Xerox Workcentre Pro 420 error APS or AP5
When printing from PC the above error is reported
  • 208 Answers
SOURCE: Can't print envelopes
Solution Title: How to print on COM10 envelops from the Bypass tray (PCL6) using a Windows 2000 O/S Resolution/
Solution
thumbsup.gif Fixed! thumbsdn.gif Did not fix. Resolution Role: Fix
Critical Message: The Envelope must be placed in the Bypass Tray face down (flap side up) and Long Edge IN. In Microsoft Word (Word 2000)
    1. Under the Tools tab, select Envelopes and Labels.
    2. Enter your Delivery and Return addresses.
    3. Click on Options
    4. Under Envelope Options; [Envelope size], select Size 10 (41/8 x 91/2 in)
    5. Under Printing Options, select Portrait (LEF) - Long Edge Feed
        • As Feed from, select Tray 5 (Bypass)
    6. Click <OK>
Within the WorkCentre Pro 123/128 print driver
After opening up the print driver [<Start>, <Settings>, <Printers>, double-click on the WCP 128 PCL6 driver], click on Printing Preferences under the General tab.
  • Under the Paper/Output tab
Set the following features as follow:
    • Job Type: Normal Print
    • Paper Size: COM10
    • Output Size: Same as Paper Size
    • Image orientation: Portrait
    • Image Rotation: OFF
    • 2 sided Print: 1 sided Print
    • Stapling: None
    • Output destination: Center Output Tray
    • Offset Stacking: None
  • Under Tray/Layout
  • Set Paper Source to Tray 5 (Bypass)
  • Click on Bypass Tray Settings
    • Paper Type: Heavyweight (1 or 2)
    • Feed orientation: Portrait
  • Click <OK>
  • " on Specify Paper Type and select Heavyweight (1 or 2)
  • " (Apply> and <OK>
  • " <OK> again
In Microsoft Word under Envelopes and Labels, Click <Print> to send the information to the printer.
Note: This setup represents one way of printing envelopes. Other ways setting up some features in a different manner will work as well.
Solution v1.3.20.0 312637.How to Print on COM10 Envelops From the Bypass Tray (PCL6) 2006-04-05 21:57:29
Posted on Nov 28, 2007
checkitright
  • 1362 Answers
SOURCE: Xerox Workcentre Pro 123 error code 016-719
this is not a mechanical error but a software error.
It either doesn't recognise the format or program
as for the driver don't thinkit's the problem the HP can use PCL6
Posted on Sep 08, 2008
  • 3 Answers
SOURCE: Xerox WC Pro 35 - Error 14-563
this code means your scanner has failed to setup correctly. this could be a problem that you would need a qualified tech to service the copier. there is nothing that you can do after you power off and power on (popo) the copier. it could be voltage, pwb board, or a binding scanner assembly.
Posted on Oct 07, 2008
  • 2072 Answers
SOURCE: Xerox Workcenter Pro 657 Memory Error
With a 657, most likely the main board has failed. It is not uncommon at all, That is a general problem with that model.
What you can try is, looking from the front of the machine, the main board is located on the back right side. removing 2 screws and releasing the levers will allow you to slide the processor board out of the machine. You can try just reseating,,,, removing and shoving the board back into the machine, and seeing if that helps.
Most likely, either the board has failed, or the memory battery had exceeded its life and the memory is not working.
Wish I had a more positive answer for you, but the 657 is getting older, and those lithium batteries are failing. I have to add though, that those processor boards, have failed pretty frequently over the years.
What you can do is go onto Google and look up "the parts drop" ,,, call them and ask for Britt, and see what he has as far as that producut is concerned. That machine is actually made byn Toshiba, you may be be able to find either a Xerox, or Toshiba repair dealer in your area that has that board and will fix it reasonably. If you find a Toshiba dealer other than a Xerox dealer. Tell them it is the same machine as a Toshiba E-120, they are exatly the same.
Posted on Oct 17, 2008
  • 990 Answers
SOURCE: WORKCENTRE PRO 420 U9 CODE
Hello sir; The U-9 code means the main control unit/switch board problem, replace it.
Posted on Feb 07, 2009
Xerox workcentre pro 55 pcl xl error
We have a WorkCentre 7655 that has been working fine for ages but is now causing some issues. A user who is running Windows 7 32 bit edition is sending files to print (using the secure print function) - the system is reporting they have spooled fine to the printer - but when they go and release the document they are getting (more often than not) about 16 out of 21 pages (for example) and then a PCL XL Error (Subsystem: Text, InternalError 0x50, Operator: Text, Position: 8564). I have another document that 9 times out of ten will actually crash the WorkCentre completely and cause it to reboot mid way through printing.
The driver we are using is the latest: "Xerox WorkCentre 7655 rev 2.0 PCL6"
As mentioned the user is running Windows 7 - the printer is shared from a Windows 2003 Server which has the same version of the driver.
Jan 06, 2012 | Xerox WorkCentre Pro 575 - 550 Copier
How to print auditron report (copy) from workcentre pro 128? Need step by step instructions- have no manual
Printing Service Reports
1. To access Service reports, follow the Entering UI Diagnostics procedure.
2. After entering the Access Number, press the Machine Status button on the Control
Panel.
3. Select the Billing Meter/Print Reports tab on the display.
4. Press the Print Reports/List button.
5. Press the CE button.
6. The following reports can be printed.
• Debug Log Report
• HFSI Report
• Jam Report
• Shutdown Report
• Failure Report
• Protocol Monitor Report
7. Select the required report and press the Start button. The selected report will be printed.
Jun 11, 2010 | Xerox WorkCentre Pro 123/128 Printer
H2 Blinking on the panel
Error code means that:
H2 Thermistor Open
Part #
Xerox Workcentre Pro 16FX, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
Mfr Part #: RDTCT0128FCZZ
Mfr Part #: CTHM-0019DS52, CTHM-0019FC52
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
How to open a message???help!!!!!
On the console you should find menu buttons. Find jobs or job prints. Select your number job and print it.
The menu buttons have many features you can scroll through. The print reports can print out the menu of the different menus of the fax machne.
good luck.
Feb 17, 2009 | Xerox WorkCentre Pro 785 Plain Paper Laser...
Feb 07, 2009 | Xerox WorkCentre Pro 423 Copier
How to do 'mirror' on photocopier
Hi, I made a mistake, sorry. It is not a 423 Greyscale etc.. that I own but a Xerox Workcentre pro 420 black and white photocopier. I have but no manual to find out how or if it has a 'mirror' or 'inverse' function. Thanks
Dec 14, 2008 | Xerox WorkCentre Pro 423 Copier
Sep 08, 2008 | Office Equipment & Supplies
43 people viewed this question
jasbo
jasbo
