Question about Lands Phones
My Facimille with digital answering machine,it is about 18 yrs old works fine but need instruction how to change the answerphone message, it is a Sharp Fo-455 model
SOURCE: Error message Sharp FO-4450 Fax machine
Press life "2" start for toner.
And life "3" start for drum.
These will reset the counters.
If you are having a "check drum error" then you have broken the sensor arm that is attached to your lid.
Call a technician in your area.
Jeff
Posted on Jan 16, 2008
cindystauart
SOURCE: How to retrieve messages from the answering machine ..remotely
Remotely Operating Your Answering Machine
Call your telephone number and wait for the answering machine to answer. If the answering machine is off, it will answer after about 10 rings and series of beeping sounds.
During the greeting message (or a series of beeps when the answering machine is off), press [0] and enter your PIN code within 2 seconds (see "Setting a Security Code or Personal Identification Number (PIN)" on page 54).
The answering machine announces the current time and the number of messages stored in memory. You hear "To play incoming messages, press zero-two. For help, press one-zero." You will hear a beep.
Enter a remote command within 15 seconds, each command there after must be entered within 2 seconds.
Posted on May 12, 2008
SOURCE: change # of ringer on an AT&T 1717 digital answering machine
how do i change number of rings before the answering machines toll saver activates.
Posted on Nov 05, 2008
SOURCE: uniden telephone answering machine
I need a manal for exs9950
where can i download the manual
thanks
Frichmond1@yahoo.com
Posted on Mar 12, 2009
  • 16 Answers
SOURCE: Conair TAD-1220 Digital answering machine
Background: The TAD1220 does not have a way to manually delete messages. It more or less has a FIFO(FIRST IN-FIRST OUT) method of retaining messages. It will save up to 14 minutes of messages and then they are deleted automatically after you play them back and receive another incoming call.
This is important:
It will only erase the messages AFTER you have listened to them *AND* received another message.
Exception: If you happen to press the STOP/SAVE button, then all of the messages will be RE-SAVED until the memory limit has been reached.
Extreme Solution:
The only manual way is to remove the battery, disconnect the power cord and erase everything. You will then need to reprogram your greeting.
Posted on May 21, 2009
Why won't my answerphone work properly?
Either you must set your home answering machine to answer on fewer rings OR disable the phone company's message system.
Nov 19, 2011 | Lands Phones
When testing the outgoing message the volume seems
http://www2.bt.com/static/i/media/pdf/response_75_userguide.pdf
If you click on the above , go to p.11,12 on setting the volume .
I agree with everything you say the only thing I can add is you may not be setting the volume correctly see note on p12.
Hope i`ve helped.
Dec 10, 2009 | British Telecom Response 75 Digital...
One tel magma 300 - can't change message on answerphone
1) Press the 'tape' symbol to access the answering machine mode.
2) Press 9 then 1 for 'answer and record'.
3) Whe you hear a 'beep' speak your message. Whilst recording the display shows REC OGM1 or REC OGM2
4) Press 5 to stop recording. Your message is played back to you
5) Press 'tape' symbol to exit.
To check your Out Going Message (OGM)
1) Press 'tape' symbol
2) Press 6 then 2 and the message is played back.
Jan 26, 2009 | GE 29888GE1 Digital Answering Machine
Panasonic Auto-Logic 2line syst dual standard cassette needs help
If the unit answers reliably but isn't recording, it probably just needs new cassettes, new drive belts and a good head cleaning. If you can find a service shop that works on cassette decks, they could probably look at the machine for you. These are the same things you need to do to a stereo deck occasionally.
On the other hand, if the machine is not picking up at all sometimes, there may be electronic problems and you might have to check Panasonic's website for service options. Parts availability for something this old could be an issue.
Dec 15, 2008 | Panasonic KX-TM150B Digital Answering...
I have a GE CID Speakerphone with answering machine and need to change the message.  How do I do this?
Hi
Just disconnect the phone from the mains for a minute and then reconnect. The old message on your answerphone is erased and replaced by the default setting message but you can record over that by pressing and holding the greeting button.
Cheers from Ireland
Dec 01, 2008 | GE 29385GE1 Corded Phone
How do i change the answerphone message on Kala Vox 300 DECT Digital?
go to this link and you'll find the pdf
http://www.dectcordlessphones.co.uk/userguides/philips/philips_Kala_300.pdf
Jul 03, 2008 | Lands Phones
Cant retrieve answerphone messages
I HAVE AT&T 5.8 digit  phone I have thrown the box and the instruction in the trash ands I can not remember how to retrieve messages
May 30, 2008 | Lands Phones
Philips model cd135
Hi there Fred
Here are links to user guides for your unit. Good luck, thanks for using FixYa
http://www.p4c.philips.com/files/c/cd1302s_73/cd1302s_73_qsg_eng.pdf
http://www.p4c.philips.com/files/c/cd1353s_05/cd1353s_05_dfu_eng.pdf
regards
Graeme
Mar 15, 2008 | Lands Phones
Philips Kala 6523 Cordless Phone
hi, do you have instruction manual i cant find mine. i have been using an other phone and gone back to this one but need to change answer machine message can you hlep please. patem
Feb 09, 2008 | Philips Kala 6523 Cordless Phone
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
