Question about Marantz VP15S1 Lamp
My Marantz VP-15S1 bulb burned out (with 775 hrs remaining). The bulb was replaced with an LU-12VPS3 replacement bulb/housing unit. It worked fine for about 2 hours and quit working. When I pulled the replacement bulb/housing from the projector, I noticed that the tip of the center "stalk", where the wire enters the tip, appears to be broken. Do you have any idea why the replacement bulb would go out so quickly? Thank you.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
The lamp is a cheap one, you should purchase a original one
we supply the Original lamps for projector since 2002
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Posted on Mar 21, 2014
Adc 4000 turntable will not spin
I don't know without looking it up, but if your table is belt driven, pull up the rubber mat by the motor pulley and see if the belt is still on. I don't know what you mean by "tonearm clutch" belt. I sorry, but you'll have to explain a bit better. For more information, please visit my website at audioserviceclinic.com. Thank you.
Dec 14, 2013 | Marantz Reference TT-15S1 Turntable
How wiring diagram for christmas lights work
All the bulbs in a section of lights are connected in series, meaning one after the other, like links in a chain. If one bulb goes out the chain is broken and that section goes out. All modern light sets have bulbs which have a built-in feature called a shunt. The shunt in the bulb is supposed to short out if the bulb filament burns out. The advertising wording would be something like 'if one bulb burns out, the others stay lit'. It usually works, but there are limits. Sometimes the shunt in the burned-out bulb fails to work and the chain remains broken. You have to find the bad bulb and replace it. Also, every time a bulb burns out, if the shunt is working and the other bulbs stay on, the power to each remaining lit bulb increases. This puts a strain on the remaining bulbs, which is why you should always replace burned out bulbs as soon as you discover them. If you don't and more bulbs in the same section burn out, you can reach a point where there's too much power for the remaining bulbs to handle, and all (or at least many) of the remaining bulbs will burn out, necessitating a replacement of the string.
Dec 15, 2011 | Christmas Lights Etc Santa's Toy Truck
Lights dont come on the sliders.
The miniature light bulbs have probably burned out or the power supply circuit to them is not working if it is an older unit; on a newer unit, the leds are probably bad or the power supply to them is not working and will have to be replaced or repaired.
Feb 10, 2011 | Marantz Audio Players & Recorders
My Marantz 6110 will not shut off-turntable keeps spinning after arm returns
My Marantz 6110 wasn't working right. I had it repaired at a stereo store. They told me the grease was old and had hardened which made it difficult to operate the way it was supposed to. They cleaned it and used new grease. It's been working great for the last 10 years. I hope this helps.
Dec 23, 2010 | Marantz Reference TT-15S1 Turntable
I have a marantz 6150 turntable and the pitch contrôle dosent stabilise and speed varies. Any idea to fix it?
hi,
replace all the electrolytic capacitors in the circuit board. if its value changes this type of problem can occur.
ok
Dec 22, 2010 | Marantz Reference TT-15S1 Turntable
Lamp replaced 1.5 years ago, now the picture goes out but comes back on every few minutes, as if it gets to hot and needs to cool down. Fan comes on.
Lamps only last for 5,000 hrs -8,000 Playing hrs
It means every hour you Play TV Lamp burns up the hours, so after 5,000hrs on most Lamp needs replacing, some Lamps dont even last this long DLPs are not like Projection you can play them 24-7 and Tubes will remain good, But Lamps are like a light bulb they all burn out after so many hours.
Best thing is to turn TV off if you are not watching it, in order to Save Hours burt on Lamp.
Mats has Lamps for $99.00 1-800-628-1118
Replace the Lamp.
Mar 05, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Marantz SR8001fail to standby mode, will not reset
Test all your speaker impedances and check for shorts on both wiring and speakers. Use a digital multimeter. If you still have an issue, disconnect all speakers and test receiver. If you still have a problem, post a comment and I can help some more.
Aug 07, 2009 | Marantz SR8001
NEC projector LT220 - replaced bulb, works for 1.5 hrs then switches itself off
Hi Matt
There might be a couple of reasons for this problem.
Best is to start with the lamp - return the lamp to whoever you bought it from and insist on a another new one.
If the problem still occurs you should rather take the unit to a repairer - because it could be the Mainboard or the Ballast ( lamp's powersupply ) that is faulty and will need replacement or repair.
Check if your unit is under warranty - because the replacement of a Mainboard is quite expensive.
Apr 04, 2008 | NEC LT60LPK Projector Lamp for LT220,...
Marantz VP15S1 Lamp Logo
75 people viewed this question
Top Marantz Office Equipment & Supplies Experts
 Bob Buchholz
Bob Buchholz
bayou sam
Are you a Marantz Office Equipment and Supply Expert? Answer questions, earn points and help others
