Question about 332-0061 - Commercial Conversion C
My keys cant lock my doors remotely - 332-0061 - Commercial Conversion C
  • 599 Answers
Check remote battery
Posted on Nov 20, 2013
Remote keyless entry
Hi
If the remote still working it self probably needs synchronizing,
to do so, turn the ignition ON,then turn the ignition OFF remove the key.
within 1 minute press and hold the lock button, press unlock button 5 times while you still holding the lock button. test the remote.
Good Luck
Mar 04, 2014 | Mercedes-Benz ML320 Cars & Trucks
2006 KIA.DOOR LOCKS; When you unlock the doors with remote, the doors immediately lock again. With the key, door unlocks and stays unlocked. however, the feature when you turn key to the right two times...
intermittant is spelled intermittent. .... Ah, locking system. ... You will find a broken wire in one of the doors that are used to set the door lock.
Probably the drivers door return wire.
Oct 26, 2013 | 1998 Honda Civic
Immobiliser problems ?
Use the key to lock and unlock door or truck, this is the same as using the remote. go to a door or the trunk and lock and unlock and then try to start the car, let me know the outcome. good day.
Apr 26, 2012 | 2003 Seat Ibiza
I had to break in my car and now my theft system is on and i cant start my car
Depending on the system you have installed... There is a reset procedure that must be done... It entails you first using the remote to lock the doors then get into the car by unlocking the door with the key get in the car and lock the doors, turn the key on, then off, manually unlock the door, open it exit the car after manually locking the doors. Close the doors... next unlock the door with the remote and all should be well. If not disconnect the battery for 10 minutes and retry. Hope this works
Jul 18, 2011 | Mercury Sable Cars & Trucks
Rear door hatch won't unlock at all the remote unlocks all doors except the hatch. Once in awhile it might open
some cars are fitted with a valet key/lock 3 keys supplied new 2 normal 1 with a flute running down the middle.key with flute will not unlock the tailgate/glove box.tailgate has 2 positions key upright=locks with central locking.key turned to the left,(or right,cant remember which)then released to upright,locked,needs key to access.independant of central locking.
Jun 24, 2010 | 2004 Mitsubishi Endeavor
I unhooked the battery now i cant stop the horn and it wont start the remote key does not work it got washed in clothes help please.97 camry
Lock then unlock the doors with the power lock button, with all doors closed (key not in ignition). If this doesnt work, try again using the key to lock and unlock from the driver door, with all doors closed.
May 12, 2010 | 1996 Toyota Camry
Remote key wont lock car
most likely the lock in the door might be bad if you cant lock it with the key then the sensor in lock is bad or the linkage bar came off need to pull door panel and look
Feb 20, 2010 | 2000 BMW 3 Series
Car doors wont lock with remote
Sounds like the rod that goes from the lock to the key came off. There is usually a little plastic clip that holds it together and they break and you get what you are experiencing. You have to take the inside panel off of the door to get inside it.
Jul 05, 2017 | Peugeot 406 Cars & Trucks
332-0061 - Commercial Conversion C Logo
23 people viewed this question
Top Paloma Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Paloma Vehicle Part and Accessory Expert? Answer questions, earn points and help others
