Question about Goodman Heating & Cooling
Fan off and on by itself
My central a/c the fan off and on by itself 3, 4 times and in cool weather time.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 102 Answers
Check the fan in auto mood or manual
Posted on Nov 21, 2013
2 Suggested Answers
dhj144
  • 80 Answers
SOURCE: unit not cooling
Low on refrigerant charge! Low side line should be cold like a beer can at the inlet of the compressor with some sweat beads around it. 55deg. The discharge should be around 125deg just hot enough you cant hold it long!
Posted on Aug 29, 2010
Why is the time on my weather station always 3 hours behind
You need to set up the correct time zone offset. For example, CST is -6; EST is -5. If daylight savings is active, time will be: CDT = -5; EDT = -4.
CST = Central Standard Time
EST = Eastern Standard Time
CDT = Central Daylight Time
and so on.
The Official NIST US Time
Aug 27, 2014 | Oregon Scientific WeatherStation...
Want to know why one fan turns on all the time but the other two don't. Is this normal. The heating is working fine besides this. Tax
That's a condenser fan motors they work when you a/c system is running. On hot weather temperature they should work all the motors to keep the system cool.On the winter time they never works cause the weather outside is too cold.
Feb 03, 2013 | Heating & Cooling
How you know if you need a cooling fan relay
If your cooling fan is running all the time or if the cooling fan does not turn on when engine temperature is at normal or higher than normal temperature. It is possible in cold weather the fan may not turn on often.
Jan 12, 2013 | 1990 Honda Accord
Time reverts back 3 hours to DST
make sure unit is set for your "time zone" The adjustment button for pacific, central and eastern time zones is located on the back. Push the button until your specific time zone is reached.
Oct 29, 2011 | Eddie Bauer Wireless ClockThermometer
While driving my 2006 torrent the ac works fine but when i come to a stop or idle it blows hot.
the condenser cooling fan(s) are not working. Usually, it will be a fuse, the relay, or a bad fan motor itself. It cools while your car is moving due to ram air flow through the condenser....
Jun 26, 2010 | 2006 Pontiac Torrent
How to clean
mcdevito75 here, Start with a new paper filter or claen the perminant one, you"ll need enough WHITE VINEGAT to fill the pot itself 3/4 full of this WHITE VINEGAR, NOW pour the pot of 3/4 full of WHITE VINEGAR into the resovoir, replace pot in the coffeee maker and cycle thru the vinegar 3 times, each time letting the mavhine cool a bit for easy handleing, on the 3 rd cycle stop 1/2 thru the brew cycle, let machine cool for 30 Minutes, then complete that cycle. Now repeat with fresh water to reove all the vinegar from the machine. Your coffee maker should now be good as new.
Jun 22, 2010 | Cuisinart Brew Central 12-cup Coffee Maker
Have a 3 year old york central air system, used very little. Turned on --- compressor runs, but fan to cool compressor will not run. What is it? I doubt the fan motor is bad?
Most of the time if the compressor runs but not the fan, it is one of two things either burned/broken wires causing bad connection or bad capacitor. Simply replace capacitor with a capacitor with the EXACT same specifications and you are good to go.
Jun 27, 2009 | Heating & Cooling
Changing Time Zone on Wind & Weather Atomic Clock
1. Press MODE to select the time with the day of week
display mode.
2. Select the time zone by pressing and holding the “ + ”
button for 3 seconds.
3. Keep holding until the desired time zone (Pacifi c,
Mountain, Central, or Eastern) is selected on the
display map
Jan 20, 2009 | SkyScan 86742 Digital Atomic Wall Clock
Central unit freezeup when on
If you are running the unit in the A/C mode with the fan in the automatic position it could be the cause of the freezing of the coil. Try operating it with the fan in the on position and see if the problem goes away. When in the automatic operation the fan shuts off when the cooling unit shuts off and air circulation stops. Hence no defrosting of the cooling cycle in the off cycle. In the evenings when the outside temperature drops after sundown the pressures in the system drop in proportion dropping the temperature of the cooling coil sometimes causing ice formation on the cooling coil.
May 22, 2008 | Weather King 10AJA2501AH Air Conditioner
Heating & Cooling Logo
20 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
