWS="Windows XP Professional" /fastdetect multi(0)disk(0)rdisk(0)partition(2)WINNT="Windows 2000 Professional" /fastdetect â â
Nov 20, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
I have the same problem with dual boot Windows 7 and XP Pro
To find the actual boot.ini file you will have to make hidden operating system files visible. To do this, open a folder such as My Computer then go to Tools>Folder Options. Within the new window that appears, select, "View" at the top. Now scroll down just a little ways and un-check, "Hide protected operating system files (Recommended)." Now press OK.
Afterward open up My Computer (if it isn't already open) and double-click on your C:\ drive to look at its files. Within this region you should find the file named, "boot.ini."
NOTE: I do not recommend editing this file, as one mistake could corrupt your installation of Windows preventing you from starting Windows successfully. If you do edit the file, you do so at your own discretion and I in no way am responsible for any damages you cause through editing the boot.ini file.
Hopefully that's the information you were after. If not, let me know and I'll see if I can assist you further.
Mar 23, 2009 | Computers & Internet
Invalad BOOT.INI File from C:\winnt\ NTDETECT
You have to rebuild the boot.ini file. That is going to require a disk and do a repair install. Or the MBR (Master boot record) is corrupt. Software like Paragon partition manage can check your MRB and see is it is pointing to the correct boot.ini file path.
Jan 16, 2009 | HP OmniBook XE3 Notebook
BOOT.INI deleted. How to re-create this file?
type in run "cmd" then presss enter then type "bootcfg /?" it gives u some help .
Dec 28, 2008 | Microsoft Windows XP Professional for PC
Hello, I have 2 Operating Systems in a computer namely Windows XP(SP3) in C:\ & Windows Server 2003 in D:\ . I've deleted the file BOOT.INI accidentaly form X:\ drive(X:\ means all drives like...
That's not a virus. Boot.ini is a default file needed for Windows OS to boot.
Fortunately, you can recreate the boot.ini files
This is a sample of the above Boot.ini file with a previous installation of Windows 2000 on a separate partition. [boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Windows XP Professional" /fastdetect
multi(0)disk(0)rdisk(0)partition(2)\WINNT="Windows 2000 Professional" /fastdetect
Simple way to add operating system on a separate partition:
At the command prompt, type: bootcfg /copy /d Operating System Description /ID# Where Operating System Description is a text description (e.g. Windows XP Home Edition), and where # specifies the boot entry ID in the operating systems section of the BOOT.INI file from which the copy has to be made.
timeout=30
[operating systems]
Please rate this if you found this answer helpful. :)
In my pc there is an problem of NTLDR missing . why this ill occure?
  1. Create a Windows 2000 boot disk that contains the following files: Ntldr
    Ntdetect.com
    Boot.ini
    Ntbootdd.sys For more information about how to create a boot disk, click the following article numbers to view the articles in the Microsoft Knowledge Base: 301680 (http://support.microsoft.com/kb/301680/ ) How to create a boot disk for an NTFS or FAT partition in Windows 101668 (http://support.microsoft.com/kb/101668/ ) How to use a Windows boot disk to prevent boot failure
  2. Modify the Boot.ini file to point to the correct hard disk controller and to the correct volume for your Windows installation. For more information about how to create a boot disk, click the following article number to view the article in the Microsoft Knowledge Base: 311578 (http://support.microsoft.com/kb/311578/ ) How to edit the Boot.ini file in Windows 2000
  3. Insert the boot disk into the computer's floppy disk drive, and then restart the computer.
  4. Copy the Ntldr file, the Ntdetect.com file, and the Boot.ini file from the boot disk to the system partition of the local hard disk.
Method 2: Use the Recovery Console loadTOCNode(3, 'summary');
  1. Use the Windows 2000 Setup disks to restart the computer, or use the Windows 2000 CD-ROM to restart the computer.
  2. At the Welcome to Setup screen, press R to repair the Windows 2000 installation.
  3. Press C to repair the Windows 2000 installation by using the Recovery Console.
  4. Type the number that corresponds to the Windows installation that you want to repair, and then press ENTER. For example, type 1, and then press ENTER. For more information, click the following article number to view the article in the Microsoft Knowledge Base: 229716 (http://support.microsoft.com/kb/229716/ ) Description of the Windows Recovery Console
  5. Type the Administrator password, and then press ENTER.
  6. Type map, and then press ENTER. Note the drive letter that is assigned to the CD-ROM drive that contains the Windows 2000 CD-ROM.
  7. Type the following commands, pressing ENTER after you type each one, where drive is the drive letter that you typed in step 4 of "Method 2: Use the Recovery Console," of this article: copy drive:\i386\ntldr c:\
    copy drive:\i386\ntdetect.com c:\ If you are prompted to overwrite the file, type y, and then press ENTER.
    NOTE: In these commands, there is a space between the ntldr and c:\, and between ntdetect.com and c:\.
  8. Type the following command, and then press ENTER: type c:\Boot.ini A list similar to the following list appears: [boot loader]
    timeout=30
    default=multi(0)disk(0)rdisk(0)partition(1)\WINNT
    [operating systems]
    multi(0)disk(0)rdisk(0)partition(1)\WINNT="Microsoft Windows 2000 Professional" /fastdetect
    If you receive the following message, the Boot.ini file may be missing or damaged:The system cannot find the file or directory specified.
  9. If the Boot.ini file is missing or damaged, create a new one. To do so, follow these steps:
    1. Use a text editor, such as Notepad or Edit.com, to create a boot loader file similar to the following boot loader file:[boot loader]
      timeout=30
      [operating systems]
      For more information, click the following article number to view the article in the Microsoft Knowledge Base: 102873 (http://support.microsoft.com/kb/102873/ ) Boot.ini and ARC path naming conventions and usage 301680 (http://support.microsoft.com/kb/301680/ ) How to create a boot disk for an NTFS or FAT partition in Windows
    2. Save the file to a floppy disk as Boot.ini.
      NOTE: If you used Notepad to create the file, make sure that the .txt extension is not appended to the Boot.ini file name.
    3. Type the following command at the Recovery Console command prompt to copy the Boot.ini file from the floppy disk to the computer: copy a:\Boot.ini c:\
  10. Type exit, and then press ENTER. The computer restarts.
Dec 05, 2008 | Computers & Internet
Invalid boot.ini
One of these two methods should fix your problem......... -------------------------- go to run and type in MSCONFIG. Then click on the "Boot.ini" tab. First, make sure if using XP Pro that the following is listed: [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect - this is the boot.ini information from XP, straight from the Microsoft Web Site. All the information below [operating systems] should be on one line! If you have a blank boot.ini file, copy and paste this information - if all information is already there, then don't change anything. Next, click the button that says "check all boot paths". You should get back a message stating that everything is good (the computer checks to make sure the boot.ini file is compatible with Microsoft Operating Systems). Next, assuming your computer likes the boot.ini file that is in there (and it should), then click the button that says "set as default". By doing this, you have now created a new (modified) boot.ini file that is a carbon copy of the original. Click apply. You will be prompted to restart. Before doing so, go back to MSCONFIG and in the general tab you will see that "use modified boot.ini" should now be checked. During reboot, you should not get the invalid boot.ini message (at least I didn't). What you will get is a message (after reachign the desktop) stating that you are not using the defaults or something like that and do you wish to go back into MSCONFIG to restore the default settings. Since your new boot.ini file is exactly the same as your original, click no and check the box to hide that irritating message. ------------------------ Or you can try this method.... right click on my computer go to properties then click the advanced tab then cilck settings under start up and recovery under system startup then click edit and paste [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect --------------------------------- Peter
Oct 04, 2007 | Intel Motherboard
Computers & Internet Logo
29 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
