Question about Vacuums
Service conti express 1700w vacuum
Electric cord needs to be replaced
2 Suggested Answers
EwingElect
  • 276 Answers
SOURCE: Broken electrical cord
The belt can e replaced but I recommend you should take it to your local vacuum cleaner service center. They may even be able to fit a new plug on the end for you if the damage is at the plug end.
Posted on Mar 22, 2009
I need a belt for bosh extraxx 17 1700w hepa cycle tech .type vxvu170v00
Contact a local vacuum repair shop. This website doesn't sell parts.
Jun 26, 2017 | Vacuums
My Hoover pure power 1700w upright, bagged vacuum cleaner shuts down after 5 minute's use. Although I purchased the pure Hoover power 1700w upright vacuum cleaner around eight years ago it has not u
Are the brushes worn down too far? As they wear the springs tension gets weaker. The brushes can also get stuck inside the channel they slide in. Could also be a buildup of dust etc inside and around the internal fan or commutator, etc.
Jan 18, 2015 | Hoover Vacuums
Broken power cord inside Conti Twister vacuume. I cannot find how to open the motor to get at the broken cord.
without seeing it i can only guess.... but most motors require taking all the screws out of the vac and prying the halfs apart... sometimes you can get away with just doing the panel at the bottom by the hinge where the handle pivots( depending on model.... to get the motor itself apart.... if there arent any screws to take out tben youre prettymuch out of luck.... you need to see where its held togethrr and undo it.
Nov 08, 2013 | Vacuums
Loud high pitched noise from Electrolux Vitesse petlover 1700w
We had a vacuum cleaner that did that and it was the signal to say the bag was full. So to test this remove the bag and see if problem goes. If it does- replace the bag.
Dec 28, 2011 | Vacuums
How do I take about my Dyson DC11 to replace the retractable power cord assembly
While it doesn't require a collection bag, a Dyson-brand vacuum cleaner can still suffer the problems of wear and tear that are prone to any vacuum cleaner--for example, a frayed power cord. If the power cord of your Dyson vacuum cleaner has become frayed, change it immediately to avoid a dangerous electrical mishap. You will need a replacement cord from an electronics service center, along with a few common household tools. You do not need electrical skills to complete the task.
Follow this steps on how to replaced the power cord assembly:
1 Unplug the Dyson vacuum cleaner's power plug from the wall outlet. Press the button on the top front of the plastic collection cover. Lift the cover off the front of the vacuum cleaner and place it aside.
  • 2 Trace the power cord to where it enters the back bottom of the vacuum cleaner. Remove the screws from the panel surrounding the power cord with a Phillips screwdriver. Remove the panel. Aim the beam of a flashlight inside the compartment so that you can see where the wires at the end of the power cord wrap around two screws on the motor assembly. Loosen these screws with a Phillips jeweler's screwdriver.
  • 3 Pull the power cord out of the compartment and dispose of it properly. Strip a 1/2 inch of insulation from the ends of the two wires of the replacement power cord. Run the wires into the compartment along the path of the original power cord--pushing the wires into the grooves inside the compartment.
  • 4 Tie a knot on the cord on the inside of the compartment to prevent the cord from being pulled out.
  • 5 Wrap the exposed end of each wire of the power cord around the loosened screws. Tighten the screws. Replace the panel and reattach the screws. Stand the vacuum cleaner right side up. Place the bottom of the plastic collection cover into the bottom front slot on the vacuum cleaner. Push the cover back on the front of the vacuum cleaner.
  • Jul 13, 2011 | Vacuums
    How to replace belt on Hoover U6626-900 Wind Tunnel bagless.
    Click this to go to a site that will show you (complete with illustrations) how to change belt.
    http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
    I hope this helps.
    Jan 19, 2010 | Hoover U6630-900 WindTunnel Bagless...
    Electrolux vitesse pet lover 1700w. Keeps cutting out and electrical sparks in front vent
    Hi there SmartAlec from NelsonVacuums.com.au here. I am sorry to be the bearer of bad news but if you can visibly see sparks and its cutting out then i would say that the motor brushes are nearly worn out. On this particular vacuum cleaner they are not sold as a spare part so i think it would need to go to a repair center for a new motor or to vacuum heaven for a replacement.
    Regards Alec
    Aug 23, 2009 | Electrolux Vacuums
    Mar 20, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
    Hi , I have replaced the electric cord on Electrolux Lux Royal vacuum , but the rewind that retracts the cord does not pull it in . The coil spring looks ok but it will not pull the cord back in , any...
    http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=564353
    Generic problem for all Vacuums
    Hi, I have replaced
    Posted by dryder on May 02, 2008
    Hi, I have replaced the electric cord on Electrolux Lux Royal vacuum, but the rewind that retracts the cord does not pull it in. The coil spring looks ok but it will not pull the cord back in, any suggestions please.
    Thanks Dave Ryder
    I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
    The question I have is it the Electrolux or the Royal cordwinder, if the cordwinder is sprung you may have to get a new one or a good used one, it’s been a while since I have done a cordwinder and I have seen it done, but I know when you remove the cordwinder you need to lock in the spring so that it does not loose it tension and re-coil ability. You may want to ask your local vac dealer to see if you need to repair or replace. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
    http://www.royalvacuums.com
    Customer Service
    For help with a model that is not working, if you want to check an order, if you need help finding a part or service center or have any other comment, complaint or question that is not a technical question about this web site use the link above. You can also call our Customer Service department between 8AM and 7PM EST Monday through Friday at (800) 321-1134.
    http://electrolux.com Customer Service
    Electrolux Home Care Products – North America
    PO Box 3900 Peoria, IL 61612
    1-800-896-9756
    Don – The Vac Man
    Go Ahead. Use Us.
    May 02, 2008 | Vacuums
    Electrolux 2100
    Call your local Aerus Electrolux office. If there is a problem in the electrical system you should get that checked before you continue with the machine. As for the cord replacement- Any Aerus service dept. can do that for you. I say an Aerus office because should you let a non-Electrolux employee work on it you will void your warranty.
    Dec 08, 2007 | Electrolux UltraLux 2000 Bagged Canister...
    Vacuums Logo
    37 people viewed this question
    Top Vacuums Experts
    AskDyson
    AskDyson
    D. Floyd Kolb
    D. Floyd Kolb
    Are you a Vacuum Expert? Answer questions, earn points and help others
