Question about Audiovox Richmond 6G40-36F 6-Year Tall Gas Water Heater
Richmond water heater 6g40-36f1 leaks from safety valve
5 Suggested Answers
  • 74 Answers
SOURCE: water heater not heating it's a richmond water heater
Now change the thermostats........this is the only other thing it could possibly be.
Posted on Apr 27, 2009
  • 154 Answers
SOURCE: I GET NO HOT WATER
needs drop tube or full replacement
Posted on Aug 01, 2009
  • 1015 Answers
SOURCE: my water heater is leaking
First shut off power then remove acess cover and carefully move insulation out of the way so you can see around elements.Check to see if leak is coming from around element.If it is determine what type of element you have. Either screw in or bolted in. Both have thick rubber gaskets that can be replaced by draing water heater and removing element then install new gasket and reinstall element.
To drain heater shut off valve on incoming cold water supply line ,make sure electric power is off. Connect drain hose to drain valve and put other end to floor drain or sump basin.You can open faucet on hot side near by to prevent vacumn and drain. If you have screw in type disconnect wires,marking them for reattachment,then use large open end wrench or pipe wrench on hex section of element and turn to left to remove. If you have bolt in element spray bolts with wd-40 or similar and carefully loosen bolts then disconnect wires and remove element.install new gasket and reverse to reinstall. I would recommend that you replace elements at this time if you are sure this was the source of the leak.
If you don't think it's leaking around elements then check fitting on both water lines to water heater to be sure they are not leaking and seeping down thru insulation and leaking out of the bottom of heater. Next check around drain valve for leak and if it's leaking you can try tightening it a little or replace it with 3/4 x2 brass nipple and 3/4 inch female iron pipe boiler drain. Use teflon tape or pipe joint compound on all threaded connections.
After you have eliminated all other sources for leak then it is probably the tank itself. If it is less then six years old the tank should still be covered under warrenty. Most warrenties will give you a new heater but installation will not be covered unless you have extended service coverage.
I hope this helps you some. Thank you
Posted on Dec 27, 2010
  • 5089 Answers
SOURCE: What's your problem?my richmond hot water heater model 6g40pv shut of and is flashing fvd interphase failure. how do i reset it
Tom W must have been 'recommended answer' from past answers, and not live answer.
What did Tom's answer say?
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Posted on Mar 22, 2013
Richmond direct vent water heater
The pilot lights then heats/sends a signal to open gas for burner then(burner)should stay on but if valve shuts the gas off,then have your unit checked. What ever you do,DON'T MESS WITH IT IF GAS/FLAME ON!!!!!. These systems come with a safety feature that allows gas to go on only when safe!!!!
Mar 30, 2014 | Water Heaters
I have a richmond gas hot water heater 6g40-36f1i want to know where is the outer door located at so i con turn it on
The gas pipe should have an accessible valve to turn off the gas.
This is gas so you have to read the manual. There is no easy way around that. You are responsible for knowing the contents of the User's Manual, including the safety warnings.
With electricity you can only kill yourself but gas includes a force multiplier so that you can injure other people as well.
Sep 29, 2012 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Burner wont stay light
Unknown if you have water heater with FV system, or older water heater. If this is new Rheem-Richmond heater, the TRD could be tripped because of clogged air intake, inadequate air supply, improper venting, overheating.
Gas control valve could be bad. Ait in gas line. Low gas pressure. etc
Copy following link for general gas water heater troubleshoot, and troubleshoot by type of gas control valve.
Aug 08, 2012 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Richmond water heater goes into lockout condition, ignition failure and I have to turn the blower switch off then on to get the water heater to work. Its getting to be a everyday thing. Also would like to...
Start-point is to inspect and clean burner parts and combustion chamber, clean air intake, bleed air out of gas line, test gas pressure, test electronic gas control valve, check for venting issues.
As general rule, gas water heater manuals recommend professional service once a year that would cover most items listed above.
To see images, and for more reading and resources, look at your product manual and open following link:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Richmond/Rheem sells power vent blower assembly that cost about $300.
Your product manual shows part numbers.
http://www.monstermarketplace.com/heating-supplies/rheem-sp12562-blower-assembly-powervent-2
Replacement gas control valve costs $300
Aug 16, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Its leaking around bottom and misting out lower vent
Get ready to replace. I have been notified of this problem about 30 times and each time the water heater dropped its load within 10 days. I was always replacing water heaters.
BUT if it is the pressure valve that is leaking then that alone can be replaced. That prevents the heater from blowing up.
Mar 20, 2010 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Audiovox Richmond 6G40-36F 6-Year Tall Gas Water Heater Logo
Top Audiovox Water Heaters Experts
paulcarew
jdthefixer
Richard Lindsey ...
Are you an Audiovox Water Heater Expert? Answer questions, earn points and help others
