Question about Dryers
Speed Queen Good day.. I have a Speed Queen, when the water runs in when rinsing, it runs out into the drain at the same time. Please advise. Kind regards..
  • Dryers Master
  • 8,220 Answers
Drain hose too low (gravity) something in pump holding flap open (if applicable) old washer (broken drain flap) without model number impossible to say without doing some looking.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Nov 20, 2013
I have a speed queen top loader washing machine it start with the washing sickle and the timer stop when it must start to spin or rinse and i replace the timer with a new one
There is sometimes a pause between wash and spin. This allows a little time to pump the water out before starting to spin. Do you hear the pump running between wash and spin?
Feb 01, 2017 | Speed Queen Washing Machines
My speed queen is not rinsing, the water is still in my machine. What could be the problem? Do I need to call a technician?
Check the lint filter drain from clogging... socks have a tendency to lodge inside. If the drain is clogged, the water level sensor will not advance the program to spin.
Jun 16, 2015 | Speed Queen Washing Machines
Rinse cycle doesnt work
Because the water from the wash is still inside it and has not drained. So you need a new drain pump!
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Jan 19, 2014 | Speed Queen AWN432 Washer
Not competing a wash cycle or draining
A machine this old is due for replacement
Mar 11, 2017 | Speed Queen Washing Machines
Hi Good Day, I brought speedqueen LWS-16NW washing machine and timer is not working properly. I have replaced timer but still it is not working. Problem description: we have connected washing machine...
Hello Mohiddin,
The most probable cause of your troubles is the lid switch, the washer will fill and agitate with the lid open but the lid must be closed for it to spin(yes i know the lid is closed but if the switch is defective it doesnt think it is closed)
Hope this helps
Good luck,Gene
Jul 23, 2011 | Speed Queen Washing Machines
The Speed Queen Top Loading Washing machine used by my condo doesn't drain completely after the wash cycle. It normally leaves half of the wash water in the tub then fills the rinse water on top of it. ...
You are absolutely right, whoever told you otherwise is full of ____!! The wash water has to completely drain out and if it isn't there may be an obstruction of some kind in the pump if this is happening all the time. It could be a child's sock, or a bra wire, something like that. Have someone reputable check it out for you.
Jan 24, 2010 | Washing Machines
Sludge build up in the agitator caused by the water softener
I use ammonia and hot, hot water to clean the film or sludge from my washing machine.
Add (2) cups of ammonia, set the washer water temp to hot and fill it to high or large/extra large load. Agitate for (5) minutes and let soak over night.
Skim off any sludge that is floating then allow the washer to run through the rinse cycle. Re-rinse a couple of times to clear the system.
Good luck and let me know.
Regards,
Oct 12, 2009 | Speed Queen Washing Machines
Speed queen wont spin or rinse
i would guess you have something blocking the pump. take off the hoses on the pump and see if there is a sock or something in the hose.
be aware that when you take the hoses off there will be water trying to get out, so have a bucket and towels ready. it is best if you can pinch off the hose first, but not everyone has a way to pinch the hose.
Jan 07, 2009 | Speed Queen AWS52NW Top Load Washer
28+ year old- Speed Queen Heavy Duty top loader
It sound like you drain hose is siphoning off the rinse water, It needs a standpipe make sure the drain hose is at about the height of the top of the washer, Make sure the drain hose isnt stuck in the drain it also needs an air cap. the drain hose should not lay on the floor to run to the drain
Please let me know if this doesnt solve your problems
Aug 31, 2008 | Speed Queen AWS52NW Top Load Washer
Dryers Logo
56 people viewed this question
Top Dryers Experts
