Question about Alcatel lucent os6250-p24 chas225wac poe 24 poe rj45 pt config os6250
No firmware installed in os 6250
No boot stream seen in terminal window
  • mohammad saleh aburub
    mohammad saleh aburub Nov 24, 2013
    I don't have any option to access or explore the CPEs via console even I used the correct cable, some of CPEs don't display boot screen as others
    How I can install the boot file
Install english Windows XP on Japanese Panasonic CF-Y7. Simply insert OS CD and reboot does not help. Computer does not read CD.
The BIOS is probably configured to look for a bootable operating system on the hard drive before it looks at the CD drive. When you first turn on the computer, you have to hit a particular key to enter the BIOS setup (I don't know what it is for your model, but for most of the Japanese models I've seen it's the delete key. The startup splash screen should tell you what key it is. You have to hit the key before the splash screen goes away, otherwise it's already booting up from the hard drive.
Once you get into the BIOS, you can select the boot option page and move the CD drive up above the hard drive in boot priority. If the OS is in the Japanese language, the BIOS text may also be in Japanese. You can probably download an English-language BIOS firmware update to change that.
Oct 22, 2011 | Panasonic Toughbook y7 Notebook
I INSTALL WINDOW XP 2006 IN MY MAC BUT NOW WHEN I START MY LAPTOP THEN I HAVE SEEN MESSAGE NO BOOT DEVICE PRESS ANY KEY MEANS MY WINDOW IS NOT OPEN
When you turn on the computer again, hold the Option (a.k.a. the Apple key) and a new screen should pop up asking with partition you want to boot into.
Feb 28, 2011 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Insataling windows xp problms
i believ ur using 32 bit operating system.change the boot sequence by pressing F12 at restart and select cd/dvd rom option while the windows cd still inside the drive,,format the c drive completely{if possible format the whole hdd} and then reinstall the windows os xp..i hope it will work fine,,just follow the screen prompts very very carefully and u will find everything mentioned,,best of luck
May 14, 2009 | HP Compaq Presario CQ60Z Notebook
Can the two operating system can be installed in same drive ?
Yes, you can have multiple OS's on the same hard drive, and partition. I've seen it and have done it before to my machines. You can choose at the boot menu which one you want (when installed), and can run Linux or XP, Vista, Mac OS... my personal favorite is a small OS called "SliTaz". It's a light, Linux-based OS that is very functionable to the user.
Mar 14, 2009 | Microsoft Windows XP Professional With...
HP NC6320 - drive not detected or found during OS install
That is a possibility that it has a data protection. Try this http://www.ptdd.com/manual2.htm download the super FDisk and burn the ISO to a DVD. then boot off of it and delete all partitons on your HDD that way it will be erased so you can start over new. You might be able to do this on HPs boot disk too. Unfortunately you cannot update the HDD firmware after the drive has no OS on it. In this case you need an outside tool to totally erase the HDD so the install can see it again.
Feb 03, 2009 | HP Compaq nc6320 Notebook
Removing password on T30
YES.... providing that the hard drive was not completely re-formated before the windows OS was installed.
Usually, manufacturers leave a section of the HD for this so in the event that something goes wrong, you would be abke to revert back to the manufacturer's setup.
Simply follow the following instructions... :
1) remove power from the T30.
2) hold or tap the 'G' key on the keyboard
3) apply power back on T30 while maintaining step 2)
4) turn on T30 via power button while maintaining step 2)
5) T30 should eventually boot up and in factory default settings.
If this doesn't work, repeat process or the T30 was configured to disable the 'G' key. In this case you need to reflash the firmware on the T30.
Aug 29, 2008 | Compaq EVO T30 Network Terminal
Won't boot up to windows
Hi
Probably sum system file is deleted from ur system and its showing this problem.
Do u hav a bootable OS CDROM. If yes run it and boot ur PC in command prompt.Then type SFC \SCANNOW(remember there is a blank space between SFC and scannow).
It will then ask u to insert ur OS CDROM and hopefully it will restore all origional file without disturbing ur installed OS.
If this does not solve ur problem then unfortunately u hav to reinstall new OS.
Jun 08, 2008 | Compaq Evo N410C Notebook
Fail to load files during text mode setup
Maybe its a software problem, have you tried putting in a bootable XP installation CD? After the bios boot and it asks you to boot to CD, press R for repair, it will try to repair your OS, and if it is an OS problem ,then it will boot once again... If not you can try formatting your HDD and reinstalling windows...
Mar 10, 2008 | Toshiba Satellite A65-S126 Notebook
Boot problem
Was the operating system installed on another computer? Or a computer with different hardware? If so the drivers for the hardware are not configured properly on the HD or in the BIOS. If this is the case you should format the HD and re-install the OS.
Aug 15, 2006 | Jetway N2VIEW Motherboard
Alcatel lucent os6250-p24 chas225wac poe 24 poe rj45 pt config os6250 Logo
65 people viewed this question
Top Alcatel Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you an Alcatel Computer and Internet Expert? Answer questions, earn points and help others
