Intex u-aa power earspeaker problem - Audio Players & Recorders
Our Intex spa pump will not turn on
does the unit power up if not check and test the ground fault safety plug they can fail --if powers up and pump not working then the your problem is most likely the ceramic rod that holds the motor /impeller in place they have a big problem of breaking and intex doesnt sell a separate pump or the replacement rod the following link can show some quick fix but if you buy a brazing / welding rod the same thickness -home depot sell them 9.99 a box you only need 3" and need to clean flux off
Intex spa E95 cheap fix
Jun 04, 2017 | Intex Pool & Spa
Plug trips when pump turned on. is there a fuse in the plug itself on intex sand filter pump
no internal fuse --check power supply breaker,can be bad plug gfi ,wiring short -wet,pump seized or frozen
Aug 14, 2016 | INTEX Sand Filter Pump
INTEX U-AA
samsung gt 3011charging problem
Oct 24, 2013 | Cell Phones
Does this phones internal earspeaker break often?
I believe your digitizer of the phone is broken that's the reason when you press the power button grey fuzz appears ,so what you can do is that call up the manufactures they will help you to fix it!
May 08, 2013 | Boost Mobile ZTE Warp Sequent Touchscreen...
Have an intex 16 x48" salt water pool generator
I checked the Intex web site and here is what they said:
There are several things you may need to check and do:
- Test the salt level first with Test Kit, and add salt as needed.
- Remove the electrolytic cell for inspection and clean it if necessary.
- If code 91 still appears despite the above steps, there might be a possible electrolytic cell
failure. Please contact Intex Service Center, and replace the cell if needed.
NOTE: Always turn the power off and disconnect power cord before cleaning and servicing.
I hope this helps.
Aug 24, 2011 | Intex Automatic Salt Water System for ...
Intex Krystal Clear Saltwater System for 2 weeks and now unit is dead. No display at all, no function. Power is on and receptacle for house power is fine.
Possible blown interanl fuse... You are required to call Intex and submit for warranty repair if under 2 years and if you have receipt.. Otherwise, you can look up blogs on how to open unit and replace the internal fuse.. Good luck.. Here's the intex number... 1-800-234-6839
Aug 19, 2011 | Intex Automatic Salt Water System for ...
No sound from earspeaker, only on speaker serrting
hi :) here to tell u slide phone much pro effect by the ribbon. even earspeaker cant use,no display,upper keypad no function. all above are effect by the ribbon. u need send for technician replace a new ribbon.
please voted me if my solution useful,thank..
Aug 02, 2010 | Sony Ericsson T303 Mobile Phone (Shadow...
No power on 8110 Intex Saltwater System
I have the same issue. Three years old so please do not say to send it in. Can you buy a replacement power supply?
Jun 14, 2010 | Intex Automatic Salt Water System for ...
Is it compatible 3.5 HP engine with the boat? (mariner 4) if yes , when i used %30 of power just alone back side go down and can not control properly . engine is TOHATSU M 3.5 S
Your motor is too large.
For the Intex Mariner 4 Intex recommend an absolute maximum of 3HP (2,2kW) and the motor must not weigh more than 40lb (18,2kg).
Those limits assume that you are using the Intex motor mount kit (Part No. 10658) and that the boat is correctly loaded and inflated.
In reality and from experience I would personally recommend 2HP maximum power and to keep the motor as lightweight as possible. Although the Intex Mariner 4 can take a motor mount, it's really a rowboat and is not suited to using a motor for extended periods, but just as a convenient tender to a larger boat it's fine.
Dec 15, 2009 | Intex Mariner 4 Boat Set
 Grubhead
Grubhead
