Question about AEG B8871-4 Electric Single Oven
Lower oven element not working
How do you get to it to remove/replace the lower element?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 107 Answers
You have to do it from rear
Posted on Nov 22, 2013
Hello, We have a bosch hbn7052gb oven. The lower oven flashed and now the bottom oven doesn't heat up, everything else works ok the fan, the top oven etc. Can you advise what needs...
Bottom element has failed. Probably 2 screws at rear to remove & replace. Disconnect fast-ons from rear - extract element - replace. best to get electrician to do this - simple job & element should be inexensive. - Rick
Jun 11, 2011 | Bosch Ovens
Maytag electric oven model cwe5800acb. The lower element in the upper oven will not heat up. Can the lower element be replaced without removing the oven from the wall.
Yes, replace the lower element by first turning off the circuit breaker to the oven (110V is still to half of the 220V element circuit even though the oven setting is turned off), then unscrew the two screws holding the element to the back wall of the oven, then pull the element out (may have to tug it a bit to get the connectors through the insulation), and pull the wire connector clips off the element.
Mar 14, 2011 | Maytag CWE5800A Electric Double Oven
The oven does'nt seem to be able to heat up above 150, the fan is working, the bottem half of the oven does'nt seem to heating up. Is this fixable or do i need a new oven?
Hi.
If the part that is not heating is only the bottom element, and the top element is heating regularly, then you may need to replace the lower element.
Before replacement the element can be tested removing it from the cavity and reading Ohms at the element terminals, with a multimeter set at Rx1. Disconnect power before removing the element.
If both baking and broiling element do not heath above a certain temperature instead, then the part to be replaced is the temperature probe, still located inside the oven cavity.
Regards.
Mar 04, 2010 | Whirlpool RBS275PD Electric Single Oven
Bake at low temp. Heating element vs control board
you need a meter that checks voltage (220) and continuity. turn off breaker remove screws that hold element in carefully pull it out just enuff to remove wires.remove wires check for continuity on element if there element is good. tape the leads to the wires turn on breaker, turn on oven if no 220 volts bad board or broken wire.
Feb 17, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
Jenn-air ww30430w dual oven, lower oven, lower element not heating, upper broil element working fine
Most likely a bad element. Turn off the power to the oven. Remove the racks.
Use a phillips screwdriver or 1/4 inch nut driver to remove the mounting screws at the back of the oven cavity to remove the element. Carefully pull the element out and remove the wires. Do not let the wires fall back into the holes.
Use a volt meter set for continuity. Touch one meter lead to one terminal on the element. Touch the other meter lead to the other terminal. If you get NO reading the element is bad.
A new element will correct your problem.
If the element reads as good you have a wiring problem or a bad control.
Jan 03, 2010 | Ovens
The lower element in my Admiral Sentry stove is not working. there is no layout for fuses so not sure what fuse needs replaced
It is not a fuse issue. Turn off the power to the oven. Remove the screws from the lower element. Pull the element out carefully. DIsconnect the wires. Take a volt/ohm meter set for ohms or continuity. Touch the 2 leads from the meter to the 2 element wire terminals. If you get no reading,replace the element with a new element.
If you do get a reading reinstall the element and replace the oven control.
Sep 21, 2009 | Stoves 720EF Electric Double Oven
Maytag electric oven - MER5770AAQ. lower heating element not work
Hi, Unplug the oven and remove the element to test it. Check the element and see if there is continuity. If the element is open, replace it. It can be bad even tho it doesn't appear bad.
I hope this helps you.
Vic
Jun 20, 2009 | Ovens
Is it easy to replace the lower element on a jtp 15 GE oven? While the wife was baking last week, the lowere element burned out. Was wondering if I could replace it myself
Easy replacement. Make sure to unplug power or shut off breaker. remove 1/4" hex screw on back of element. Pull off female terminals or some have screws. Install new element the same way.
Mar 23, 2009 | GE JTP15 Electric Single Oven
Electric Oven doen't heat
cdkd, there should be a TC0, on the back of the oven. Thermal cut out. You want to check to see if it is open. You will have to pull the oven out enough that you can remove the back panel cover and check it. The lower and upper oven should have one. It's a very cheap part to replace. If this TCO fails, no heat. Check this first before buying a new board. Catriver..post back.
Nov 17, 2006 | GE Profile JTP56 Electric Double Oven
AEG B8871-4 Electric Single Oven Logo
55 people viewed this question
Top AEG Ovens Experts
ashburton
Sal DeAngelo
Steve
Are you an AEG Oven Expert? Answer questions, earn points and help others
