Question about Garden
John deere parts
Blade engages but then kicks out
    Sergeant:
  • Garden Expert
  • 417 Answers
I'm not sure what you mean by "kicks out". That's not proper terminology, sorry.
Posted on Nov 23, 2013
5 Suggested Answers
computus
  • 487 Answers
SOURCE: I have a john deere
Hi, sounds like the clutch. If you feel confident you can strip the mechanism down, clean and replace, otherwise its a new clutch.
Posted on Aug 29, 2010
dontbother10
  • 2220 Answers
SOURCE: what part number oregon chain do i need for a
Hello Sam;
I cannot find anything by Deere (probably an efco 152) about your saw. Oregon does list some particulars here:
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
I input:
John Deere; CS52; *see below; All (0.325"); All (0.050"); All (yours is likely green - low kickback).
*16" - 66 drive links (the part that fits in the bar).
*18" - 72 drive links.
If your saw does not use either 66 or 72 drive links I suspect the bar, drive sprocket, or drive sprocket and bar nose in use are not what the the saw was originally supplied with. Any local chainsaw seller/mechanic given your chain as a pattern can fabricate one in about 5 minutes. Often a local chain is less expensive (no shipping).
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
efcoPower.com
http://www.efcopower.com/indexPri.jsp
Posted on Sep 07, 2010
Testimonial: "This is very helpful. Thank you."
philwalker78
  • 608 Answers
SOURCE: do i instal the bends
Up, regards Phil.
Posted on Aug 07, 2011
vanherringto
  • 1738 Answers
SOURCE: john deere 325 garden tractor. bought it used, can't get blade bolts loose to replace blades. is there a trick?
Check to make sure the bolts are not 'left hand threads' which loosen by turning clockwise.
Posted on May 24, 2012
John deere d140 lawn mower shoots of when i ingage the blades
Here's the link and I'm sure you will get the solution of your problem.
JOHN DEERE D140 SERVICE REPAIR MANUAL
May 04, 2017 | John Deere Garden
I have a John Deere 355d lawn tractor. Every time I engage blade or release brakes the mower dies out. Checked safety seat switch and its not that.
Try pulling up on your PTO switch to engage the RIO switch. If it works then there is a problem with the reverse switch is located near the directional pedals/linkage or on the transmission. Attached is a picture of the switch from the John Deere parts catalog and a wiring diagram.
Feb 13, 2016 | John Deere Garden
John Deere X304 PTO Engagement Problem When Warm
Hi, check your belt tension, check all idler pulleys and drive pulleys for free rotation with the belt off and finally check that the belt is not bottoming out in any of the drive pulleys. If so, replace the belt. The blades should come up to speed imediately wether hot or cold and it sounds like your belt is slipping in one or more of the pulleys which drags the motor revs down until it grips. Regards Phil.
Jun 13, 2012 | John Deere Garden
John deere f935 blades engage but will not lock into egaged position
If you want to solve your problem, click on the link I attach.
Best Manuals
Apr 25, 2012 | John Deere Garden
John Deere 318 blades won't engage once it gets hot.
Check the clutch gap in the front of the machine (the one that engages the belt) by tightening or loosening three lock nuts around clutch. Tightening decreases gap/ loosening increases gap. Note: do not tighten too far as it will result in clutch drag or lockup! Stop when its just starting to touch then back off slightly. Also without a proper charge on the battery the magnetic power for the clutch is altered and not strong enough to engage clutch when hot. Find out why battery light is on.
May 01, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Oct 02, 2009 | John Deere Garden
John Deere LA110 mower blades got disengaged
yes. your mower has a blade engagement cable attached to the drive sheve. i am providing a link to the manual which shows this.
http://manuals.deere.com/cceomview/OMGX22464_C8/Output/Index.html?tM=HO
Jun 25, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Fuse blows when engage blade
The electro-magnetic coil side of your PTO is shorted out.On the 318 it is very easy to replace,just under front screen.
Apr 04, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
