Question about LG 50PX5D 50 in. Plasma HDTV
No display sound ok
No display sounds are ok
    Problem Solver:
  • 13 Answers
Factory reset if you can display the menu, otherwise needs a repair
Posted on Nov 21, 2013
When tv is powered on tv only displaying channel number and sound -no raster. using video mode displays are ok. sound is also ok
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Dec 06, 2014 | Sharp Televison & Video
I have a HAIER tv. model no is 21fa 18-t.picture ok no sound. But amplifier working ok system ic no is, 8865csng7ep1
Have you checked its speaker? Check it. If picture is OK, there should be sound, provided the settings to sound are OK; ie, sound system settings. Check the sound system settings once again. If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window. google.com/+GopakumarGopalan
Nov 01, 2013 | Televison & Video
Vertical line display, sound ok
You have a defective panel.
Mar 20, 2013 | LG Televison & Video
Dell(intel motherboard High Audio Defination sound)power showing yellow colour instead of green for display.It is not displaying at all, power supply ok, ram ok, cmos, ok, motherboard ok, audio sound no...
control panel administrive tools computer management device manager any yellow? ! question marks or red x will tell you that you need to reinstall the driver/s
to do this right click on the ? x ! select reinstall driver
control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 28, 2010 | Intel BIOSTAR Mainboard Support processor...
Asus Mother Board(P5GV-MX) display off, Boot time sound also off, The ram is OK. Processor can't check. Please give me solution.
Oct 18, 2010 | ASUS P5GV-MX Motherboard
How to turn off the ringer for HP 640 Fax Machine
Silent mode You can turn the sounds of the HP Fax (including ringing) on and off using the control panel button. You can also set all sounds to turn off on a daily schedule; for example, turn all the sounds off between 8 pm and 8 am. 1. Press Menu repeatedly until BASIC FAX appears and press OK. 2. Silent Mode will display. Press OK. 3. Select On-Daily and press OK. From: 00h To: 23h will display. 4. Enter a start time and an end time and press OK.
Jul 06, 2010 | HP 640 Inkjet Fax Machine
I get this error when I try to play a DVD on my laptop using WDVD
I assume that you are using a TV with the Computer to watch a Blu-Ray disc using HDMI connection.
In order to play a Blu-ray Disc (BD) movie on a television, the display configuration must be set to display on the television only. Having the image set to display on the computer and the television at the same time will generate the above STOP error message "Your display environment does not support protected content playback message".
Follow this procedure to properly configure the settings
needed to play a Blu-ray Disc (BD) movie on a television.
1. Connect the Computer to the TV using an HDMI cable.
2. On the Computer, click the Start -> Control Panel -> Appearance and Personalization -> Adjust screen resolution.
3. In the Display Settings window, click the Advanced Settings button -> Intel Graphics Media Accelerator tab -> Graphics Properties button.
4. In the Intel Graphics Media Accelerator window, under Operating Mode, click the down arrow and then click to select Single Display.
5. Under Primary Device click the down arrow and then click to select Digital Television, and then OK.
6. At the Confirm the Desktop Change prompt, click the OK.
7. In the Advanced Settings window, click the OK button.
8. In the Display Settings window, click the OK button.
9. In the Control Panel window, click Hardware and Sound.
10. In the Hardware and Sound window, under Sound, click Manage audio devices.
11.In the Sound window, click to select HDMI Device, and then click the Set Default button.
12. In the Sound window, click the OK button.
13. Now close the Control Panel window.
NOTE: Also check for any update for the software you are using to play the videos and update for the Video Driver
Good Luck!!!!!!!!!!
Oct 10, 2009 | HP Computers & Internet
Philips 32" lcd hdtv. HDTV no longer displays, but sound still ok
I reset the comcast cablebox. I totally unplugged the cablebox for 20 seconds and then plugged it back in. Turned on both the cablebox and the tv and the HDTV channels operated correctly.
Dec 08, 2008 | Philips 60PP9202 60" Rear Projection...
Display problem in pentium mother board!
MODEL NO.--INTEL 845 GVRS. problem is --- power led is on but no display and no beep sound. SMBS, RAM ,, PROCESSER, & HD Are all ok. Pls. tell me how can i slove my problem?
Nov 13, 2007 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
LG 50PX5D 50 in. Plasma HDTV Logo
26 people viewed this question
Computer Repairing
Computer Repairing
