Question about Marantz Audio Players & Recorders
Marantz sr5400 standyby light wont turn on - Marantz Audio Players & Recorders
I have marantz 7'300 an the standby light is on but wont power on no screen no sound idk help please
Unplug it from ac for 10 minutes and then try it. If that does nothing you need to get it to warranty service. It has a 3 year warranty so should still be covered. No Video or audio output on MARANTZ nr1602
Jun 14, 2016 | Marantz Audio Players & Recorders
The red light on my Marantz SR5008 keeps flashing and wont turn on. How can I fix this
Disconnect everything and then plug in only the power. If the light still blinks, the PS is probably damaged and will need to be serviced. If the light doesn't blink, you have a shorted connection. Speaker wires are probably the most likely.
Oct 07, 2014 | Marantz SR5001
Marantz sr5400 static
static is interference from other devices being too close to each other.
try moving or turning off devices that aren't being used. try not to stack all of your stuff on top of each other. i hope this helps
Apr 09, 2014 | Marantz Audio Players & Recorders
Projection tv wont start
check all your settings and connections to insure all are attached and set for desired input as for the original issue my projection tv did the same and just needed a new bulb good luck
Apr 05, 2014 | Televison & Video
Marantz pm-52 wont turn on
You need to get test equipment to be sure. DVM meter is a fine start
Apr 20, 2013 | Audio Players & Recorders
Error code 'CHECK E2P IF'
Water damage is the worst. It could damage the boards beyond repairability. It will take a professional to determined, if your unit can be saved
Nov 28, 2009 | Marantz Audio Players & Recorders
Error ""protecting" on maranz sr5400
The amplifier is being overdriven or components of the output stage are breaking down due to earlier overdriving.
May 17, 2017 | Marantz SR-5400 Receiver
TV turns on for a split second then back to standyby
i think your capacitor is blown, do a google search for insignia, lcd, capacitor...
you can buy another one for about $2 but its a pain to install, you can also instead buy a new powerboard for about $80, its an east install and you wont blow more capacitors
bestbuy.partssearch.com
May 09, 2008 | Insignia IS-LCDTV32 32 in. Television
19 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
