Unlock land grabbers - Computers & Internet
Have a problem can't get on my d2 pad cause I can't remember my password would like to get a new one
Posted on Nov 20, 2013
How to fix a grabber reacher?
I have a idea to help you .If apart ,you mean the rivets are missing? If this is the issue, find or ask a family member w/ a pop rivet gun.The claws that do the grabbing are stamped,labeled (L)-(R). Reassembling the Grabber w/ the rivet gun wouldn't be too difficult .I could fix your problem, if we were neighbors!
Mar 03, 2013 | Unger NN140 Nifty Nabber Trash Grabber 51"...
Can i connect a samsung camcorder vdp453 to windows7 pls?
Most of these camcorders do not have proper usb support for video, so you'll have to buy a so-called video grabber or capture card. You can plug in the video grabber to usb and then connect dvi or firewire from your camcorder. Install the included software, configure your camera. Then press play and the video grabber will record the input from your camera.
When you buy one of those video grabbers, make sure it's a good one. Make sure powerful and stable software (which is compatible with windows 7) is included. Cheap things usually don't work. I've had this Chinese piece of junk for $10 which lagged and kept crashing my computer. Pinnacle was a lot more expensive but it works great and the fun will last a long time.
Jun 17, 2011 | Samsung VP-D361 Mini DV Digital Camcorder
I need a driver for easycap usb capture card
http://www.szforwardvideo.com/support/index.html
That should link you to the drivers for your usb capture card. I believe the category you must select is "
USB Video & Audio Grabber". Make sure you choose the correct model. The directions should be pretty straightforward to follow. If you can't find the directions, I've posted them below.
• Download the DC60+ Video grabber with audio drivers and utilities file to your computer.
• Unzip this file to a directory you will remember, such as DC60+.
• Uninstall the old drivers for Video adapter with audio from your computer at first, and leave your DC60+ Video grabber with audio plugged into your PC or laptop.
• Run setup.exe, from the directory file.
• Plug DC60+ Video grabber with audio into your PC or laptop, and click "OK" or "Next" to update the latest drivers. Please find the installation step through Quick Installation Guide or Software and driver CD.
Name: dc60+ driver.rar
Mar 22, 2011 | Computers & Internet
How to get no. Of pixels from given image through java
try this code
import java.awt.image.PixelGrabber;
import java.awt.Toolkit;
import java.awt.Image;
class getpixel2
public static void main(String args[]) throws Exception
Image image = Toolkit.getDefaultToolkit().getImage("D:\\one.jpg");
if(image==null)
System.out.println("NO FIle");
PixelGrabber grabber = new PixelGrabber(image, 0, 0, -1, -1, false);
if (grabber.grabPixels())
int width = grabber.getWidth();
int height = grabber.getHeight();
if (isGreyscaleImage(grabber))
byte[] data = (byte[]) grabber.getPixels();
else
int[] data = (int[]) grabber.getPixels();
for(int i=0;i<data.length;i++)
int r = (data[i] >> 16) & 0xff;
int g = (data[i] >> 8) & 0xff;
int b = (data[i] >> 0) & 0xff;
System.out.println("(R,G,B)=("r","g","b")");
public static final boolean isGreyscaleImage(PixelGrabber pg)
return pg.getPixels() instanceof byte[];
} import java.awt.image.PixelGrabber;
class getpixel2
if(image==null)
else
May 15, 2010 | Computers & Internet
Good Morning- I have an '01 exploreer...My Drivers side door won't close..the "Grabber " in the door, is closed and won't open...Can i fix this myself? Thanks ...Patrick
try spraying some penetrating oil or WD-40 on it and stick a big screwdriver in the "grabber. While pushing the screwdriver towards the car pull the outside or inside door handle. make sure its unlocked. it should open right up, good luck.
Nov 06, 2009 | 2001 Ford Explorer
I have a EZ Grabber but do not know how to work it.
had same problem. ensure right selections are made in the souce menu. & that your connectors are out connectors and not ins.
Sep 18, 2009 | Ulead Videostudio 8 for PC
Pansat 2500a Dish Network Key
hola me puedes mandar las key de la pansat 2500
Feb 14, 2009 | Panasonic Televison & Video
Paperfeed on sx200 epson
The rubber grabber has got out of position.
Switch printer off.
Take all paper out of the feeder, put your hand in and you'll feel a rubber semi-circle, rotate (push) it toward the back of the printer until you can feel the rubber part disappear, load paper and switch the printer on and it should reset itself to the correct position.
Sometimes you have to press down slightly on to the paper weight sensor to unlock the grabber.
Try it and see how you get on.
Nige
The INK Store
http://www.the-inkstore.co.uk
Jan 09, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
