Question about AEG Lavamat W1450 Front Load Washer
AEG Lavamat W70 - AEG Lavamat W1450 Front Load Washer
rizla
  • 1463 Answers
SOURCE: AEG Lavamat 1000
hi
dont know if this is the one you need AEG 1000 Washing Machine
you may need to scrool down to download the manual .
riz.
Posted on Mar 03, 2008
  • 326 Answers
SOURCE: I need cogs for my aeg lavamat where i CAN GET IT?
you can get it at  www.repairclinic.com
Posted on May 06, 2009
SOURCE: AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
Posted on Jun 12, 2009
  • 174 Answers
SOURCE: aeg Lavamat 64840 programme stops at 1 minute.
The main PCB, before sending the door aperture signals, checks for the following conditions:
• The drum must be stationary (no signal from the tachymetric generator)
• The water level must not be higher than the lower edge of the door
• The temperature of the water must not be higher than 40º C.
Automatic release device
In the event of a power failure, or if the appliance is switched off using the ON/OFF switch, or if there is a
fault in the solenoid valve, the bi-metal PTC cools within a period of between 55 seconds and about 4
minutes (at a temperature of 65°C), thus releasing the door.
if after swiching off for longer than 5mins and the door lock does not unlock the lock must be faulty.
Posted on Jul 16, 2010
  • 174 Answers
SOURCE: How do i re set an EFO code on an AEG LAVAMAT
you just need to mop up the water inside the cabinet to allow the float switch in the base to reset.check there is nothing stopping the float returning to the floor. a small leak from the door seal can cause enough of a leak to trip it . clean the door glass and seal to stop this. or change the door seal.
Posted on Jul 24, 2010
Hi please advise.my aeg 110 lavamat does not switch on.completely dead'
Lavamat 110 doesn't exist. Maybe it's a lavamat 1100;1105 or similiar...
Dado
Mar 17, 2017 | AEG Washing Machines
Why AEG Lavamat 88840 Front Load Washer doesn't spin?
either the pump is blocked so cant pump water out so stops program.or brushes in motor worn down(both cheap fixes)
May 22, 2015 | AEG Lavamat 88840 Front Load Washer
What means c1 on aeg oko lavamat 74500
Hello!
Error C1 on AEG Lavamat usually means that there is a trouble with water filling. The required water level is not reached.
I reccomend you contact your local Service
Force Centre.
Here is the link to a manual of a similar AEG Lavamat waching machine (a "trouble shooting" part). Hopefully, it will help!
http://manualsbrain.com/ru/manuals/1793433/?page=30
Aug 20, 2014 | Washing Machines
AEG Lavamat 64809 error code E30
Lavamat?! Where in the *&%^ is this machine from? Yugoslavia! I'm guessing it will not allow water IN Because only the Spin (Centrifuge) cycle works?! So if that is so you need your water inlet valves replaced, there are Two. Even in machines named after a Bar of Soap!
Jan 04, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
Jun 10, 2009 | AEG Lavamat 88840 Front Load Washer
Operating instructions lavamat 538
type in ' AEG lavamat 538 ' into the top right hand address bar on your pc and you will find links that will give you all the instruction manuals you need... AEG is at the lower end of the list....
Good luck
sue
Aug 03, 2008 | Washing Machines
AEG Lavamat 1000
hi
riz.
Mar 03, 2008 | AEG Lavamat 88840 Front Load Washer
AEG Lavamat W1450 Front Load Washer Logo
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
