Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Error message on boot up of Dell PC 5150 = Rv370 P-n 113-a62801-106 Bios
When i boot up my PC i receive the following error message 'Rv370 P-n 113-a62801-106 Bios' and i cant progress any further. Few times after turning PC off for several days it has resolved the issue but then problem resubmerges again.
  • 23 Answers
SOURCE: Dell Dimension 3000 reformat trouble
please re partition the hard disk and install the operating system. if the same error continues then change the ram and try
Posted on Jan 28, 2008
2dcapcom
  • 51 Answers
SOURCE: my dell optiplex gx200 bios can't boot
maybe try taking out the cmos battery located in your case, looks like a small watch battery, that will clear bios settings and start from scratch, if there is no battery then there is a jumper sequence to do this
Posted on Feb 17, 2009
jell587
  • 447 Answers
SOURCE: Upgraded Dell Dimension 3100 memory to 2 Gigs - Windows XP fails
Did you add the two sticks with the 512 or remove the 512 and add the two 1gb sticks? Try booting the machine with ONLY the 1gb sticks in.
Your machine supports 1gb modules but they can't be higher than 533MHz. Check that the memory you purchased was either PC3200 (400MHz) or PC4200 (533MHz) and is 1.8v. If you post the part number off of one of the modules I can look it up for you.
Posted on Feb 22, 2009
ChipcircuiT
  • 157 Answers
SOURCE: Computer won't boot up
i tell you m idea....first, maybe there is no operating system like windows or etc...second maybe your hard disk is not detecting or its damage,third, check the bios setup for the drives..it can help to solve the problem
Posted on Mar 04, 2009
antiochpc
  • 1314 Answers
SOURCE: Dell 5150 Start-Up Problem.. beeps
Beeping on startup is a memory error. The blue screen you got was most likely caused by a memory error as well. First, take out then re-install your memory. If the error persists and you have more than one stick, test each one singly to find out which stick is bad.
Posted on Jun 27, 2009
Locked out from eee box 1035 need to reset bios how?
Try this. Right out of the manual. The reset button is the little pin hole next to the power. Will need a paper clip that is straightened.
Entering the BIOS Setup
BIOS (Basic Input and Output System) stores system hardware
settings that are needed for system startup in the PC.
In normal circumstances, the default BIOS settings apply to most
conditions to ensure optimal performance. Do not change the
default BIOS settings except in the following circumstances:
An error message appears on the screen during the system
bootup and requests you to run the BIOS Setup.
You have installed a new system component that requires further
BIOS settings or update.
WARNING!
Inappropriate BIOS settings may result to instability
or boot failure. We strongly recommend that you change the BIOS
settings only with the help of a trained service personnel.
Quickly enter the BIOS
Windows8 boot time is quite fast, so we developed the following
three ways for you to quickly access the BIOS:
Before booting up the system, insert a straightened paper clip
into the BIOS Reset key.
BIOS Reset key
Press the power button for at least four seconds to shut down
your PC, then press the power button again to turn your PC back
on, and press F2 during POSt.
When your PC is off, disconnect the power cord from your PC's
power connector. Reconnect the power cord and press the
power button to turn on your PC. Press F2 during POST.
Oct 16, 2013 | Compaq Presario 5000 PC Desktop
NTLDR compressed on a Compaq Presario SR105CL cant enter bios to set to boot
Step 1:
Which operating system ?
Computer is booting from a non-bootable source. Computer hard disk drive is not properly setup in BIOS. Corrupt NTLDR and NTDETECT.COM file. Misconfiguration with the boot.ini file. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT.32 New hard disk drive being added. Corrupt boot sector / master boot record. Seriously corrupted version of Windows 2000 or Windows XP. Loose or Faulty IDE/EIDE hard disk drive cable. Failing to enable USB keyboard support in the BIOS. Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD ROM First verify that no Floppy Diskette or CD is in the computer, unless you are attempting to boot from a diskette. b> Note: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any card reader or flash reader make sure that no memory stick is inside the computer. Additionally disconnect all USB drives, cameras, ipods, iphones, etc. from the computer. If you are attempting to BOOT from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files or is corrupt. If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive. Second, when the computer is booting you should receive the below prompt. Press any key to boot from the CD
Mar 10, 2013 | Compaq Presario sr1055cl PC Desktop
When I started my DELL Inspiron 1525 running Win 7 Ultimate, I got a white-on-black screen which questioned the voltage from power adapter. Diagnostic program run.. Stopped with the following msg: Error...
2000-0142 and 2000-0146 are hard drive SMART errors, indicating the HDD will fail.
To boot message about the AC adapter was a BIOS level message that normally appears when a Auto/air ac adapter or other 65 watt ac adapter is used to power the system.
Jul 16, 2011 | Dell Inspiron 1525 Laptop
When i start my pc it display NTLDR file missing
Here ya go!
http://www.tinyempire.com/notes/ntldrismissing.htm
Jun 14, 2011 | Computers & Internet
My HP e9120f gave me the following error message the other day. "reboot and select proper boot device..." My first thought was my hard drive was bad. I could turn off the computer and after a...
You might have another part that has gone bad. Check the RAM and see if it gives you any problems.
There is a program call mem test that you can burn to a CD and test your memory. But if your no longer able to get to the bios:
you def had a hardware problem.
May 04, 2011 | HP DT PAVILION ELITE E9120f DESKTOP PC
I keep getting an error mess of 0xc0000225 when turning on my laptlop
We would like to know the exact error message or error code you receiving. Follow the below steps to get error message.
i. Restart the computer
ii. Start tapping F8 key
iii. You will see advanced boot option window
iv. Select " Disable automatic restart at system crash"
You may even check for the boot sequence order in BIOS.
BIOS DISCLAIMER: Modifying BIOS/complementary metal oxide semiconductor (CMOS) settings incorrectly can cause serious problems that may prevent your computer from booting properly. Microsoft cannot guarantee that any problems resulting from the configuring of BIOS/CMOS settings can be solved. Modifications of the settings are at your own risk.
Mar 24, 2011 | Computers & Internet
Laptop not used for some years. could enter bios OK to reset Replaced U/S CMOS battery with no problem. Restarted............ Message press F1 ibm bios setup press F11 to invoke IBM product recovery...
I received an IBM laptop with same issue a few months back. The error message due to the drained out CMOS RTC (coin-cell battery), which retains and other BIOS settings.
The system is OK and all you have to do is to get the CMOS/RTC battery replaced by the a professional.
Good Luck!
CreativeTECH
Dec 31, 2010 | IBM ThinkPad R30 2656 Notebook
When installing xp on new hard drive in a gateway GT5056 it says NTLDR is missing What does this mean
If you are attempting to install Windows XP and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive.
When the computer is booting you should receive the below prompt.
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again.
Aug 16, 2009 | Computers & Internet
Windows will not boot up
Hello.
If you got a Windows CD try the following...
Reboot the computer and enter bios by..
When the blue DELL™ logo appears, press <F2> immediately
You might have to try this a few times since you have to be really quick,
In system setup (bios)
Set CD Drive as first device in the boot sequence. Press F10 then chose "Y" to save.
Reboot.
When asked if you want to start on CD just press any key.
The menu on your cd should have a repair option.
Hope this helps.
Regards...
/Tech5508
Feb 14, 2009 | Dell Dimension 4600 PC Desktop
After 18 month the computer will not go into POST on a re-start but will start normally when completed turned off.
simple. clear the CMOS by using clear cmos jumper setting or remove the cmos battery and put it again and then change the bios settings as per ur machine configuration.
Feb 23, 2007 | Foxconn NF4UK8AA-8EKRS Motherboard
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
63 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
