Question about Vacuums
Volta u3282 - Vacuums
My Volta vaccum is sucking strongly using tools but not when using floor vaccum
what blocks the suction hose when not in use . our dyson has a slide plate at end of hose
Feb 14, 2015 | Vacuums
How to turn on a volta ultima. I borrowed it off a neighbour and dont know how to turn it on, ive pressed every button, i dont get it!
Hi a_clockwork_,
Welcome to fixya!
The on/off is a pedal on the lower left side of the machine.
Hope this helps.
Handie Andie
Jul 15, 2011 | Vacuums
My simer ace in the hole a5000 will not charge my 2.5 year old battery. The battery voltage reads 10.75 volts. I replaced the twelve volt charger and it originaly lit the yellow charging light , but it no...
I does sound like a controller issue. Try testing the charging output (be careful, who knows what the voltage may be coming out) I would say it is the battery but the yellow light thing has me thinking you are right. That thing has been sitting there maintaining the battery for 17 years, it is probably tired. The other bad news is if your battery has been sitting at that low volta.ge it may have a greatly reduced capacity now. Hope this helps some. .
Jun 09, 2011 | Vacuums
My volta pet lover vaccumm won,t **** up the dirt and fluff off my carpet. It is also very hard to push when it is turned on.
The product is a load of rubbish. I wouldn't bother to fix it. It does not perform as desired. Scrap it or use it as a boat anchor!
Feb 16, 2011 | Electrolux EL1000A2 Pronto Bagless Stick...
Hot water not coming from my voltas mini magic water dispenser
Your heater element was damaged and need replacement.
Dec 17, 2010 | Vacuums
I have a volta ultima vacuum and the brush won't turn around anymore.
Tip the cleaner up and were the brush is theres a belt it is either slipping or broken replace. Undo cover over brush and undo brush lift out put new belt onto motor and then the brush and reassemble
May 17, 2010 | Vacuums
Volta ultima 2000 watt vacumn - hardly any suction at all
change your bag.or your motor is going bad so have that looked at.
Jul 03, 2009 | Electrolux UltraLux 2000 Bagged Canister...
How do i reverse the air cycle to blow up a pool i have a volta
should have a filter on the top of the machine that blows hot air. ripp it off and jam the hose in.. if not then your machine won't do it
Dec 18, 2008 | Electrolux Vacuums
Vacuums Logo
19 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
