Question about Xerox Phaser 7750DN Laser Printer
Black atc sensor failure - Xerox Phaser 7750DN Laser Printer
    Problem Solver:
  • 7 Answers
    The Black ATC sensor detects an insufficient amount of developer. Remove fuser and visualy check black developer housing. Does developer even on magnetic roll?
    If this failure reoccurs three times successively, you will need to clear Tech Rep Fault in service mode.
Posted on Nov 20, 2013
Hi! How to fix error code 092-315 for xerox 7225?
That is a black drum atc failure. First try to replace the black image drum and if that doesn't resolve it can be the MCU Board.
Mar 07, 2016 | Xerox Office Equipment & Supplies
Xerox workcenter 7345 erore code 009-383 ?
Your is an "ATC error" indicating that the density test has failed for Black. There are many possibilities, but here are the top 5:
1) Dirty or defective ATC sensor (130K63000) (difficult to reach..recommended to be done by technician)
2) Defective Developer (802k60194) (also difficult) You also need Developer Charge Powder (604K22550)
3) Defective ATC Clutch (121K23270) (also difficult to reach)
4) Drum (013R00624) not turning, or bad drum
5) Drum motor (007K88604) not turning
xerox and tektronix dell canon konica minolta qms samsung lexmark okidata...
Feb 07, 2016 | Xerox Office Equipment & Supplies
Cyan ATC sensor failure. Error code 14. I replaced developer and did ATC sensor setup. Still having issue.
Yellow ATC Sensor Failure,Code12
Magenta ATC Sensor Failure,Code13
Cyan ATC Sensor Failure,Code14
The ATC Sensor detects an insufficient amount of developer.
Note
If this failure reoccurs three times successively, an Engine NVRAM value is set preventing further printer use until the Clear Tech Rep Fault (see pg.6-20) is performed.
Troubleshooting Procedure
Step Actions and Questions Yes No 1 Is the problem toner and/or developer empty. Replace the toner or developer. Go to step 2. 2 Is the ATC sensor clean and free of dust, toner or any other contaminates? Go to step3. Clean the ATC sensor. 3 1.Check the ATC sensor wiring harness Yellow=P/J129
Magenta=P/J130 Cyan=P/J131
2.Is the wiring harness or the sensor defective? Replace the ATC Sensor and/or wiring harness. Go to step 4. 4 1.Remove the Rear Cover and RearShield.
2.Measure the voltage at...Yellow=P405B3 Magenta=P405B8 Cyan=P405A10
on the engine control board.
3.Is the voltage between+1 and
+3VDC? Replace the engine control board. Go to step 5. 5 1.Measure the voltage at...Yellow=P405B14 Magenta=P405B11 Cyan=P405A11
2.Is the voltage+5VDC? Replace the engine control board. Go to step 6. 6
1.Measure the voltage at...Yellow=P405B2 Magenta=P405B9 Cyan=P405A9
2.Is the voltage 0VDC? Replace the engine control board.
Go to step7.
7
1.Remove the Imaging Unit Plate cover.
2.Inspect the wiring harness between the engine control board and the developer housing assembly.
3.Is the wiring harness defective? Replace the wiring harness.
Replace the ATC Sensor.
8
Run approximately 10 pages of the solid fill full-page prints for this color to ensure the error is cleared.
Mar 12, 2015 | Xerox Phaser 7750 Laser Printer
2001 chrysler town and country. A\C heat Blowers will not work when controlled my front main pannel. It is a auto temp controlled system. The rear blower will work but no heat when controlled by the rear...
This may be similar to what I just fixed on an '00 dodge:
http://www.dodgeintrepid.net/showthread.php?t=89711
Accessing the Integrated Diagnostic System:
Procedure for Automatic Temp Control (ATC) equipped vehicles:
With the engine ON and the vehicle stopped set the temp to 75*F. Next hold down the Floor, Mix and Defrost buttons until the ATC display begins to flash. While the display is flashing, the system will run it's tests and calibrations.
When the display stops flashing, the tests and calibrations are complete.
The ATC display can only display one error code at a time. Any stored codes can be scrolled through by pressing the Panel mode button once for each code. DO NOT press any other button or you will have to start the test over. Note the codes and refer to the list below to determine what system is malfunctioning.
List of Climate Control DTCs:
23: Blend door actuator feedback failure (bad servo)
24: Mode door actuator feedback failure (bad servo)
25: Ambient temp sensor failure
26: ATC In Car thermister failure (ATC only, bad ATC head or ATC head disconnected while battery is connected)
27: ATC in car sensor failure (ATC only)
31: Recirculation door actuator stalled (stuck door or bad servo)
32: Blend door actuator stall failure (stuck door or bad servo)
33: Mode door actuator stall failure (stuck door or bad servo)
34: Engine temperature message not received (ATC only, bad ATC head or bus failure)
35: Evaporator sensor failure
36: ATC control communication failure (bad ATC head or bus failure)
37: Blend door actuator output shorted to battery (bad servo or wiring fault)
38: Blend door actuator output shorted to ground (bad servo or wiring fault)
39: Mode door actuator output shorted to battery (bad servo or wiring fault)
40: Mode door actuator output shorted to ground (bad servo or wiring fault)
41: Recirculation door actuator output shorted to battery (bad servo or wiring fault)
42: Recirculation door actuator output shorted to ground (bad servo or wiring fault)
43: Common door shorted to battery (probable wiring fault, could be a servo that failed in an odd manner)
44: Common door shorted to ground (probable wiring fault, could be a servo that failed in an odd manner)
45: A/C control blend door input open or shorted with respect to ground (MTC only, wiring fault or bad servo)
46: A/C control blend door shorted to battery (MTC only, wiring fault or bad servo)
47: A/C switch failure (MTC only)
48: A/C control mode door input shorted to ground (MTC only, wiring fault or bad servo)
49: A/C control mode door input shorted to battery (MTC only, wiring fault or bad servo)
50: A/C control electric backlite (EBL) switch fails (MTC only)
51: System voltage too low for calibration!!! (check battery cables, battery and alternator!)
Dec 10, 2014 | 2001 Chrysler Town & Country
FAULT CODE 009-380
The Yellow ATC Sensor detects a low TC (toner concentration).
Initial Action
  • Check that Toner/Developer is present.
  • Check the Yellow ATC Sensor for contamination. Ensure that the sensor is seated correctly.
NOTE:
To clear this fault, enter Component Control and set the value of NVM location 752-109 to 0.
This can be caused by many things. I've seen broken Drum contacts from improper drum installation causing Developer bead carryover. Toner dispense motor assy's failing. Developer Housing failure. DVHVPS failure.
Sep 19, 2014 | Xerox Fuser Cartridge 008R13040 for Work...
Xerox phaser 7760 saying "black ATC sensor failure - code 009-380", i changed developer and xerox phaser 7760 saying "black ATC sensor failure - code 009-380", i changed developer and xerox phaser 776
When you have a sensor failure, you need to replace the black ATC sensor and recalibrate it. Another reason for sensor failure is you are not getting toner moved down to mix with the developer...the toner tube/auger spring could be clogged up or not functioning.
Also if you changed the developer housing when you changed the developer, you need to change the value to the new sensor # that comes with the housing.
Feb 16, 2014 | Xerox Phaser 7760DN Laser Printer
Error 14 scanner
That sensor is located in the developer housing. You can either replace the sensor, or replace the developer housing, which comes with the sensor. Either way, you will need to go into diagnostics and set the value of the new ATC sensor after replacement. (You will need to replace the developer powder if you get a new developer housing)
Sep 19, 2013 | Xerox Phaser 7700 Laser Printer
004-354 cyan atc sensor failure
Hi mgordonO:
The problem is with the toner cartridge or the developer. One or both may be empty.
Apr 08, 2009 | Xerox Phaser™ 7760/DX Laser Printer
The car keeps coming up a code 23 on a 1999 chrysler 300 for the
Code 23= Blend door feedback control
On cars with automatic climate control: To enter diagnostic mode, set the temperature to 75F, press the the off button. Press Floor, Defrost\Floor, Front Defrost simutaneously for 3 seconds until the temperature display begins to flash.
On cars without automatic climate control, set the blower to any speed, turn the temperature control in between warm and cold. Press Floor, Defrost\Floor, and Front Defrost. All codes will flash via the Front Defrost button.
When the test is over all fault codes will be displayed (on cars without automatic climate control, they will be blinked out on the Front Defrost button).
Code Action
23 Blend door feedback control
24 ATC mode door feedback failure
25 Ambient temperture sensor failure
26 ATC in-car sensor
27 Sun sensor failure
31 ATC recirculate door stall failure
32 ATC blend door failure
33 ATC mode door stall failure
34 Engine temperture sense failure
35 Evap temperature sense failure
36 ATC head command failure
Mar 23, 2009 | 1999 Chrysler 300M
Xerox Phaser 7750DN Laser Printer Logo
267 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
